Old 07-10-2020, 09:37 PM #1
iseeu1001 iseeu1001 is offline
iseeu1001 is on a distinguished road
can I put 17 trd rims on my 2013 20 inch limited rims?
I think the 17 inch rims look better then the 20 inch rims on my 4runner but how much would it cost to make it work?2013 Toyota 4Runner Trd 17-in alloy wheel - matte gray - PTR2035110GR | Jim Coleman Toyota, Bethesda MD
iseeu1001 is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 10:20 PM #2
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
I think it's a straight swap as long as you keep the same size tires that fit on the SR5 and TRD models.
Sent from my moto g power using Tapatalk
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 10:50 PM #3
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
The 17" and 265/70/17 that come OEM on TRDOR, SR5 and TRDP would fit with 0 modifications.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 10:51 PM #4
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
That's literally what I did on mine. Straight swap and added Falken Wildpeaks. Minor rubbing at full lock so I did the fender liner mod and it's all good now.can I put 17 trd rims on my 2013 20 inch limited rims?-img_20200625_121425-jpg
Sent from my Pixel 4 XL using Tapatalk
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 11:08 PM #5
shaun's Avatar
shaun shaun is offline
shaun is on a distinguished road
shaun's Avatar
So you want to replace your 20" with 17" rims? Yes you can do that but you will need new tires as well. You would be looking at around 800 or 900 or so for rims and about another 800 or 1000 or so for tires. FN Wheels make some good rims with different color choices as well which are made to be Toyota spec 17″ FN Wheels ƒ(x) Pro | FN Wheels Store I paid 899 for 4 shipped with lugnuts.
Oh another thing top consider is you may want 5 tires and rims to account for your spare. I know FN wheels will sell you a cheaper "dinged" wheel that may just have a scratch on it for cheaper.
shaun is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 12:36 AM #6
Originally Posted by mbm112 View Post
That's literally what I did on mine. Straight swap and added Falken Wildpeaks. Minor rubbing at full lock so I did the fender liner mod and it's all good now.Attachment 365229
What do you mean by rubbing at full lock? Did you need to adjust your speedo or anything?
Yup I want to change all 4. Donut rim is not the same size I think as my regular rim anyhow. 215x4=860+taxs 6% which is $911. Not bad prices for 4 rims and yes I did account into getting wheels lol because how else would I put them on? I can recoup the cost by selling my 20 inches. Tires should be somewhat cheaper then what I have on right now.
Old 07-11-2020, 07:06 AM #7
bowhun2r's Avatar
bowhun2r bowhun2r is offline
bowhun2r will become famous soon enough bowhun2r will become famous soon enough
bowhun2r's Avatar
If you go with the FN wheels they are 0 offset meaning the wheels are pushed further out than stock. At full lock (turning until the steering wheel stops) you will clip the front lower inner bumper with stock 265/70/17 tires on the LE. As @mbm112 stated it's an easy fix and no one will be able to notice it.
Speedo will be fine. The stock 20" and the 17" with stock 265s are practically identical in diameter.
Going Bigger - 5th Gen Tire Fitment Guide
That's an excellent thread with great info.
can I put 17 trd rims on my 2013 20 inch limited rims?-img_4782-jpg
23 ORP: FN Pro Wheels|Falken AT3 265/70/17|Ragu Molle Panels|Diode D LED interior Tail as Turn|Canvasback Liners|Dobinsons 300/700 599/705 10mm Spacer|12.volt RS|Tuxmat| OEM Audio+ Reference|
Sold 18 LE: Magnuson S/C| FN PRO Wheels| Diode Dynamics HID LB| Tail as turn LED| XD DRL/LB LED | Precision LED interior | Cooper AT34S 265/70/17 | Trail Rocker and Running Boards| 12.volt Solutions RS | Canvasback liners | Dobinsons 300/700 599/705 10mm spacer | ILX-207 Alpine PDR-F50 | Rago Molle panels | Pro grill with LED | Pro bumper swap | RCI skids
bowhun2r is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 08:49 AM #8
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
Buy a set if 17s from a member here (especially the OR wheels) and you can frequently get a wheel/tire set for $500 if you're not picky about the tires.
Even if you are, sell the tires to a used shop and you're still coming out ahead.
Toffees is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 02:00 AM #9
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
Alternatively, keep an eye on your local Craigslist as folks do sell take-offs periodically, especially from SR5s and TRD Offroads. You'd probably still want to upgrade tires if you plan on doing offroad driving, but you may easily be able to find a set of take offs for around $500 via this route too.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
4runner , cost , inch , make , rims
WTB - 5th gen 20 inch / limited tires and rims Mark4runnar For Sale: Suspension/Wheels/Tires 2 12-27-2017 11:31 PM
WTB - OEM 4th Gen 4R 18 inch limited rims SilverGs For Sale: Suspension/Wheels/Tires 0 01-30-2016 08:13 PM
WTB: Stock 20 inch rims from 5th gen limited xxaarraa For Sale: Suspension/Wheels/Tires 3 03-29-2015 05:47 PM
2013 Limited 20 inch tires & rims for sale LWRC7 For Sale: Suspension/Wheels/Tires 3 04-16-2013 07:55 PM
18 inch Limited Rims 4runnerjl 4th Gen T4Rs 1 07-11-2011 02:08 AM
