Old 07-13-2020, 11:31 PM #16
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Originally Posted by Deep_palancar View Post
An overfill of less than several quarts is of no real concern for engine damage. The only risk of damage is from so much oil that the crank shaft becomes submerged and froths the oil. It takes something more than 6 quarts to reach that level and when it does you will know it by the noise and vibration.
There is a lot of head-space above the oil to allow the vehicles to operate up and down hills at severe angles.
Hundreds of FJ Cruisers have been double filled since '07. On the FJ the engine drain is under the skid plate but the transmission drain is just aft and visible. Many, many have had the transmission pan drained and 6 more quarts of engine oil added to already full engine then driven for thousands of miles. Only a few reported oil frothing when climbing steep inclines.
An inch or so above the full line is nothing to fret over.
Thanks for your post. Makes me feel better. I have never heard of anything like that prior. If that were the case, why the min and max bump marks?
pointman is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 10:52 AM #17
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Beat me to it- I was gonna say since the 4WD Toyotas are built for and known to traverse extremely steep grades surely they took that into account when designing the oil pan- need to keep the pickup submerged and also need to keep oil from getting whipped by the crankshaft under pretty severe tilts.
Just changed my oil for the 2nd time this morning- first time was at about 1200 mi and just returned from a trip where I put 7200 mi on in 4 weeks. So I'm at 8400 mi.
I have the Shrockworks skids so it was nice to just remove 4 allen head screws to pop the filter access and go through the hole they included for the drain plug. Much easier than stock skids.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 07:24 PM #18
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
like I stated many times on my oil changes.. oil drains out of the engine 45 min !!! takes longer on my old GM V8 engines. oil ports in these engines Toyota takes longer to drain out.. then the oil guy will set up the 6.6 qt amount.. then it will be over the fill mark.. because the old oil was still in it some amount..
I put in 6.25QTS... at the fill mark.. check it the next day when it sits over night on level ground..
changing the oil at a repair shop less time more profit ..
catrains is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 05:53 PM #19
Banned
Banned
Thanks for your post. I appreciate the insight. The puzzling part is, this is the oil from the factory. I haven't changed it yet. I will be sure to go less than the 6.6 at first, and do as you said and add in after checking overnight. Thank you.
dealer , find , level , oil , service
ATF level high on cold... swampy_swimmer 3rd gen T4Rs 12 05-25-2023 10:21 PM
MPG @ sea level vs mile high? Dkon82 4th Gen T4Rs 19 09-22-2011 12:58 PM
oil level high at 4 quarts? jateelover Classic T4Rs 2 03-21-2010 02:11 PM
Motor oil dipstick level WTS Maintenance/Detailing 2 04-05-2007 10:49 PM
