Old 07-13-2020, 12:45 PM #1
omegadeluz77's Avatar
omegadeluz77 omegadeluz77 is offline
omegadeluz77 is on a distinguished road
Lift Help
I currently have Bilstein 5100s all around on stock springs. Corned spacer in rear and front shock on highest position (2.75?). I am running 285/70r17 and had gotten rid of the rubbing with fender liner tuck. I swapped my grill guard for a Warn Hidden winch and x20 synthetic. I am getting rubbing when turning in reverse. Will any type of upgraded springs provide a bit extra lift or am I limited out? I don't off road much now but to plan to in the near future. I appreciate any tips or suggestions. Thank you.
omegadeluz77 is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 04:45 PM #2
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Talk to mike with exit off-road on the Dobinsons thread. He will set you straight.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 08:23 PM #3
Thanks!
Old 07-13-2020, 09:04 PM #4
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
A new spring or a little more lift may help with rubbing on road, but as soon as you stuff the tire a little with IFS, you'll be back to rubbing again....Not the solution.
If you plan on going off road, and plan on staying with the 285's, and don't want to rub............fix the problem with either with a BMC, some plastic trimming, mudflap modification/removal ect, or all of the above, depending on where you are rubbing.
Also wheels spacers/negative offset wheels will make the rubbing worse....if you've done anything there.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 08:13 PM #5
Thanks for the suggestions.
Old 07-15-2020, 09:33 PM #6
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I have the same set-up......you need a BMC for sure and no spacers. I still have mudflaps that work but they are carved out in the wheelwell and I have spacers from my 275's but I am going to pull them as the 285's don't need them.
83Mule is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 10:36 PM #7
Do you have oem or upgraded springs or UCA?
Old 07-15-2020, 10:40 PM #8
Trail4Run Trail4Run is offline
Trail4Run is on a distinguished road
I am looking into ordering the Cornfed spacers. How have them been for you so far?
Trail4Run is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 04:14 AM #9
Zero issues in the last 3 years.
Old 07-16-2020, 07:59 PM #10
83Mule's Avatar
83Mule's Avatar
Stock springs, SPC UCA's
Old 07-16-2020, 11:49 PM #11
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
This is right on- find the rub first and clear the area. Personally, I would consider a heavier spring down the road.
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 12:01 AM #12
hkombrink hkombrink is offline
Real Name: Hayden
hkombrink is on a distinguished road
Real Name: Hayden
I'm currently running the bilstein 5100's at 2.5" upfront with 1.5" spacer in rear (OEM springs) I am considering switching to the Old Man Emu 884's and setting the bilsteins back to the 0" position which from what I've read will yield around 2.5" of lift. (Can someone confirm this lift amount??) If you're looking to go up to 3" I'm pretty sure the 885's will get you there or you could set the billies at .85" (first perch) and put the 884's on.
hkombrink is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 12:07 AM #13
The lift quotes for 884 & 885 sound correct at 0 position. That is with zero weight, with front weight plan on some sag. Don’t neglect replacing those shock circlips for safety.
Old 07-17-2020, 12:23 AM #14
Real Name: Hayden
Real Name: Hayden
Just curious why do you recommend changing the circlips/what are they for? I'm kind of a noob to the lift game haha.
Old 07-17-2020, 03:40 PM #15
Those are the clips you insert on the shock body that the front coil seats against to get .85”-2.5” of lift. Once used, manufacturer suggests you replace instead of re-use of the originals into a new location. There are stories out there of failed clips. Spend a few bucks for cheap insurance while you are replacing springs and resetting your new lift.
bit , lift , provide , rubbing , springs
How many inches of jack stand lift do I need to install lift spacer/bushings? 4Runner4Runner4 4th Gen T4Rs 3 03-21-2020 07:37 PM
WTT: ToyTec RCC2.0HD-P heavy lift springs for std 2" lift coils - CO DavisTN For Sale: Suspension/Wheels/Tires 1 09-09-2019 11:36 AM
F/S New 3rdGen Daystar 2.5" Front Lift/30mm Rear Lift-NJ thaemcee2 For Sale: Suspension/Wheels/Tires 3 10-07-2015 07:16 PM
Daystar 2.5/1.5 lift (newer easy version) - exact height of lift? BigEd 4th Gen T4Rs 1 05-06-2011 11:10 AM
WTB: Spacer lift kit, body lift, diff drop kit for 2007 4Runner deedubb Want to Buy/Trade 0 05-12-2010 11:45 PM
