Old 03-09-2021, 09:10 AM #16
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Sludge can be caused by other things as well not just type of oil. Long periods of idling in hot weather is what I think got me. I would make sure your PCV valve is new ($5) and also look at my post above about cleaning the OCV screens. Once I did those things I went to 5k OCI and its cleaned up. I'm at 215k+ miles now.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 241,000 miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 47,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 10:33 AM #17
TFT4RL TFT4RL is offline
TFT4RL is on a distinguished road
Thank you I will check those things out!
TFT4RL is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 02:24 PM #18
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Originally Posted by TFT4RL View Post
I’ve been using the the platinum synthetic from Walmart. Never had an issue with it before.
that's very good oil with a robust additive package, i strongly doubt that's where your problem is. Pennzoil had a PR disaster in the 80's with oil that was formulated wrong and sludged up badly...seems they're still living that episode down even today.
as Jivewalker said, overly extended change intervals for your uses along with poor PCV peformance and other minor factors like extended idling can contribute to oil varnishing in a way that might cause just enough sludge to affect a sensitive part like the oil control valves.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 05:16 PM #19
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
The OCVs have very tight fitment of the spool valve in the bore; a bit too much varnish can sometimes make them sticky and cause the DTC. Also an intermittently failing/weak coil can contribute to the issue, sometimes you might not notice a drivability issue.
Basically it doesn't have to be sludge in the sense of thick, chunky stuff; as MidniteTRD said, could be just a bit extra varnish on the valve and bore.
It's an issue that pops up every now and then on a lot of stuff.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 10:23 AM #20
Thanks for all the great info. I was thinking about it and I often do spend my lunch hour in my truck letting it idle. Maybe that caused an issue and had been building up over time. If it happens again I now know what to look for.
Old 10-29-2022, 12:28 AM #21
hiflyer767's Avatar
hiflyer767 hiflyer767 is offline
Real Name: TonyO
hiflyer767 is on a distinguished road
hiflyer767's Avatar
Real Name: TonyO
Originally Posted by Jivewalker View Post
Had same or similar issue about 100k miles ago after an extended OCI.
There are two oil pipes that feed oil to the oil control valve, one on each side of valve cover. At the top of those pipes, there is a bolt that holds it to the OCV. Take that bolt out, it is hollow. On the end of the bolt will be a plastic cased cone shaped filter with a metal screen. It should come out with the bolt, if not use a pick to get it out. Clean it up and reinstall screen, bolt to torque.
Also, pull the cam position sensors on the valve cover and wipe them off, may be some sludge on them.
Check PCV valve or just replace it, its cheap.
Ever since then, I change my oil every 5K.
THANKS FOR THIS INFO! It just did it to me again this past week, driving back home. I'm going to replace the OCV and the filter, as well. The oil is 500 miles away from being changed, but still clean!!!
So it's gotta be the OCV...and maybe the filter.
THANKS AGAIN!
hiflyer767 is offline   Reply With QuoteReply With Quote
Old 10-29-2022, 12:00 PM #22
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Originally Posted by Mack1611 View Post
I'm not a mechanic, but I did stay at Holiday Inn Express last night...
What causes the P0015 code?
The variable camshaft timing (VCT) oil control valve (OCV) is stuck in the open position.
The camshaft phaser is stuck in the retarded position due to damage or clogged oil passages.
Oil flow problems to the VCT piston and phaser from incorrect oil viscosity.
The OCV has an open circuit or the ECM has an open circuit.
The harness plugs are notorious for wires coming loose out of the back of the plugs when trying to pull them. Has happened to me both times I’ve changed spark plugs which had me pulling plugs, all on the driver’s side. The wires to the plugs can be repaired but you need the right crimps and crimping tools. Open circuits on these will have you unnecessarily changing expensive parts. Check every single wire at the back of the plugs.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 10-29-2022, 12:03 PM #23
I just had this exact same thing happen to me at only 52k. Took it to the dealer and they asked me when my last oil change was and what kind of oil I use. I usually go about 7500 miles between oil changes and the last one was about 2500 miles ago. I told them I use Pennzoil. They told me that may be the cause that some oils sludge up more than others and the Toyota oil has additives that prevents that. They did change my oil and clean my sensors and it is running smoother than it has in a long time. Could it really be the brand of oil I use?
They are full of it. I have 315K miles on a 2014 SR5 and I use Quaker State Synthetic 0w20 with change intervals of 10K miles.
camshaft , driving , lights , p0015 , plug
Wiper Control Stalk - Won't "Auto Return" Wiper in "Off" Position? Randyman... 5th gen T4Rs 4 12-05-2018 04:12 PM
17" or bigger wheels and tires under 33" look f*&%ing retarded on a truck. KidVermicious General Discussions 52 04-08-2016 07:00 PM
Retarded timing when A/C on LarsB General Discussions 0 06-16-2015 09:02 PM
Fuel Trim, Bank 2, "No Data" 0xfded 3rd gen T4Rs 3 10-13-2013 02:41 PM
Rear Window Issue - Stuck In "Up" Position. Tanner Classic T4Rs 5 05-25-2012 02:03 PM
