Old 07-14-2020, 01:01 AM #1
hiflyer767's Avatar
hiflyer767 hiflyer767 is offline
Real Name: TonyO
hiflyer767 is on a distinguished road
hiflyer767's Avatar
Real Name: TonyO
P0015 Camshaft Position "B" Timing Over-Retarded (Bank 1)
2015 4Runner SR5 4x4 w 115000mi, just installed new spark plugs and serpentine belt. I was driving along on the highway in Cruise Control at 90mph from ATL to Tampa when it went into limp mode and the following lights, Check Engine and TRAC OFF came on.
I managed to regain acceleration control when I'd pulled over and turned off the truck, then unplugged the Throttle Body plug and the MAF plug.
The lights cleared out the following morning. A week later, while driving to Kentucky from Naples, it happened again near the border between Georgia and Tennessee.
I repeated the same steps as before and again, the acceleration returned and the Dash Lights went away by the next morning. I'm now back in Chicago and had the OBDII code read.
P0015
Anybody able to help???
hiflyer767 is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 02:01 AM #2
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Could just be that Oil Control Valve for the exhaust cam variable valve timing is shorting itself out after driving it for an extended period of time. Worst thing is it might need the Camshaft actuator replaced.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 12:49 PM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
^^^ That does sound like an OCV to me too. Had the same problem on a 4th Gen.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 07:25 PM #4
Wolfman’s Brother Wolfman’s Brother is offline
Wolfman’s Brother will become famous soon enough Wolfman’s Brother will become famous soon enough
Have you tried wiring up raptor lights and adding a sick roof rack?
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
Wolfman’s Brother is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 08:23 AM #5
blanchard7684 blanchard7684 is offline
blanchard7684 is on a distinguished road
sounds like a cam timing solenoid is faulty.
This happened in my old mustang three times with same symptoms and same codes.
blanchard7684 is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 04:36 PM #6
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
I'm not a mechanic, but I did stay at Holiday Inn Express last night...
What causes the P0015 code?
The variable camshaft timing (VCT) oil control valve (OCV) is stuck in the open position.
The camshaft phaser is stuck in the retarded position due to damage or clogged oil passages.
Oil flow problems to the VCT piston and phaser from incorrect oil viscosity.
The OCV has an open circuit or the ECM has an open circuit.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 03:07 PM #7
Hunterlee's Avatar
Hunterlee Hunterlee is offline
Hunterlee is on a distinguished road
Hunterlee's Avatar
P0015
hiflyer767 did you get this figured out? I had the exact same issue happen yesterday.
2015 SR5 4x4 | Southern Style Offroad Sliders | Weathertech mats | Bilstein 5100's all around | Icon springs | ARB Rear Diff Breather | Nitto Ridge Grapplers 285/70R17 | ARB 2000 awning | Baja Rack Utility Flat Rack and ladder | 17" Fn countersteer wheels | Front Runner RTT
Hunterlee is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 12:31 AM #8
hiflyer767's Avatar
Real Name: TonyO
hiflyer767's Avatar
Real Name: TonyO
Sorry for the LONG delay...haven't been on in a while.
I changed my oil and filter as soon as I got home. Not a problem since. I believe I was over mileage on my oil change by about 1200 miles due to my LONG ASS ROAD TRIP to Naples, FL from Chicago...
Old 08-10-2020, 12:34 AM #9
hiflyer767's Avatar
Real Name: TonyO
hiflyer767's Avatar
Real Name: TonyO
I'd love to. But, my garage is an old Chicago style with a 6' door. It barely squeezes in NOW with the factory roof rails...
Old 08-19-2020, 10:31 PM #10
Hunterlee's Avatar
Hunterlee's Avatar
No worries!
But awesome! I’ll have to give that a shot. I appreciate the feedback.
Old 08-20-2020, 07:54 AM #11
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Had same or similar issue about 100k miles ago after an extended OCI.
There are two oil pipes that feed oil to the oil control valve, one on each side of valve cover. At the top of those pipes, there is a bolt that holds it to the OCV. Take that bolt out, it is hollow. On the end of the bolt will be a plastic cased cone shaped filter with a metal screen. It should come out with the bolt, if not use a pick to get it out. Clean it up and reinstall screen, bolt to torque.
Also, pull the cam position sensors on the valve cover and wipe them off, may be some sludge on them.
Check PCV valve or just replace it, its cheap.
Ever since then, I change my oil every 5K.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 02:14 PM #12
customtc customtc is offline
customtc is on a distinguished road
thanks for the info
customtc is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 09:09 PM #13
TFT4RL TFT4RL is offline
TFT4RL is on a distinguished road
I just had this exact same thing happen to me at only 52k. Took it to the dealer and they asked me when my last oil change was and what kind of oil I use. I usually go about 7500 miles between oil changes and the last one was about 2500 miles ago. I told them I use Pennzoil. They told me that may be the cause that some oils sludge up more than others and the Toyota oil has additives that prevents that. They did change my oil and clean my sensors and it is running smoother than it has in a long time. Could it really be the brand of oil I use?
TFT4RL is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 10:07 PM #14
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Which Pennzoil version have you been using? At 7500 mile intervals, even their conventional oil shouldn't be building sludge. But if you're running conventional oil at 10K intervals you're going to have sludge in your future.
waypoint is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 08:45 AM #15
I’ve been using the the platinum synthetic from Walmart. Never had an issue with it before. Seems strange to me. Maybe I’ll switch to Mobil 1 and see what happens. I can’t see paying double for Toyota oil.
camshaft , driving , lights , p0015 , plug
Wiper Control Stalk - Won't "Auto Return" Wiper in "Off" Position? Randyman... 5th gen T4Rs 4 12-05-2018 04:12 PM
17" or bigger wheels and tires under 33" look f*&%ing retarded on a truck. KidVermicious General Discussions 52 04-08-2016 07:00 PM
Retarded timing when A/C on LarsB General Discussions 0 06-16-2015 09:02 PM
Fuel Trim, Bank 2, "No Data" 0xfded 3rd gen T4Rs 3 10-13-2013 02:41 PM
Rear Window Issue - Stuck In "Up" Position. Tanner Classic T4Rs 5 05-25-2012 02:03 PM
