Old 12-28-2020, 06:45 PM #16
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Instructions are on the meso web site, down loaded them last night. Also there is a tube you vid that shows it fairly well. Everything minus the 12v illumination for the switch.
INSTALL GUIDES
– MESO CUSTOMS LLC
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 06:52 PM #17
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by Charlievee View Post
Where did you tap into the 12v illumination for the switch?
See the enclosed wiring diagram above.
Connect wires to the Wiper warmer switch:
Gray - dimming ground
Green - 12V illum power
I just used a regular chassis ground, so my switch backlight does not dim.
Note that these wires are very small gauge. I used an exacto razor blade knife to carefully slice off some insulation to expose the wire and soldered to it. Be sure to insulated and strain relieve with tape or cable ties so you don’t tug on them too much after installation.
Old 12-28-2020, 09:18 PM #18
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
INSTALL GUIDES
– MESO CUSTOMS LLC
Thanks! I guess they must have just put them out as I couldn’t find them last week.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 09:48 PM #19
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Anytime Control of Mirror Puddle Lights: Use as Ditch Lights
Originally Posted by jhguth View Post
has anyone installed these who doesn't have factory puddle lights?
I believe oldred sells a harness which converts your mirror harness to premium harness. Then you can add mirrors with puddles and turn signals.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 07:36 PM #20
Originally Posted by BEAR x SF View Post
After an unsuccessful first install meso provided a second harness and it turned out the first one was defective, been looking forward to this since picking up the meso puddle lights last year, also went ahead and rearranged the switches from factory. Looking forward to the map lights to match the dome light.
I finally got around to installing mine, what was defective about yours? Mine don’t seem to turn off if I leave it in auto mode even with the truck started.
Old 03-26-2021, 12:25 PM #21
4RPower's Avatar
4RPower 4RPower is offline
4RPower is on a distinguished road
4RPower's Avatar
Out of stock...
Looking forward to doing this cool mod, especially since MeSo Customs now has (in stock) the plug and play wiring harness for the 5th gen. The puddle lights however are not in stock. I asked via email when/if they would have more. Actually got an email y'day "more are in production and will be avail....soon"
2017 SR5 prem in silver: Viper remote starter, Carista fob mod, Aries mats, Rhino Rack mast holder, BLACK Fluid Film, TRD forged billet oil & radiator caps, LED puddle mirror, map, cargo & reverse bulbs, Kat's battery wrap, Bilstein 5100 level lift, OEM hitch cover, glove box organizer, ARB Scuba mod, Lamin-X yellow w/ Calais yellow LED, lift gate stickers, dipped emblems, FJ40 shift knob, ambient light sensor mod, MeSo puddle pods, blacked out steering wheel garnish, Driver side A-pillar grip handle...and the fake Pro grill
4RPower is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 02:19 PM #22
Great write up ElectroBoy. But I took the easy route and installed the meso puddle light kit. It worked like a charm as it was all plug and play.
Also I added the reverse trigger to it so the puddles automatically turns on while backing up. If you want to give this a try. Just connect pin4 of the meso puddle light kit switch to the reverse trigger pin4 red wire in main body ecu harness.
Thanks OldRed for the trigger wire.
Old 04-14-2021, 04:09 PM #23
Banned
Real Name: Mark
Banned
Real Name: Mark
Thanks, that’s a great idea!
I’m looking at the back-up lights wiring diagram and how to wire it into my setup.
I’m wondering if you could check something out on your 4R for me.
When you flip the Meso switch to On, do the backup lights turn On as well as the puddle lights?
Old 04-14-2021, 04:16 PM #24
When I manually turn on the puddle lights, the reverse back lights does not turn on. Only time the back up lights turn on is when I’m actually in reverse.
I made my own anytime front - rear camera harness and I had to add bias diodes when ever i touched the reverse trigger. So both front and rear mode has a diode.
If your having that issue when manually turning on puddle lights, are you using reverse trigger ? If so the diode may also be needed.
The diagram below is for the CTH anytime camera switch when used with the T9. But I’m showing this as a diode example.
Old 04-14-2021, 04:22 PM #25
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
I had the same idea after doing the MESO puddle lights upgrade a while ago. I used a AOB switch with a relay to be able to manually turn on\off the puddle lights with ignition on. I was able to get a wiring diagram of the puddle lights from a member here, and successfully tapped into the system. Works great
12 Volt 3amp ON-OFF Toyota OEM Replacement Push Switch with LED blue lights for Highlander, Tacoma, 4Runner, Tundra and Sequoia
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 05:52 PM #26
Banned
Real Name: Mark
Banned
Real Name: Mark
I haven’t implemented a reverse trigger yet. But yeah, that’s what I was thinking, that I’d need to add a forward biased diode from the MB ECU harness 2F pin 4 (Backup lights +12V) to the Meso switch wire that powers the puddle lights. That would block any puddle light operation from turning on the reverse lights.
But with this circuit whenever in reverse there would be +12V going to the MB ECU illumination output F10 pin 4 (MILE). This is what supplies power to the puddle lights. I’m not sure if that output driver would be OK with that when it’s not active. Might be better to add another diode in that line, similar to your diode ORing scheme for the camera control.
Thanks for the info, another project for me.
Old 04-14-2021, 07:48 PM #27
Depends on where your getting 12v to power. During reverse trigger on backup should be okay with no diode. your anytime puddle switch power is different than reverse so your okay Anytime Control of Mirror Puddle Lights: Use as Ditch Lights
I would wire it first to see if the back up lights only comes on during reverse only, then your good.
Old 05-04-2021, 02:22 PM #28
4RPower's Avatar
4RPower's Avatar
Back in stock at Mesocustoms.com !
Bit pricier than expected....but I had to have them.
Old 08-26-2021, 08:35 AM #29
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
So much great info in this thread!!!
I am ordering the Meso Customs harness and switch today. I'm definitely going to be doing the reverse light modification as well. You guys are fantastic!!! Thank you!!!
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 08:38 AM #30
007Tacoma's Avatar
007Tacoma's Avatar
Quick question...
Does anyone know where we can get more of these DPDT Toyota Switches or have them custom made?
I have an ugly silver DPDT switch on my dash that is used for controlling my interior running lights (red LEDs so I can see in the cabin without affecting my night driving vision). I'd love to be able to make that flow with the rest of my dash...
I'm 007Tacoma.
anytime , lights , meso , product , switch
Rock lights on with puddle lights munkel 5th gen T4Rs 3 08-10-2022 03:39 PM
Anyone installed the 5th gen mirror covers with the blinker and puddle lights? SilverGs 4th Gen T4Rs 123 02-09-2020 12:06 PM
Ditch lights and rear lights JayToo 5th gen T4Rs 1 10-17-2019 12:32 PM
WTB headlights and drivers door mirror with puddle lights Mudballz Want to Buy/Trade 0 05-03-2019 09:21 PM
Problem with mirror turn signal and puddle lights Crseth 5th gen T4Rs 3 01-01-2014 08:34 PM
