Old 07-20-2020, 06:53 PM #1
BrianRD BrianRD is offline
BrianRD is on a distinguished road
Suspension barks, like a dog
After off-roading for a bit, my front suspension starts making noise, the best way to describe is is like a dog barking. Any ideas what could be causing it?
It's not the shocks, those have been replaced with Bilstein 6112s and it still does it. Do I have osmething that needs to be lubed? Replace bushings in the control arms?
BrianRD is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 07:18 PM #2
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
Is your neighbor's toy dog missing? ;)
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 07:47 PM #3
Sbenis Sbenis is offline
Sbenis is on a distinguished road
When you came back home did you pressure wash the suspension?
Sbenis is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 11:05 PM #4
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Dust sheilds, skid plate rubbing?
itr1275 is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 10:33 AM #5
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
It's dust in the various suspension components. Common. Wash it, goes away.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 02:55 AM #6
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
I have total chaos lowers and mine does the same thing. Bought new bushings. Had them installed a total of three times following their tech to the T. Does fine for a week but has to be re lubed way too much.
Has a set 4 years ago and a buddy has them now on a different rig, quiet as can be. So whatever total chaos changed sucks.
Anyway, most likely lower control arm bushings.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 08:26 AM #7
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
what kind of grease are you using?
tm965 is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 02:18 AM #8
GX4SEVEND's Avatar
GX4SEVEND's Avatar
Superlube. Exact one sent with the control arms.
‘14 SR5 in white
Full RCI skids
Old 07-23-2020, 08:33 AM #9
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
A co-worker's 2019 Tacoma TRD OR was making a noise like that when he would hit small bumps. You could actually rock the truck while it was parked and hear it. His problem was a cab bushing. They changed it and fixed the noise. I know they're different than a 4runner, but might could check that....Now thinking about it....probably wouldn't be that because the 4Runner doesn't chassis flex like a Tacoma.
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
yota1976 is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 09:01 AM #10
I started with superlube and after experience some squeaks, I switched to the following and have had much better luck:
molygraph--have used this the majority of the time as i can use it on my delta joints too--have never had a squeak since
Amazon.com: CRC Sta-Lube SL3330 Moly-Graph Extreme Pressure Multi-Purpose Lithium Grease - 14 Oz.: Sports & Outdoors
Got this to use on my lca delrin bushings, will use this on my uca bushings moving forward as well... pricey
Amazon.com: Prothane 19-1751 Super Grease Tube - 14 oz.: Automotive
Old 07-23-2020, 12:45 PM #11
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
I have dirt king lowers. They use a delrin bushing. I have only heard them squeak a few times a month or two after the initial install and that was because I've improperly greased them and playing at a mud park contributed.
Ever since then after a proper grease, I have yet to hear a peep. I try to grease them maybe every 6 months. You could try to see if their delrin bushing is compatible with your total chaos lowers in the furure.
I use Lucas oil red n tacky grease.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
bilstein , control , dog , replaced , suspension
WTB: TRD Pro Rear Suspension Take-Offs (Shocks & Suspension) - Houston, TX steveh_2007 For Sale: Suspension/Wheels/Tires 0 03-06-2020 12:02 PM
Box of new 4th gen suspension parts(Energy Suspension, OME, MOOG) and headunit $35 nytosc For Sale: T4R Items 0 08-06-2019 01:01 PM
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
