Old 07-23-2020, 06:03 AM #1
Paragon1's Avatar
Paragon1 Paragon1 is offline
Paragon1 has a spectacular aura about Paragon1 has a spectacular aura about
Paragon1's Avatar
Creaky Suspension after Icon Stg 2 Install
2015 TE w/ KDSS. Had the suspension installed in March. First Have a sneaking suspicion they didn't install the lower front bushings properly as I've seen videos of installers having to drill out one of them, which I suspect needed done but wasn't, and instead they only installed one of them. I noticed this when I had the car up on a jack and saw the base of the shock sitting crooked on the bolt.
Second, squeaking. For the love of god, the squeaking. Its coming from the front. Thought it may be the rubber bushings on the sway bar since they're extended due to the 3" lift, but now i'm not so sure. For anyone who's dealt with this, how did you remedy it? Im currently TDY and 800mi away from the installer.
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
Paragon1 is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 08:27 AM #2
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
I installed my Icon Stage 2 myself and I can say that both bushings should fit fine and there is no need to drill anything out. As of right now, I personally know over 20 people with Stage 2's (installed themselves) and the coilovers went on with both bushings and no drilling. I am not sure what videos you watched, but swapping out some front coilovers is pretty straight forward. In my opinion they should both have bushings, and it would drive me nuts that they both don't.
For the second part of your question, I did have some squeaking with my Stage 2 when I initially installed it. My issue was the upper control arms and not the coilovers themselves. I have JBA upper control arms and just needed to add a couple more shots of grease to each zerk and I was good to go. If you installed upper control arms to keep your alignment in check, you may want to look into the greasing of the UCA's also.
Hope this helps!
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 03:04 PM #3
Paragon1's Avatar
Paragon1's Avatar
I’ve got the icon tubular ucas, will give them a look. Thanks for the info!
Old 07-23-2020, 04:07 PM #4
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
be sure to loosen your uca bolts before greasing and use a good grease. had a shop grease my uppers while they were installing new lowers and they did not loosen the bolts... my ride was incredibly rough and bouncy when i left the shop. thought it had to do with the new LCAs, then i looked at my uca bushings and found they were completely buldged out
tm965 is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 08:04 AM #5
Paragon1's Avatar
Paragon1's Avatar
Hope this helps!
You, sir, are a gentleman and a scholar. Squeaking seems to have resolved. Not only did it appear the upper zerks not greased, they didn't put the dust covers over the end delta joint zerk, so I had to order some of those too.
Unbelievable how fast a reputable shop can go downhill.
Old 07-25-2020, 06:56 PM #6
Thumbs up Awesome! Glad I could help!
Well I am glad you found the problem! I know squeaks and random noises can drive you crazy! Definitely get those dust covers on and just remember to put 2-3 shots of grease in each zerk every 10,000 miles (at each oil change). It may call to do it more often but I have had luck just doing it at each oil change and it helps me remember. Happy wheeling and enjoy your nice, quiet suspension!
Old 07-25-2020, 09:04 PM #7
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
A lot of aftermarket parts like to use urethane bushings. They are worse when it's cold outside too.
You have to make sure they are lubed up good or they will squeak.
Energy Suspension Formula 5 Bushing Prelube
Do polyurethane bushings squeak? Not with this stuff! - YouTube
Other people have polished the sleeve inserts. Personally I would start with the grease.
itr1275 is offline   Reply With QuoteReply With Quote
bushings , install , installed , squeaking , suspension
T4R Forum Special - ICON Suspension & ICON Alloys Wheels - Ends 3/8! Battle Born Offroad Battle Born Offroad 0 03-02-2020 02:50 PM
Creaky Suspension Ggradtech 3rd gen T4Rs 6 03-19-2018 01:20 PM
need quick help please on ICON suspension install. Hbryanlopez 5th gen T4Rs 7 08-03-2017 05:13 PM
Icon Suspension Install Mick1 5th gen T4Rs 17 07-18-2014 10:15 AM
Icon Suspension & Bumper Install YotaDan FJ Cruiser 5 05-29-2013 03:21 PM
