07-24-2020, 01:51 PM
#16
Real Name: Joe
Real Name: Joe
Awning is something to consider. My wife gets up in the night to use the loo, so likes to sleep on a cot down below. Works great. Picture is Yellowstone NP. We were on a paved spot, so couldn’t tie down corner. Otherwise is a little less wrinkled.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
07-24-2020, 01:54 PM
#17
Real Name: Joe
Real Name: Joe
Originally Posted by tls3601
Been my understanding that a hard shell RTT can be mounted to stock roof rAck with addition of stronger crossbars like LFD, has anyone done this and care to post up a pic?
Try the Niserack. Installed on factory side rails, super solid. Less than $300.
07-24-2020, 01:57 PM
#18
Real Name: Tom
Real Name: Tom
Would it be long enough to install a hard shell RTT on it? Thinking something like the roof nest.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
07-24-2020, 02:23 PM
#19
Originally Posted by Gxblade1
Is that a XL?
Just the regular. I think the XL is only wider and not longer. I think
YouTube
07-24-2020, 02:39 PM
#20
Real Name: Joe
Real Name: Joe
I put the front and rear mounts as far apart as possible, and then measured the distance from the back of the rear mount to the front of the front mount (maximum surface distance). I got just over 38 inches. This is definitely not a full roof, or even a 3/4 rack, so you would have to measure the mounting requirement for your RTT.
My 23zero has a distance between mounting rails of about 33 inches, but I mount mine sideways (ladder and entrance on passenger side), so it fits with no problem.
Hope this helps. Let me know if you want some pictures with tape measure or items on top.
07-25-2020, 11:26 AM
#21
Still a lot to think about it seems. I do appreciate all the information though. Truly.
08-28-2020, 12:48 AM
#22
Hope you guys are checking the oem roof rack load capacity before piling 350lbs+ up there.....
Aftermarket racks typically employ additional points of contact with the roof to help distribute the load more evenly.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
09-06-2020, 03:52 PM
#23
I own a Smittybilt RTT which is a soft top. I wish I owned a hard top one. Definitely considering purchasing their latest hard top version.
09-06-2020, 04:59 PM
#24
Real Name: Nick
Real Name: Nick
Agree
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
