Old 07-25-2020, 02:31 PM #1
numbbrrr numbbrrr is offline
numbbrrr is on a distinguished road
Aluminum Skid plate with access panels to oil filter AND oil plug?
Winter is coming and after 3 years my metal skid plate is rusting out bad after 3 years trying to ask the question. Does anyone know a "bolt on" ALUMINUM skid plate that has access panels for both the filter and oil drain plug? Thanks in advance!
numbbrrr is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 02:39 PM #2
shaun's Avatar
shaun shaun is offline
shaun is on a distinguished road
shaun's Avatar
CBI comes to mind. Toyota 5th Gen 4Runner Full Skid Plates - CBI Offroad Fab
shaun is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 02:43 PM #3
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Hefty Fabworks
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 02:47 PM #4
chester4Run chester4Run is offline
chester4Run is on a distinguished road
RCI has a hole for the drain and an access panel for the filter.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 04:39 PM #5
fbksurferjoe fbksurferjoe is offline
fbksurferjoe is on a distinguished road
2nd for RCI. Also has hole for transmission drain and transfer case drain on the crossmember. Was a nice surprise this morning when I went to drain the transfer case and transmission.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
fbksurferjoe is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 08:48 PM #6
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
RCI Aluminum.....Sweeeeet.
83Mule is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 09:11 PM #7
skinny420 skinny420 is offline
skinny420 is on a distinguished road
Check out BudBuilt.com Pics of mine linked in sig or see here: Fuji the 4Runner |
skinny420 is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 12:14 AM #8
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
LFD Off Road just released their Aluminum front skid, it has an access door for the filter and a cut out for the drain plug
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 08:35 AM #9
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
Another for RCI
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 09:20 AM #10
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Subscribed
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
oil , plate , plug , skid , years
Access to oil filter w/o removing OEM skid plates obxbird 5th gen T4Rs 14 07-07-2021 08:22 PM
Skid plate with oil filter access? Bftfan 5th gen T4Rs 4 06-17-2019 03:08 PM
Modifying skid (for oil filter access) before researching a new one Flyer 4th Gen T4Rs 6 01-15-2014 08:25 PM
Skid plate access question howieb 4th Gen T4Rs 5 02-21-2010 09:35 AM
Where is that Skid Plate Mod for easy access to the oil filter greasefingers Maintenance/Detailing 6 06-01-2006 11:00 AM
