02-28-2013, 09:42 PM
Fog lights with high beams... the easy way
I had wanted to make the factory fog lights operable off the switch with high beams, but after seeing the how much work was involved on the 5th gen courtesy of ANTMAN, I decided to take a different approach.
If the high beams are on, I decided there wasn't much need to turn the fogs off. Simple solution was to add a relay, with the coil powered by the high beam circuit. The relay provides power to the fogs from a constant 12V source (and of course isolates the circuits so the highs don't come on with the fogs nor overloads the circuit). In my case I have HID's installed, so I tapped the 12V fused feed from the battery at the ballast relays, and the added high/fog relay only powers the coil of the ballast relays.
One $6 relay, eight connectors and bit of wire, no cutting of vehicle wire or taking the dash apart, fog switch and indicator light still works with low beams, and I know my fogs are on whenever the high beams are on. About 5 minutes to do.
If you want the ability to turn off fogs when the high beams are on, a separate switch could be added to interrupt power to the relay coil.
03-01-2013, 01:15 AM
Real Name: Rick
Real Name: Rick
Sounds like an interesting solution. Would you mind posting a wiring schematic?
2012 Trail Edition, Salsa Red, MetalTech (Icon) Long Travel Rear, Panhard Relocation Bracket, Radflo 2.5" Extended Travel Front, LR UCA's, 17x9 XD wheels, Cooper S/T Maxx 285/75-17's (34"), 4.56 Gears, Wet Okoles, Weather Tech FLoor Covers, Canvasback Cargo Covers, Shrockworks Sliders, BudBuilt Hidden Winch w/ Warn 9.5ti, On-Board Air (using sliders as air tanks), Rigid D2's, RCI Skids, Body Mount Chop, Console Vault.
03-03-2013, 10:15 AM
Pictures please...
03-03-2013, 02:01 PM
This sounds like a good option. I was wanting to free up the fog lamp switch on the stalk for use on my LED auxillary lights. This method lets me do that.
Thanks.
03-03-2013, 02:34 PM
This sounds pretty cool. I also really wanted to allow my fogs to work with the brights as there is a dark spot right in front of the vehicle with the brights when you lose the fogs. I'll have to check this out and give er a try!
03-03-2013, 03:38 PM
You want to be able to turn fog lights off with high beams for safety or don't use your high beams at highway speeds, which could also be a safety issue. When driving at highway speeds, you want your attention focused down the road and not being drawn close to the vehicle, which fog lights do. This is why they are disabled with high beams. Using fog lights with high beams off road is fine since your speed is much slower and your attention is going to be focused right in front of you.
This space for rent.
03-03-2013, 10:37 PM
I've never thought of it that way but it makes total sense. I've always just figured that it had something to do with the legalities of having 6 front facing light beams on at any given time. Great point!
03-03-2013, 10:57 PM
Thanks! I always wondered why they were wired that way.
03-04-2013, 03:27 PM
Diagram
Diagram is attached, drawn without HID conversion. If you want to be able to shut off the fogs, a switch could easily be added between the power from the high beams and the added relay to interrupt it. I have not been distracted by the added light so I don't see the need for a switch.
My state requires that headlights have high and low, so even though the bulbs are separate it counts as one light. Three auxiliary lights and two spot lights are allowed in addition to headlights.
05-05-2017, 05:17 PM
Real Name: Steve
Real Name: Steve
This is an old thread and I don't think the OP is active anymore...
Has anyone else done this mod?
I installed some Rigid D2s in my Fog locations, and brainfarted the fact that they won't be on with the high-beams.
I want to do this as it would solve my problem, but my knowledge of all things electrical is embarrassing.
With that said I "think" I understand the diagram, but I have no idea what relay to get, what kind of connectors or gauge of wire or anything else I may be overlooking because I know diddly about electrical do-hickys and widgets and other magical things.
Can anyone give me a parts list of what I actually need to buy? (and any other advice for keeping me from burning up my truck would be helpful)
Thanks
-Steve
_________________________________________
'14 Mag Gray 4Runner TEP
No More: '11 T4R SR5 - '98 Lexus GS400 - '98 T4R Limited - '87 T4R
04-21-2020, 04:10 PM
There is a really clean looking plug and play product called the brite box installs in about 10 minutes sold by aspire auto accessories
Reason: link
04-21-2020, 07:12 PM
Looks interesting. They also appear to have a H11 > H9 conversion harness to avoid trimming the bulb itself.
Saving this info for when the BD Squadron Pro’s arrive.
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
04-21-2020, 10:04 PM
Has anyone found a way besides ANTMAN's method in running the fogs by itself?
04-22-2020, 06:46 AM
It's spendy, but I'd be interested to hear reviews of that.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
01-24-2022, 11:24 PM
I figured out how to control my fog lights independently on my 06 Tundra, it was a simple thing to cut one wire and supply another source of 12V to the switch on the stalk. Problem was, it was applicable only to Access Cabs w/o DRLs. That write up is out there on a forum somewhere. I'd like to do the same thing on my 4Runner. The Brite Box is tempting but it doesn't utilize the factory fog light switch on the stalk to have anytime control. You have to install a new switch. Kind of defeats the purpose to me. I'll check out Antmans technique.
2012 4Runner SR5 4WD
2011 Tundra Doublecab 5.7L SR5 4WD
2013 Highlander AWD-Better Half
2005 Highlander AWD V6-Daughter
2006 Highlander FWD 4cyl-Son
