Old 10-01-2020, 09:57 AM #16
Gonecamping's Avatar
Gonecamping Gonecamping is offline
Gonecamping will become famous soon enough
Originally Posted by Jax4runnerTE View Post
My 2013 Trail lists the GVWR as 6300# rather than the typical 5000# I see for most 4Runners.
I assume this is due to the suspension (w/KDSS) set up and would like to know if the Trail tongue weight is impacted as well over the 500# typically noted.
Looking to use the 4Runner for a 20 ft Airstream with 3800# dry/5000# loaded weight and 550# tongue weight for a short period of time here in Florida.
Would install a WD/Sway, maybe bags to supplement, so just looking at any info on the Trail towing differences.
Thanks
GVWR does not equate to towing capacity. I personally wouldn't want to tow anything above 2500 lbs with the 4Runner, unless it was a perfectly flat road at sea level.
Gonecamping is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 05:10 PM #17
halflife78's Avatar
halflife78 halflife78 is offline
halflife78 will become famous soon enough
halflife78's Avatar
I am currently looking at getting that basecamp airstream and along with it I have been considering supercharging the 4Runner along with getting bigger brakes and tranny cooling.
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
halflife78 is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 09:30 PM #18
onesojourner's Avatar
onesojourner onesojourner is offline
onesojourner is on a distinguished road
Everyone has a standard but man that is a low one. I have towed with my 3rd gen all over the place from the rockies to Florida. My 4runner has about 100hp less than you. I found the experience to be adequate.
OP Did you get that trailer yet?
Airstream towing-signal-2021-03-09-082833-jpg
onesojourner is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 02:46 PM #19
DanTh3Man DanTh3Man is offline
DanTh3Man is on a distinguished road
I tow a Wolfpup 16 BHS with my '15 and don't have any issues. I'm running a 4 point sway control WDH and airbags in the rear.
Make sure to haul in S4 and gear down to S3 for hills and you'll be fine (other than never driving past a fuel station without stopping).
DanTh3Man is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 01:30 PM #20
b407driver's Avatar
b407driver b407driver is offline
b407driver is on a distinguished road
b407driver's Avatar
Originally Posted by rector15 View Post
Any of you towing an airstream with a 5th gen? I have a 2020 pro and interested in a smaller airstream (16 or 19 Bambi) but not sure how capable the vehicle would be.
We tow a T@b 400 (~3000-3200 pounds actual tow weight) here in CO, and would not want it to be any heavier. You need to get used to screaming around at 4000+ rpm in this thing, and only use it in 'S' mode (we never use 5th gear). We use a brake controller but no sway control, and hav only found sway an issue when on pavement that is severely rutted (i.e. deep tire depressions along the direction of travel) from semi traffic.
The 5th Gen is not a tow vehicle, but it does work. Can't imagine pulling 5000-lbs, though...
[1986 Toyota XtraCab, 1990 4Runner SR5, 2003 Seqouia SR5] 2016 SuperWhite 4Runner TRD Trail
ToyTec 1" TRD Spring Seats, both set at top perch (2" lift) | Wheelers/Eibach T-13 1.5" rear coils | Cooper AT3 275/70-R17 tires | TRD Skidplate KDSS mod (cutouts) | Smittybuilt BeaverStep w/grip tape | Rola Vertex cargo basket w/AT Low-Profile mounts | ARB Differential/E-locker Breathers | Rotopax 2x 2gal fuel, 2x 2gal water
b407driver is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 03:51 PM #21
Metal Head Metal Head is offline
Real Name: Eric
Metal Head will become famous soon enough
Real Name: Eric
Here's a previous post I made on this same subject. Not an Airstream but a similar weight trailer.
A few 1000 towing miles later and trips through GA mountains since that post and I'm still OK with the 4Runner towing performance.
I highly recommend the hitch (quiet & leave connected while backing) & brake controller (clean install) I have.
https://www.toyota-4runner.org/3516166-post500.html
Metal Head is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 08:10 PM #22
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
Airstream basecamp 20X
My bride and I just purchased a loaded Airstream Base camp 20X. We have towed it on a couple of 200 ish mile trips and absolutely LOVE the camper and the 4Runner/base camp combination.
Our 4runner is NOT stock. Larger CAF radiator, 4.88 gears, 285/70/17 E load range tires etc.
Truck weighs 5700 with just me and my wife and a full tank. Trailer is 4300 fully grossed out.
We tow in 4th at about 3100 rpm/60-62 mph. 12.0 miles per gallon over almost 800 total miles. I will flip it up into 5th on long downhill grades.
We use a frame mounted Draw Tite hitch that was meant for an Australian market Prado 150, and a Blue OX Weight distributing hitch.
Last weeks trip to Lake Eufaula in OK. had the CAT Scale reading:
Front Axle 2860 Drive Axle 3440 Trailer Axle 3660
Total Gross 9960
Great trip and very easy to tow.
More to come on The actual towing set up and loading coming soon...
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 08:27 PM #23
bill444 bill444 is offline
bill444 is on a distinguished road
Putting aside payload capacity, the issue can be the trailer pushing around the 4Runner particularly at higher speeds and on non-flat terrain.
I think someone quoted the dry weight and GVWR for the 16' Basecamp and 16' Bambi. They're roughly the same and could both be within spec for the 4Runner. However, the Bambi is wider and taller.
If you're extra cautious, consider the height / shape / width of the trailer when making your decision.
2022 ORP, 1995 Land Cruiser
bill444 is offline   Reply With QuoteReply With Quote
Old 09-20-2022, 09:51 AM #24
MickeyR MickeyR is offline
Real Name: Mickey
MickeyR is on a distinguished road
Real Name: Mickey
Thank you for post
MickeyR is offline   Reply With QuoteReply With Quote
airstream , capable , iphone , towing , vehicle
Pulling an Airstream with a 4Runner TerraCrawler 5th gen T4Rs 2 04-06-2018 02:44 PM
v6 vs v8 for Towing? kylixz 4th Gen T4Rs 9 09-01-2016 09:04 PM
Towing a 24-27' Boat with the V8 - What are you towing? rmd0311 4th Gen T4Rs 7 09-10-2009 08:36 PM
towing with V6 2WD suuny 4th Gen T4Rs 11 09-18-2007 01:20 PM
Towing an Airstream Trailer pickerdd 4th Gen T4Rs 13 11-03-2006 09:28 AM
