Old 07-26-2020, 01:17 AM #1
Old 97's Avatar
Old 97 Old 97 is offline
Real Name: Aaron
Old 97 is on a distinguished road
Old 97's Avatar
Real Name: Aaron
Suspension Advice Request
Hey y'all,
I'm trying to plan out the appropriate moves to augment my suspension setup as I continue to make changes to my T4R. I'd appreciate any advice folks may have to keep me from making a mistake.
My current setup is Bilstein 5100s all around (1.75 up front, 1" cornfed spacers on the rear), the purpose being to level the truck with a slight lift, and to stiffen the ride a bit. I've just put new tires on, and went from stock to 275/70/R17s, and am getting a bit of rub on the right front mud flap.
What I'm aiming to do in the very near future is add a Victory Blitz bumper up front (~30-60lbs, haven't decided between aluminum or steel as of yet), followed by a Warn M8000-S winch (~60lbs) added on early next year. I'm concerned that I'll need to upgrade my front coils to support the ~90-120lbs of additional weight. In doing so, I'd like to maintain the more leveled rake, and perhaps add another inch of lift to avoid having to remove the mudflaps due to the new tires. As such, I'm open to the idea of replacing the rear spacers with upgraded rear coils as long as I can maintain the appropriate rake. Finally, I'd like to avoid having to swap UCAs if at all possible.
I'd love to hear any recommendations or experiences that might help guide me towards a setup that will address the additional weight up front and potential extra lift.
Thanks!
2017 SR5 4x4 Premium (Nautical Blue)
Old 97 T4R Journal
Old 97 is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 06:52 AM #2
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
Bilstien makes rear coils for 1.5" lift. But if you are adding weight up front then look into replacing all 4 coils with either Dobinson or OME. Both companies make coils for added weight while maintain a level ride hight with your 5100.
You mentioned that you didn't want to swap out your UCA but if you decide too than look into JBA uca. They are cheaper than many other brands that are out.
Chubbypanda is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 07:00 AM #3
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by Old 97 View Post
Hey y'all,
Thanks!
I'd say install the bumper/winch first and see if the drop in static ride height is ok. If not, you could measure and then decide which coil to use to get it back to an acceptable static ride height.
Regarding the rubbing, when does it rub and how bad is it? If its minor rubbing when you are on the bumpstops and fully locked, you could try using the heat gun to move around the mud flap to keep it from rubbing. 275s on stock offset shouldn't be a problem so I'm assuming you're running a different wheel.
Adding an extra inch of lift will not help you much with the rubbing when offroading/articulated. Also, adding an extra inch to your 1.75 lift will likely result in you needing UCAs to adjust the caster. Using stock ones may not get you enough caster to move the tire away enough from the body mount/mud flaps.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 04:46 PM #4
Old 97's Avatar
Real Name: Aaron
Old 97's Avatar
Real Name: Aaron
Thanks for the recommendation, I'll look into them.
That's probably a good idea. I was a bit worried that the 5100s would struggle without the additional support from the coils, but I'm not adding a whole lot of weight so it might be better to wait and see how it holds up.
As for the rubbing, I did some testing today and found that I'm actually rubbing on the front fender, not the flaps. It only happens when fully cranked in either direction and reversing. Also, I'm running TRD Pro wheels, so my offset is a bit different than stock. Gonna have to dig in to find the least intrusive way to address it.
Thanks for the feedback!
Suspension Advice Request-img_8179_2-jpg
Old 97 T4R Journal
Old 07-29-2020, 01:20 AM #5
Angle grinder and trim down the bumper a millimeter or 2 and move the fender well forward a bit.
There are 2 screws holding the fender liner at the bottom
Remove them slide fender well foward a few millimeters and screw back into place.
Old 07-29-2020, 10:34 AM #6
keyser_soze's Avatar
keyser_soze keyser_soze is offline
keyser_soze is on a distinguished road
It is very easy to trim the front fender and move the liner back a bit. This will solve the rubbing issue.
Do not hesitate to get new springs. I had the Bilstein 5100 and Daystar 1.5" combo for years and I recently upgraded to Dobinson (2.5"F / 1.5"R) springs and it rides so much better! I wish I would have just done this from the start. The springs are cheap anyways.
I also upgraded my bump stops and sway bar bushings. These are cheap ($160 for everything) and are very easy to install, I highly recommend upgrading if you are already going to be working on the springs. The bump stops help the initial feeling over bumps making it smoother. And the sway bushings make a noticeable difference in body roll while driving at speed on windy roads.
2015 SR5 Premium Bilstein 5100 | Dobinsons Springs | SCS SR8 | 285 Toyo Open Country AT3 | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS LEDs | JBA UCAs | CTH T9 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Dayton HO 10"
keyser_soze is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 05:33 PM #7
Old 97's Avatar
Real Name: Aaron
Old 97's Avatar
Real Name: Aaron
I found I didn't need to trim anything, moving the fender liner forward solved the rubbing issues. Thanks for the advice!
I've been looking at the Dobinsons, particularly C59-314 (front) and C59-505 (rear). Were you able to keep the Bilsteins with the Dobinson coils, or did you need to replace the struts as well? If you kept them, what did you set the front strut height to? If you had to replace them, which did you end up using?
I'll take a look at some bump stop and sway bar bushing options as I'm planning this all out.
Thanks!
Old 97 T4R Journal
Old 08-03-2020, 11:02 AM #8
The Dobinsons work with the Bilstein 5100s. I left the front strut at the lowest setting.
front , lift , rear , setup , spacers
Looking at 1st Gen, Advice Request DavidR1 Classic T4Rs 11 10-16-2019 02:08 AM
Totaled '99 advice request niwtsol 3rd gen T4Rs 29 09-20-2017 05:58 PM
New PC, request advice on WIN 7 vs WIN 8.1 philsey Off Topic 18 04-26-2015 12:22 AM
Newby service advice request leo General Discussions 2 04-23-2012 11:33 AM
Looking for advice (+ pic request) bennett518 5th gen T4Rs 17 08-28-2011 09:55 PM
