Front Windshield Fluid not working
The fluid is not coming out to clean the front window. The rear is working fine.
I found the reservoir tank completely empty (odd since I barely use it). Filled it up and have been watching for a week.
The tank has emptied a few inches, but figure it is due to the lines being empty.
-Do not see any moisture buildup, so assume the line is not leaking.
-Did not see any lines disconnected or bent after a quick look around.
-The motor sounds like it is working, but will find someone to help me confirm this.
-Since the back is working, guessing it is not a fuse.
-Thought one of the wiper fluid nozzles would shoot out some fluid if it was a clog on the nozzle.
What else can I look for when I do a more in-depth inspection? Will double check everything listed above.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
