Old 07-27-2020, 05:36 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Too Many Wiring Terminals on Battery Bad?
Before I can shell out the money for SPOD or Switch Pros, is it bad to hook up too many wire terminals to the battery? I have 27F Northstar AGM battery and there are two lightbars, anytime front/rear camera and a winch hooked up to the battery terminals. I'll soon be adding a fridge powered directly to the battery. Is this too much?
Chilow is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 07:16 PM #2
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Look into a Bussman Relay/fuse panel. Run one cable from the battery to the bussman. They come prewired just look on Ebay.Or search on the forum.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 07:37 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I'm surprised you even have any threads left on the battery with all that connected.
I'd go with the Bussman as well for a cheaper alternative.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 07:49 PM #4
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Theres absolutely nothing wrong with wiring multiple things directly to the battery, the reason it can become an issue is if you start forgetting which wire is for what and that's why having a fuse block has value. If all of your wires are terminated cleanly and have solid connections it's fine, it just may be a lot harder to troubleshoot or remember how you wired something in the future.
jhguth is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 07:49 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
It’s not a matter of if it’s bad or not… its more about trying to have a tidy distribution setup and a good sturdy connection for anything attached to the battery.
It’s far easier to connect a distribution panel like a Bussman or BlueSea block and have all the accessories connected to that. It will be cleaner and easier to maintain. It also simplifies circuit protection (fusing) and makes it easier to adding and removing circuits.
If you are going to spend the coin on a SPOD or SwitchPro, I would do it all at once. That would be an ideal opportunity to clean everything up.
Old 07-27-2020, 08:36 PM #6
rlporter507 rlporter507 is offline
rlporter507 is on a distinguished road
here's my set up
i dont have much on it yet, just the light bar harness.
Too Many Wiring Terminals on Battery Bad?-20200619_110600-jpg
rlporter507 is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 08:41 AM #7
stay_tuned stay_tuned is offline
stay_tuned will become famous soon enough
not to jack
can someone link to that busman panel? not sure which is the go to
stay_tuned is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 01:42 PM #8
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
You probably have this covered, but you may want to revisit your anytime back/front camera setup to see if the front camera is powered on constantly. If so, maybe you can delete one battery connection. Some generic camera installation instructions direct you to connect to the battery or ignition-on +12V. You really only want the camera powered on when you select it via the Front-Off-Back switch; that’s where you should connect to get the camera power.
Old 07-28-2020, 05:59 PM #9
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
I'm slowly researching the same issue, not that i want to add all the landing and Christmas tree lights that seem to be all the rage and will not require plug and play systems like the spod and such.
Some helpful sites.
POWER TRAYS - Mounting Solutions for Expedition Vehicles – PowerTrays
https://www.waytekwire.com
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 01:05 PM #10
Charlievee's Avatar
Charlievee's Avatar
Thoughts on this setup?
Power Distribution Module
"Pre-Wired Bussmann RTMR Module
This kit includes a pre-wired Bussman RTMR module with 10 fused accessory circuits, 5 of which are relay operated. All wiring is properly terminated and sealed, with automotive grade TXL cross-linked wire used throughout. This wire has a 125C insulation temperature rating and is specifically designed for automotive use where it may come into contact with high temperatures and oil. Generous 10ft pigtails are supplied to reduce splicing and provide the user with enough wire of the correct type to complete the installation.
This kit includes the following:
- Bussmann RTMR Module
- 5 ISO 280 Micro Relays Rated at 35A
- 5 18AWG x 10FT Control Wires For the Relay Circuits
- 5 12AWG x 10FT Relay Output Pigtails (Max Suggested Fuse Rating 30A)
- 5 14AWG x 10FT Fused Output Pigtails (Max Suggested Fuse Rating 15A)"
Old 07-29-2020, 01:26 PM #11
Bumbo's Avatar
Bumbo's Avatar
Looks solid... that is the exact Bussmann RTMR I think many of us were thinking about in this thread.
It's really not that hard to populate the wiring and crimp all this stuff yourself, but it's can be time consuming. That package really isn't that bad for the price.
anytime , bad , battery , lightbars , terminals
No Electricity, New battery, new terminals :( WarpzoneQc 3rd gen T4Rs 8 04-13-2016 08:51 AM
Battery cables and terminals GX4SEVEND 3rd gen T4Rs 3 02-12-2013 03:35 PM
Replace battery terminals? NathanOfSeattle 3rd gen T4Rs 20 01-03-2013 06:01 PM
Battery Cables and terminals GX4SEVEND 3rd gen T4Rs 3 08-17-2011 02:16 PM
Replacing Just Battery Connector Terminals? SgnDen 3rd gen T4Rs 8 06-29-2009 05:39 PM
