Old 07-29-2020, 12:56 AM #1
david05111 david05111 is offline
david05111 will become famous soon enough
What roof rack for Rigid Adapt?
I know, I know. It's ludicrously expensive, but I think I have a line on one for one much cheaper than new from a buddy.
I've been trying to decide what rack would be the best to use with it. The Prinsu one has stood out to me so far, because it looks like it has a half-fairing of sorts that allows the bar to sit almost flush.
I like the gobi racks, but the light bars seem to sit preposterously high on the rack.
Has anyone any recommendations? I'd really like a clean, but practical solution.
PRINSU
Example of another
david05111 is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 03:28 AM #2
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Have you looked at the Sherpa Crestone? This has a better waterproof mounting system then many racks and the side plates follow the roof contour very nicely. 5th Gen 4Runner Roof Rack | 2010-2020 4Runner | Sherpa Equipment Co. — Sherpa Equipment Company
What roof rack for Rigid Adapt?-1cdff03f-ead4-4365-833c-87975f9c4716-jpeg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 01:20 PM #3
That does look nice, and I do have concerns about water leaking into the roof based on threads on the subject on the board. I think that its pretty unacceptable that manufacturers of many racks don't do a better job of figuring out a way to ensure water intrusion is a non-issue.
How does Sherpa address the problem better than others? There's not much information on their site.
Old 07-29-2020, 02:42 PM #4
This may help. Sherpa Equipment Company - 5th Gen
Old 07-29-2020, 05:55 PM #5
Thanks, that's a great link.
I like the Sherpa from what I've seen, though the Prinsu fairing does seem to be a better design for a light bar. It has like L-shaped cutouts at the edges which just makes the Prinsu look like it has a bit of a shorter fairing to bring the lights down a bit.
I'd really like to get a measurement on both to see what kind of dimensional differences there are.
I'ts not that important, because the design of the Adapt bar seems to place the important "light" portion toward the top of the bar; the lower bit is non-functional and could sit behind the down behind the fairing and closer to the roof line.
Old 07-30-2020, 08:07 PM #6
Anyone else have input?
Old 07-31-2020, 01:23 AM #7
IMO prinsu style looks best especially with lighting. The Sherpa rack looks killer, i like their mounts. SSO also has a similar style rack. lot of guys don't like the "erector set" style of the racks but its your taste that matters.
Old 07-31-2020, 02:43 PM #8
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
paid $1700 for my 40" adapt , ended up putting it on my raptor. wires so thick i can't run them down the side of the 4runner.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 12:38 AM #9
Interesting, hadn't heard of that issue. Did you consider running it down the back or anything as an alternate or is there just not enough cable?
That does make give me some pause. I had never considered that to be an issue.
Old 08-02-2020, 08:26 PM #10
rayofsi's Avatar
rayofsi's Avatar
the 2 power wires are 8 gauge.. i bought some 46 amp delphi metripack connectors good for 10ga wires... wouldn't fit in there..
the light also comes unterminated, so your choice of connectors.
Old 08-02-2020, 09:54 PM #11
drill a hole in your roof, marine grade grommet, done.
line , prinsu , rack , sit , sorts
Rigid Adapt Lights Hook 'Em Horns! 5th gen T4Rs 37 03-06-2020 12:21 PM
RIGID Adapt E-Series Cutting-Edge Technology TotalAutomotiveLV Total Automotive Performance 0 10-28-2019 05:40 PM
FS: Rigid E2 40" and 4th gen Whitson roof rack - Tuscaloosa, AL - prices listed philskeeter For Sale: T4R Items 21 09-18-2015 10:00 AM
Finally, Gobi Roof Rack Installed with Rigid LED Balcs1 5th gen T4Rs 33 05-28-2012 07:45 PM
Rigid LED's on my Gobi Roof Rack Performance Report? Balcs1 5th gen T4Rs 30 01-21-2012 07:51 PM
