Old 09-14-2021, 12:05 PM #136
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
Originally Posted by Jrunr View Post
Are there anymore updates from those of you running the Gen2’s? Anymore issues? I am contemplating getting these and was also wondering about the high-beam performance? Do they have good range/distance? Are they bright enough?
From a few of the pics, it looks like the new Gen2’s even eliminate the need for fog light upgrades…
Lastly, are there any other options out there that put as much, or more, light on the road as these?
So far so good. Huge improvement over gen1
amir_gh is offline   Reply With QuoteReply With Quote
Old 10-08-2021, 10:29 PM #137
Punctual Punctual is offline
Punctual is on a distinguished road
Anybody..
Anybody have issues with their drl’s randomly cycling on for a few seconds even when the car is off and parked?
Morimoto says to tap into the EFI fuse in the engine bay, but that causes random drl’s cycling for me.
This is on a 2021 trd pro.
I’m wondering if tapping into the acc fuse box inside the truck would stop this?
Anybody resolved this?
Punctual is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 09:29 PM #138
D4Krunner's Avatar
D4Krunner D4Krunner is offline
D4Krunner is on a distinguished road
D4Krunner's Avatar
Adding to the gen 2 failures. 1 month and drl LEDs are going out which I believe may be causing a random hyper flash issue while signaling.
Gen 2 Xb headlights is out already!!!-0db1fceb-6d65-42b2-aa12-76f7c2ffe80b-jpg
D4Krunner is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 10:10 PM #139
Anonymous4Runner Anonymous4Runner is offline
Anonymous4Runner is on a distinguished road
Makes no sense, TBH. Did you not order the add-on to counter hyperflashing issues at time of ordering headlights? Did you do the install yourself or have someone else do the install?
Anonymous4Runner is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 11:00 PM #140
D4Krunner's Avatar
D4Krunner's Avatar
It’s simple plug and play no add on needed. It’s a bad headlight with bad LEDs. I just hope this is a one time thing and it doesn’t happen with my replacement.
Old 10-20-2021, 01:54 AM #141
Jrunr Jrunr is offline
Jrunr will become famous soon enough
Question
On your 2021 TRD Pro, how is the light output compared to the stock Bi-LEDs in both low beam and high beam performance?
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 11:26 AM #142
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
I just thought of something - why not wire up the 4Runner headlights the way the way my Range Rover operates:
- Both have adaptive hi beams
- Both have projector driving beams and halogen/reflector hi beams next to them
I was in the Range Rover the other day and was checking out what exactly happens when I pull the high beam stalk.
- Not only do the inner reflector/halogen beams illuminate for the dedicated high beams, but there is an “eyelid” in the projector beam that raises the cutoff of the driving beams to make it run wide open.
This “have your beams and shine them, too” approach sounds wonderful if it can be achieved while staying within power limitations of the wiring harness. I imagine this would mean buying those LED DRL’s from Xenon Depot and splicing over either:
1.) The wires for the high beams directly to the DRLs, to parallel those when the hi beams are triggered, or
2.) If the above would cause issues, splice a trigger off the hi beams and let it control a dedicated power supply to the new DRL hi beams.
Could this work?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 06:55 PM #143
ubertoyotax's Avatar
ubertoyotax ubertoyotax is offline
ubertoyotax is on a distinguished road
Those look slick
2018 T4R ORP
ubertoyotax is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 09:30 PM #144
Could this work?
I’m sure it could work but we would need to run a separate relay to power the 9005 bulb, and the wiring diagram so I know which while to tap into for the high beam trigger…. Then we would have to figure out how to manage the DRLs…
2021 TRD Pro, MGM
Old 10-21-2021, 12:25 AM #145
MENU > OFF
Gen 2 Xb headlights is out already!!!Gen 2 Xb headlights is out already!!!Gen 2 Xb headlights is out already!!!
Old 10-21-2021, 05:28 AM #146
MENU > OFF
Lol. Yeah, I always seem to forget we can do that!
2021 TRD Pro, MGM
Old 10-24-2021, 02:20 PM #147
Who'd you order the headlightss from? Either way, it's covered by warranty. It sounds like you did the install yourself. I suppose it's a bit of a hassle having to swap out, waiting and installing new replacement headlights but could be worse if you didn't know how or have tools/space to do the work
Old 10-25-2021, 06:45 AM #148
Low beams are about the same if inconsequentially better, you don’t have that little dead spot hole and there is a more defined cut off.
High beams are much better.
Old 10-26-2021, 05:26 PM #149
Do you have any pics of the high beams on the road?
2021 TRD Pro, MGM
Old 10-27-2021, 12:42 PM #150
Ironman4x4America Ironman4x4America is offline
Ironman4x4America is on a distinguished road
On our 5th Gen TRD Pro. Had zero issues since install December 2020.
Gen 2 Xb headlights is out already!!!-greg_front_bdr_gas-station_1500x1000-jpg
Ironman4x4America is offline   Reply With QuoteReply With Quote
bought , fuse , gen , stick , thoese
DIY: TE Headlights, Black Headlights (BHLM) Jesse1983 5th gen T4Rs 39 02-14-2019 09:29 AM
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
GX470 headlights=4Runner headlights? ssmumich00 Engines / Suspension / Wheels / Tires / Audio / Accessories 17 10-18-2013 06:54 PM
tacoma headlights = 4runner headlights calithirteen 3rd gen T4Rs 6 06-26-2013 05:09 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
