Old 07-31-2020, 11:45 AM #1
clarksky clarksky is offline
clarksky is on a distinguished road
Wanted: Fishing Rod Storage Solution
Does anyone have a creative and secure solution for storing and transporting fully-assembled fly rods?
clarksky is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 12:25 PM #2
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
Following.
I haven't set mine up yet but I've seen guys have mounts on the inside roof but I'm sure your fly rod is like mine and is longer than the inside of the 4runner. Ive seen some guys lock it into their yakima snowboard/ski racks. But those are the only options I've seen. Hopefully someone else has a good solution.
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 01:03 PM #3
Bossman's Avatar
Bossman Bossman is online now
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Interior Overhead Fishing Rod Holder
Fishing poles?? Inside storage
Cargo area roof hook? (Fishing Rod Holder)
Fishing pole holder.
My coat hook mod fishing rod holder
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is online now   Reply With QuoteReply With Quote
Old 07-31-2020, 02:48 PM #4
slowveloce slowveloce is offline
slowveloce is on a distinguished road
I saw a ton of the river quivers or Thule Rod Vaults a few weeks ago in Steamboat. Honestly I had never seen one before that trip. Depends on what rod I'm using if it "fits" or not. Right now its a 4wt or a Tenkara. I would think that you would need to be fishing a lot to have it strung up and hanging on your 4Runner all the time, and I fish 3-5 days a week.
slowveloce is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 03:02 PM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
What he says ^^^. You can also bend it from the back to the front passenger floor assuming you have no passenger and it's not too long. Seen that done a bunch. I have a 4 piece recon that has a metal tube.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 05:43 PM #6
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
Poles are secured with cable thru spinner bale or between spool and bar on a conventional with a lock.
Wanted: Fishing Rod Storage Solution-7b4b6deb-3c62-4ec3-872b-8b257cf85845-jpg
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 05:46 PM #7
Pic with poles
Wanted: Fishing Rod Storage Solution-d8403df6-5c7e-4d92-9861-ea03e7390c3b-jpg  Wanted: Fishing Rod Storage Solution-29a13168-36b5-43a3-927d-43eba38f5efe-jpg
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
Old 07-31-2020, 05:49 PM #8
LOCKING UP YOUR GEAR
With petty theft getting worse, I now keep my stuff locked up, even when running into a tackle shop for bait or a place to grab takeout food, when fishing at places where I’m well away from the vehicle, going in for a meal, etc. AND I take my stuff in at night. I know, a PITA, but seems necessary today.
I use plastic coated cable with a loop swaged at each end. One cable for each rod. One end of the cable is looped to the rod rack, and the other end is passed around the mount shaft and thru the bail of a spinner or around the base and between the spool and a side brace on a conventional. Swages had to be flattened a little more than usual to accommodate some conventionals.
Then the end of the cable is locked to the rod rack with just enough slack that it puts no tension on the rod/reel, which can move up maybe ¼ inch in the rod holder. This keeps at least one set of the circle screw rings for the reel mount down inside the rod holder so a reel cannot be easily removed from a rod and just the rod taken. It also keeps the rod/reel from bouncing up in the holder as an added benefit. I use a set of locks that has a single key, so only one key for all 20 rod holders. And one rod/reel can be removed from its holder with the rest of the rods locked in place.
My coolers are locked to the racks with a cable thru a handle and each cooler has a cable that is looped to the rack that goes over the top of the cooler and is locked to the rack with enough tension to keep the lid from being opened. This top cable also makes it even more difficult to take a cooler off the rack. Same keyed lock set used for coolers.
All the cables used are flexible enough to lock rods/reels as I’ve described but tough enough that pliers type wire cutters would take some time to cut a cable. Thus the quick snatch/go thief is not a problem unless they come with the “JAWS of LIFE” so to speak.
My front and rear racks are locked onto my vehicle with receiver pin locks. With the newer easy on/off rack mounts, it’s just a matter of time before a whole rig (rack, cooler, rods) disappears.
Call me paranoid but I’ve never lost anything since having a couple of rods disappear off my vehicle some years ago on Pea island during the day, with me on the beach over the dune and the vehicle parked on NC12 shoulder out of my sight.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
Old 07-31-2020, 08:42 PM #9
kinnakeettom kinnakeettom is offline
kinnakeettom is on a distinguished road
think he's talking about fly rods with reels attached the are far too delicate to drop in a surf rack and you don't have much sticking below the reel anyway .
Mine are broken down and stored in my truck will look for a photo.
Wanted: Fishing Rod Storage Solution-p4036120-jpg
GT Double E
kinnakeettom is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 05:36 PM #10
The rod vaults on the roof rack are pretty sweet, but I don't get to fish enough to justify one. Personally, most of the fishing is done in brief stops on my way home from work, and I was hoping for a neat, clean way to transport a fully-assembled rig to have at the ready. Straps suspended from the overhead hooks may be easiest way to go, but it feels like there is room for improvement. I do have a molle panel isntalled over the rear passenger-side window, and I've looked for ways to incorporate it but have yet to figure out anything suitable.
Old 08-02-2020, 05:37 PM #11
wow. just, wow
Old 08-02-2020, 05:46 PM #12
next time I come down to Padre I'll call and let you look at them as I pass thru Houston on the way down . I can break it down and have it on a table in the garage in 15 mins so its easy to take out
GT Double E
Old 09-20-2020, 08:41 PM #13
update
i've used the molle panel in the back window to secure the rod handle and a strap to support the rod itself.
Wanted: Fishing Rod Storage Solution-image-1-jpeg  Wanted: Fishing Rod Storage Solution-image-jpeg
Old 09-21-2020, 08:56 AM #14
only problem with your set up is the rod blocks the doors when you have another person riding with you. I'm trading for a land cruiser and going to have to build a new set up in the shop this winter
GT Double E
Old 04-25-2021, 09:29 PM #15
redneckcrawler's Avatar
redneckcrawler redneckcrawler is offline
redneckcrawler will become famous soon enough
I built one using a 6" conduit carrier kit and a 6" piece of pvc. I think its 8' long. I just throw it up on the roof rack and go.
Example
Wanted: Fishing Rod Storage Solution-cc400_45-jpg
redneckcrawler is offline   Reply With QuoteReply With Quote
fly , fully-assembled , solution , transporting , wanted
Inside Rooftop Fishing Rod Storage thebrandon 3rd gen T4Rs 10 03-17-2019 10:13 PM
Fishing poles?? Inside storage Bodhi327 5th gen T4Rs 14 11-26-2018 01:42 PM
Fishing Rod storage solution arizona4runner 3rd gen T4Rs 9 11-25-2017 05:59 PM
Storage solution volkinator General Discussions 6 11-05-2015 02:57 PM
Let's see your fishing rod/gear storage! NC4runAR Off Topic 9 04-11-2014 07:24 PM
