Old 12-14-2020, 11:29 PM #76
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
Originally Posted by daytonaviolet View Post
How much slower ?
My passenger mirror completes it's fold two whole seconds before the drivers does. I can confirm that it is NOT a friction issue as I've disassembled the drivers mirror and ran it standalone... still slow.
Sorry for late reply. I deleted the older diy. Rev3 is the current one.
CTH Folding Mirrors DIY Rev3.pdf - Google Drive
Thanks for the updated PDF! I did end up figuring things out, it just took a while.
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 11:31 PM #77
smeerun's Avatar
smeerun's Avatar
Originally Posted by LakeRunr View Post
The other thing I would check is the voltage across the pair of wires for each mirror while it's moving...to see if the voltage is the same on both sides of the vehicle.
Good call. Just the 1millionth reason I need to pick up a multimeter...
Old 12-15-2020, 03:25 AM #78
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Contact sevag via messenger and he will setup a group chat. Let’s see the slow mirror fold. Hopefully he can send you another motor to try.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 11:27 AM #79
smeerun's Avatar
smeerun's Avatar
Good call. I PM'd you because I don't have Facebook and need help finding Sevag on messenger.
I'll record a video showing the slow mirror today.
Old 12-15-2020, 05:27 PM #80
smeerun's Avatar
smeerun's Avatar
Shot a video demonstrating the slow open and close of the drivers mirror. As stated in the video, I currently only have the 12V power connected so the mirrors are controlled solely by the included button. I don't think it'd make a difference to tap into the lock/unlock as the toggle...
Old 12-15-2020, 08:04 PM #81
LakeRunr's Avatar
LakeRunr LakeRunr is offline
LakeRunr has a spectacular aura about LakeRunr has a spectacular aura about
LakeRunr's Avatar
Smee, tapping into the lock/unlock circuit won't make a difference in opening speed. Looking at the video, both mirrors appear to swing at the same degrees-per-second (but can't tell scientifically). I'm thinking that the total arc of the passenger side mirror is less than the total arc of the driver's side mirror. Can you measure that?
Edit: I think that's exactly what's going on. I couldn't stand not knowing (and my kit just arrived today), so I went out and measured. When unfolded, the passenger mirror is at least 3.5 cm closer to the passenger door window than the driver's mirror is to the driver's door window. This makes sense, because the angle needed to see correctly in the passenger mirror is less (far edge closer to the car) than the angle needed for the driver's mirror.
Conclusion: I think the speed is the same, it's the duration that's different, and that's because the driver's mirror has more distance (arc) to travel.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
LakeRunr is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 08:55 PM #82
Smerdinian Smerdinian is offline
Smerdinian is on a distinguished road
I’m here guys, but it’s touch to TS in here and follow, I have 80+ messages a day, only on messenger. So if you need anything, contact me on messenger ...
Or join the group Toyota 4Runner
Smerdinian is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 11:14 PM #83
DaveyTN DaveyTN is offline
DaveyTN is on a distinguished road
My wife drives a GX460 (which is similar to the Toyota 4Runner in several ways), and I can confirm that the passenger mirror closes before the driver's mirror. I too agree that the driver's mirror on the GX has more arc to travel. Hope that helps.
DaveyTN is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 11:47 PM #84
smeerun's Avatar
smeerun's Avatar
Okay this all makes MUCH more sense now. I'm not at all worried about it and @LakeRunr , you're totally right... the mirrors are swinging at the same degrees-per-second and even the sound of the motors are at the same "bzzzzzz" tone. I never realized that the mirrors are set at a different distance/angle.
Been enjoying the folding mirrors!
Old 12-26-2020, 11:37 PM #85
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
Thought I would share my install experience as I just wrapped up tonight. Overall the install is not bad but I did break out the soldering gun (my kit did not come with "Vampire" clips for splicing into the factory wires (x3) and I am not a huge fan of using them anyhow so I solder those connections and then replaced the in door connector (x4) to the mirrors with my own as they were a bit sketchy.
Over all the DIY instructions were excellent - my two sticking points in the install were separating the factory wiring connector - first step in part two and then fishing the wires through the door grommet. Both were doable but the only time were it took multiple attempts
Only time will tell how long they last. I got a very odd e-mail from CTH from someone claiming to be employed by them and urging me to cancel the order saying they are known to be defective products and fail after a couple months - it was strange, needless to say I didn't cancel and will just see how long they last.
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 02:30 AM #86
Folding Mirror kit - anyone try this yet?
I would ignore that email as cth was hacked. That guy was sending emails to recent customers while asking for ransom.
Old 12-27-2020, 08:55 PM #87
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Any tips for separating the factory connector? I've seen several people mention that it was a pain
Old 12-27-2020, 11:33 PM #88
Engineer's Avatar
Real Name: Charles
Engineer's Avatar
Real Name: Charles
Best bet is a second person as you need two hands to push in both clips that are holding the inner connector in (one on each side) one uses a small flat head screw driver the other I used small Phillips. but you need a third hand or in my case a screw driver against my stomach to allow you to push the inner clip out go the housing - I don't suggest pulling by the wires but I guess thats always an option
Old 12-28-2020, 11:28 AM #89
PCRIDE4RUNNERORG PCRIDE4RUNNERORG is offline
PCRIDE4RUNNERORG is on a distinguished road
I did the install today. It went really smooth.
CTH folding mirrors - YouTube
Very nice install! Good job. Do you have aftermarket lights in the mirrors? What LED's are you using? Its very bright and something I could add to mine.
PCRIDE4RUNNERORG is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 12:28 AM #90
Following thread. I also ordered a pair today.
cth , folding , installed , kit , mirror , mirrors , sevag
Driver's side folding mirror repair? GPsevinSixx 3rd gen T4Rs 7 07-09-2020 07:42 PM
Off Market Auto Mirror Folding System? cherrywanzi 5th gen T4Rs 8 12-30-2013 07:45 PM
Limited with 3rd Row. Folding 2nd row? MpJustice 5th gen T4Rs 6 03-09-2013 09:54 AM
Power Folding Mirror? flyrv9 5th gen T4Rs 1 02-18-2013 01:25 AM
4th Gen Power-folding Mirror Question Duncan 4th Gen T4Rs 5 06-28-2012 04:44 AM
