08-02-2020, 07:27 PM
#16
Originally Posted by dipNrip
The filter only needs hand tightened. I check with torque wrench but never moves after I hand tighten.
you can hand tighten it fully? over the o-ring on the housing? I think I need to see pics of your forearms, mr. hercules, cause thats some grip strength.
4RUNHER Owner: October 2014-October 2020
SOLD 2010 MGM TE w/ KDSS SOLD
Consolidated Slider Info Thread :: 5th Gen Features/Models/Differences :: New member? Please read this.
08-02-2020, 07:52 PM
#17
Originally Posted by jahdai42
Definitely going to try this tomorrow when I'm not so pissed.
Haha good advice, I almost always regret when I don't follow it myself.
08-02-2020, 07:53 PM
#18
Real Name: Eric
Real Name: Eric
Originally Posted by yota1976
Is it hard to replace the factory plastic housing for an aluminum one? I might upgrade to that later.
Very easy. For details, see this article that I wrote:
Metal Oil Filter Housing Upgrade + Motivx Tools Oil Filter Wrench
08-02-2020, 08:25 PM
#19
It’s only 18 ft-lb. I don’t even try to get it as tight as possible. Just lube up the o ring real good and go until it’s tight. I only double check with torque wrench to make sure it the whole way on.
On the oil filter I’d recommend the Toyota one. I’ve had issues with the Doman brand in general. Only thing you need to do is bend the tabs on the center post inside the housing and transfer it to the new one.
08-02-2020, 08:33 PM
#20
You built like a 12 year old girl?
08-03-2020, 08:51 AM
#21
mine gets too tight to continue by hand without some serious fight so I just start it by hand and then finish it with a tool after it hits the o-ring. My skids dont give me a whole lot of room to fight with the filter so why not use the tool? I always finish with the torque wrench and it tightens down a little before clicking for me.
*back to the OP, theres been times when I had to take a large screwdriver and drive it through a metal canister style oil filter because it was overtightened. Idk how that would work with this type of housing, it might just splinter on you and you need to be able to get the plastic threads out, without carefully cutting them with a dremel. let us know what you come up with OP.
08-03-2020, 10:49 AM
#22
I’m calling BS as well. There’s no f’ing way you can torque anything to 216 inch lbs aka 18 foot lbs with your hands. Nope.
#23
Originally Posted by ElectroBoy
This. Hit the threads with penetrant. But before attacking with a dremel, first try a persuader.
Get large channel lock pliers or a pipe wrench. Pull slowly, the rubber gasket was probably not lubed before installation and it binds. If the cover breaks apart, use the dremel.
thanks again, worked like a charm. I threaded 36" of black iron pipe on the end and boom. Replaced with the Dorman metal cap.
2016 Trail,
08-03-2020, 10:59 AM
#24
Keep an eye on the dorman, plenty of reports here it doesn't seal like the factory aluminum one does.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
08-03-2020, 05:34 PM
#25
Banned
Real Name: Mark
Banned
Real Name: Mark
Originally Posted by jrandom
Just make sure the center tube is the right length, I am pretty sure the part number listed here on the forums has a center tube that is too long, mine was. It is super easy to swap from your old plastic housing.
I believe it’s just the reverse. The plastic Toyota 4R filter housing has a long center tube while the Toyota aluminum one, which fits other models, is shorter. You’ll verify this when you see them side by side.
08-03-2020, 08:40 PM
#26
Thanks for the sanity check, fixed. yeah couldn’t remember exactly, it has been years since I changed it out, I just know it’s wasn’t straight across swap.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
08-04-2020, 03:33 AM
#27
A 27mm Craftsman wrench works well with the MotivX oil filter wrench instead of a socket and breaker bar. Assuming you have the skid plate off. It's ~14.5" long.
08-04-2020, 07:56 AM
#28
This Assenmacher wrench fits completely over the tabs and on the notches.
Its a good design and not some cheap crap made in China that's funding the Red Army like so many wrenches I see people here using that 'eff up the filter housing.
Assenmacher Tool of Boulder, Colorado Toyota Filter Wrench
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
08-04-2020, 09:20 AM
#29
I also hand tighten mine. Go until the tab lines up. It's quite easy.
I had mine stuck, the tabs ripped off, and the entire thing tore apart as I tried everything to remove it. The threaded part remained.
In the end, I spent hours with an old soldering iron, melting away at the threaded part so that I wouldn't jack the threads up on the metal part of the engine that receives it.
It was a total nightmare. As you can see in the photo.
Now I have a metal housing, I hand tighten, and I have had no issues
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
08-04-2020, 01:05 PM
#30
Fun day there
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
