Old 08-05-2020, 03:32 AM #31
ElectroBoy's Avatar
Real Name: Mark
ElectroBoy has much to be proud of ElectroBoy has much to be proud of ElectroBoy has much to be proud of ElectroBoy has much to be proud of ElectroBoy has much to be proud of ElectroBoy has much to be proud of ElectroBoy has much to be proud of ElectroBoy has much to be proud of
ElectroBoy's Avatar
Real Name: Mark
Originally Posted by nb rob View Post
I also hand tighten mine. Go until the tab lines up. It's quite easy.
I had mine stuck, the tabs ripped off, and the entire thing tore apart as I tried everything to remove it. The threaded part remained.
In the end, I spent hours with an old soldering iron, melting away at the threaded part so that I wouldn't jack the threads up on the metal part of the engine that receives it.
It was a total nightmare. As you can see in the photo.
Now I have a metal housing, I hand tighten, and I have had no issues
You are a real trooper. I salute you.
1st Gen 1987 T4R, sold at 180K miles
3rd Gen 2000 SR5, sold at 239K miles
5th Gen 2018 ORP, just interior mods
Old 08-05-2020, 08:28 AM #32
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a jewel in the rough patkelly4370 is a jewel in the rough patkelly4370 is a jewel in the rough
And just think. If the tabs on a metal one broke you'd never be able to melt off those same chunks.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 12:23 PM #33
TheNicestGuy24 TheNicestGuy24 is offline
TheNicestGuy24 is on a distinguished road
Originally Posted by 57HotrodVW View Post
Get yourself a Toyota specific filter wrench from Motivx Tools. They work great, and "grab" both the ears on the housing, and the flutes.
That, plus a 27mm socket to turn the filter wrench, and a breaker bar or "cheater" (pipe over a ratchet handle) will take care of tight filter housings.
Read all about it in this article:
Metal Oil Filter Housing Upgrade + Motivx Tools Oil Filter Wrench
Just a tip from experience, I have the Motivx wrench, it is a great tool and every Toyota owner needs it that does oil changes.
However, even with this tool you can still break the plastic tabs off of the housing if it was overtightened the last time it was put on. I personally snapped one of the tabs off my Camry housing with this tool. That is when I swapped to OEM aluminum.
Not blaming the tool for snapping the housing, it was definitely due to previous overtightening, just letting you know that this tool also won't prevent you from breaking tabs in this scenario.
2011 SR5
2011 Camry
TheNicestGuy24 is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 02:17 PM #34
DougR DougR is offline
DougR is on a distinguished road
Professional Advice from Charlie's Foreign Car Service
Damaged Oil Filter Housing On Toyota and Lexus - YouTube
DougR is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 05:07 PM #35
N6WRV N6WRV is offline
N6WRV is on a distinguished road
The Motivx oil filter drain tool is also a good idea. Not as messy as that throwaway plastic thing.
Oil Filter Drain Tool for Toyota, Lexus, Scion 2.0L - 5.7L Engines - Motivx Tools
2015 4Runner Limited with X-REAS Sport Enhancement Suspension, 37qt ARB fridge wired directly to battery with ARB Wiring Kit.
N6WRV is offline   Reply With QuoteReply With Quote
filter , impact , remove , tabs , tool
Oil Filter Housing Mack1611 5th gen T4Rs 10 05-31-2019 09:20 AM
WTB - 4TH GEN 06 V8 air Filter Housing groove4u Want to Buy/Trade 5 03-15-2016 06:31 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Where to buy new oil filter housing sandwich 5th gen T4Rs 3 06-23-2011 02:08 PM
oil leak on oil filter housing. dustyDtard Problems & Warranty Issues 6 03-29-2006 01:24 PM
