Old 08-06-2020, 04:07 PM #16
N6WRV N6WRV is offline
N6WRV is on a distinguished road
Been runnning these in rear rear turn signals for 1-1/2 years now. They work fine and cost about half the price of Lasfit.
OXILAM 7440 LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free T20 7440NA 7441 W21W WY21W Blinker Bulb Replacement (2PCS)
by OXILAM
Amazon.com: OXILAM 7440 LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free T20 7440NA 7441 W21W WY21W Blinker Bulb Replacement (2PCS): Automotive
2015 4Runner Limited with X-REAS Sport Enhancement Suspension, 37qt ARB fridge wired directly to battery with ARB Wiring Kit.
N6WRV is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 04:45 PM #17
These dual-element bulbs will fit the front turn signals on a 5th gen 4Runner.
SIRIUSLED RLS 7443 7444 Built In Resistor Canbus Anti Hyper Flashing Error LED Turn Signal Light Bulb with Full Aluminum Body Dual Filament Smart Driver Amber Orange Color Pack of 2
by SIR IUS LED
Amazon.com: SIRIUSLED RLS 7443 7444 Built In Resistor Canbus Anti Hyper Flashing Error LED Turn Signal Light Bulb with Full Aluminum Body Dual Filament Smart Driver Amber Orange Color Pack of 2: Automotive
Old 08-06-2020, 05:15 PM #18
Six_Actual's Avatar
Six_Actual Six_Actual is offline
Real Name: AJ
Six_Actual will become famous soon enough
Six_Actual's Avatar
Real Name: AJ
Adding this to the list of subtle mods that make the vehicle look better and perform better (Safety in this case). I'll be coming back here when its time. Just need a good reason to pull the bumper, because as of right now, this isn't it just by itself.
Six_Actual is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 04:43 PM #19
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Well... I messed up in the video. Turns out you don't have to pull the bumper. You can access these bulbs via the wheel well liner. It wouldn't have made an interesting video, but it would have been a ton easier.
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 08:50 AM #20
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
On the bright side you didn't scratch your arms up reaching in there.
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 10:43 AM #21
007Tacoma's Avatar
007Tacoma's Avatar
LOL - not this time at least.
I'm 007Tacoma.
Old 08-19-2020, 12:13 PM #22
zw470's Avatar
zw470 zw470 is offline
zw470 has a spectacular aura about zw470 has a spectacular aura about zw470 has a spectacular aura about
zw470's Avatar
Can anyone confirm that we need Standard and not CK sockets?
zw470 is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 09:41 AM #23
007Tacoma's Avatar
007Tacoma's Avatar
Thumbs up Not CK Bulbs - Toyota does not use CK Bulbs (that I'm aware of)
That's a great question! I had forgotten all about CK Bulbs!!! CK Bulbs have the same base, but the grounds and positive lines are in different positions. If these had been the wrong type, the ground would have shorted out the circuit and blown the fuse. I know that Chevrolet and Chrysler use 7444NA - which is a CK Bulb. However, the 4Runner does not use CK Bulbs.
Also, I can confirm that these are the correct bulbs for the 4Runner front turn signals as I used these in the video...
LASFIT 7443 - Dual Color Switchback LED Amber Turn Signal Blinker Bulbs
Amazon.com: LASFIT CANBUS Anti Hyper Flash 7443 7444 T20 Dual Color Switchback LED Amber Turn Signal Light Blinker Bulbs, White Daytime Running Parking Light, No Load Resistor Need, Standard Socket (Pack of 2): Automotive
LASFIT 7440 - LED Turn Signal Blinker Bulbs
Amazon.com: LASFIT 7440 Anti Hyper Flash Canbus LED Turn Signal Light W21W WY21W Blinker Bulbs, No Load Resistor Need, Upgraded Intelligent Temperature Control Version- Amber Yellow (Pack of 2): Automotive
I'm 007Tacoma.
Old 08-20-2020, 09:46 AM #24
utctscanr75's Avatar
utctscanr75 utctscanr75 is offline
Real Name: Bird Dog Overland
utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light
I put these in my new Alpharex Luxx headlights when swapping from stock. They work great.
utctscanr75 is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 01:41 PM #25
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Originally Posted by ElectroBoy View Post
There are resistors built into these bulbs so they look like incandescents to the dumb flasher and there’s no hyperflash. LASFIT erroneously calls them “Canbus”. Since these bulbs are driven so hard to get them so bright they will get hot with extended use, like 10 minutes or so on a hot summer day. There’s also some type of built-in thermal switch that opens up to protect the resistors in this case (they are physically small and can only dissipate so much heat even with aluminum heat sinking). When that happens you will hyperflash but when turning off the blinkers for a short time, maybe 30 seconds, the switch resets and all is well. I’ve had mine over a year and the only time I could get them to hyperflash was by leaving the emergency flashers on for about 20 minutes.
If they are switchbacks, would they also overheat from just being on for an extended period of time? Or is the white led not driven so hard?
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 03:12 PM #26
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
I don’t know, but this statement is on their site for the switchbacks. It probably pertains to 4Runners also. I wouldn’t use them. It’s just for show for other drivers, who cares?
“ This product doesn't fit Honda Pilot. And will hyper flash on Jeep Grand Cherokee, 2016-2017 Toyota RAV4, 2020 Toyota Tacoma, 2018-2019 Toyota Tundra, 2018-2019 Crosstrek, 2019 Forester. Please don't buy this product if you want to replace the turn signal for these vehicle.”
Old 08-21-2020, 01:47 PM #27
007Tacoma's Avatar
007Tacoma's Avatar
This probably has to do with the depth of the bulb in the housing for those vehicles. These bulbs are significantly taller than the incandescent bulbs... but the 4Runner has gobs of room in the housing.
I'm 007Tacoma.
Old 08-21-2020, 03:24 PM #28
3RDGENGuy's Avatar
3RDGENGuy 3RDGENGuy is offline
Real Name: Matt
3RDGENGuy is on a distinguished road
3RDGENGuy's Avatar
Real Name: Matt
I bought las fit turn signal bulbs with the built in resistors and the drivers side went dead after 1 week !! I’m glad I didn’t convert everything to las fit led. I bought for the rears and didn’t even open them and returned them.
3RDGENGuy is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 08:55 PM #29
Banned
Real Name: Mark
Banned
Real Name: Mark
That happens sometimes to consumer electronic parts. Unless you want to pay for X-ray inspection, post-manufacturing test, component burn-in, environmental test, temperature cycling, and post environmental test like the military does to weed out weak parts, you’re gonna occasionally get some failures.
LASFIT has a 1 year replacement guarantee. Use it.
Old 08-21-2020, 10:38 PM #30
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
I’m good would rather have oem quality over junk
4runner , bulbs , led , signals , turn
FS: Lasfit 7440 Amber Turn Signal Bulbs - $40 - Pittsburgh, PA 97BlackAckCL For Sale: T4R Items 0 05-21-2020 11:40 AM
FS: 5th Gen Lasfit front turn signals. Canbus no Hyperflash no resistor Bayonne Nj 0 skillzo1 For Sale: T4R Items 1 04-05-2020 10:29 AM
FS:5th Gen- Lasfit/ExtremeLED/Proclip-Atlanta, GA mag4rnr For Sale: T4R Items 14 02-17-2020 09:35 PM
One touch turnsignals? can it be done? dedonderosa 5th gen T4Rs 13 04-25-2017 04:46 PM
Tint/cover for turnsignals emsmatt 5th gen T4Rs 3 03-20-2011 04:59 PM
