Old 01-19-2021, 10:30 AM #46
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Originally Posted by Akkording View Post
"Amber is the color of your energy"
I got that reference!!!
Woah...
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 10:53 AM #47
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Woah...
then you UB40 ish now
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 09:11 PM #48
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Well...I'm back with a new issue.
Installed the new lights, loved them. Was driving today and all of a sudden I got a hyperflash. Got home and the front right flasher wont work but it works for a parking light.
Everything was working as it should but now it doesn't.
Thoughts?
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 04:18 AM #49
Lazywildcat01 Lazywildcat01 is offline
Lazywildcat01 is on a distinguished road
I just installed the front and rear turn signals last week and they are super bright and I have been momentarily dazed if I happen to be staring right at it when unlocking from the rear lol
I had some issues with install of the rear that I had to remove the whole tail light assembly to fit the bulb in. There just wasn't enough slack to maneuver the longer bulb through. While removing one of the tail light assembly, I cracked some paint where the top of the taillight meets the back panel which was annoying. I will have to touchup paint it now to prevent rust.
Lazywildcat01 is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 04:54 AM #50
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Thoughts?
There’s an open connection somewhere in the bulb high power circuit. Possibilities:
One of the bulb’s pins isn’t making contact with the socket. Is it bent or broken? Maybe it’s not seated well in the socket. You’ll need to get in there and check. Remove it and check the bulb pins. Straighten them out if bent. Check the socket pins if you can see in there to make sure they’re OK and not spread apart too far. Re-install the bulb and try the lights and flashers again. If it still doesn’t work re-install your old OEM bulb to make sure it works in that socket.
(Some of these LED bulbs are long and rather heavy. I worry about them working their way out of the socket with jolts and vibration. So I make sure the socket contacts are snug before inserting the bulb. After testing everything out I add a small dab of a thick adhesive like shoe goo to bridge the bulb body to socket body and hold it in place better. Externally, don’t get any glue in the actual socket where it can get in the pins.)
The other possibility that is the bulb just failed. You can try testing the bulb’s high and low functions on the bench with clip leads and a 9 volt battery or a power supply. Or just return it. There’s a warranty on them, you can contact the vendor for a replacement.
Old 01-21-2021, 02:36 PM #51
Real Name: Doug
Real Name: Doug
Pulled the bulb and connections look okay, didn't have time to throw it on the multimeter but still have hyperflash.
Talking with Lasfit but they are difficult and seem to only be in the office at night (overseas I assume).
My guess is they'll replace it.
Sent from my SM-G986U using Tapatalk
Old 01-22-2021, 11:28 AM #52
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Thoughts?
My Lasfit bulbs would hyperflash randomly when they overheated. It would be sporadic and would stop if I turned the flasher off and then back on usually
Old 01-22-2021, 02:28 PM #53
Real Name: Doug
Real Name: Doug
Talked a bit with Lasfit last night and they tried to initially say "Its because your vehicle isn't compatible with the bulbs." I told him he was crazy and that I have heard of tons of people running them without issue, that in a previous email chain, HE suggested them, and that it was a warranty issue and needed to be replaced. Finally he replied that they would send out a new pair.
Little frustrating but in the end they warrantied their product.
Old 01-26-2021, 12:22 PM #54
007Tacoma's Avatar
007Tacoma's Avatar
Indeed... the hill has been topped off. LOL
I'm 007Tacoma.
Old 01-26-2021, 12:28 PM #55
007Tacoma's Avatar
007Tacoma's Avatar
Yeah... miscommunication and cultural differences can make these exchanges taxing on your patience, but I hope that the replacements get you fixed up.
So far I've had mine in for the past 12,000 miles. I've had no major problems, and I've only see them hyperblink once during a ridiculously long time with the blinker on in hot weather. I also agree with @ElectroBoy - these bulbs are large and heavy. Falling out of the socket is a concern especially on rough terrain.
I'm 007Tacoma.
4runner , bulbs , led , signals , turn
FS: Lasfit 7440 Amber Turn Signal Bulbs - $40 - Pittsburgh, PA 97BlackAckCL For Sale: T4R Items 0 05-21-2020 11:40 AM
FS: 5th Gen Lasfit front turn signals. Canbus no Hyperflash no resistor Bayonne Nj 0 skillzo1 For Sale: T4R Items 1 04-05-2020 10:29 AM
FS:5th Gen- Lasfit/ExtremeLED/Proclip-Atlanta, GA mag4rnr For Sale: T4R Items 14 02-17-2020 09:35 PM
One touch turnsignals? can it be done? dedonderosa 5th gen T4Rs 13 04-25-2017 04:46 PM
Tint/cover for turnsignals emsmatt 5th gen T4Rs 3 03-20-2011 04:59 PM
