Old 08-05-2020, 10:50 PM #16
Anonymous4Runner Anonymous4Runner is offline
Anonymous4Runner is on a distinguished road
Originally Posted by 1000MPH View Post
I got these at Amazon and used the M6x16mm.
Cap screw so I could add a black vinyl cap.
Someone said any longer than stock and you might interfere or scratch your back window when rolled down.
50 PCS Socket Head Cap Screw Assortment Set, M6 x 10mm, 12mm, 16mm, 20mm, and 25mm, Stainless Steel 304, Bright Finish Amazon.com: 50 PCS Socket Head Cap Screw Assortment Set, M6 x 10mm, 12mm, 16mm, 20mm, and 25mm, Stainless Steel 304, Bright Finish: Home Improvement
Yep...idiot salesman who I worked with to finalize the purchase put on wrong screws when he put in temp. tags for me to drive off. It ended up scratching the rear glass few days later. They tried to blame it on me for putting in wrong screws but I explained to them why would I need to replace them if I haven't gotten new tags and temps tags still being the same at time of putting them on by the salesperson?
They ended up covering it out of their pockets without counting it against my factory warranty
Anonymous4Runner is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 05:04 PM #17
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
This is what the backside looks like.
Rear License Plate Screw?-42ee2cf6-5aa9-4567-ad53-3e67353394c8-jpg
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 07:53 PM #18
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Originally Posted by Ogre75 View Post
The liceense plate screws were the first set of "toyota special corrosion resistant hardware" I had to replace when I bought my rig. Snapped the head right off without much torquing. Both were rusted solid. I had to drill them out and put in new ones. So far the trash hardware is my biggest complaint with the 4R. I don't care about the mpg, minimal power, lack of updates, but at least find a supplier that can provide hardware that won't weld itself immediately.
Just picked up a '21 and one front screw was already rusted when I picked it up.
They told me they would get me some, but Toyota dealers are useless.
(First time I am ever using a front plate in a front plate state as they already installed the mount)
Anywho, I picked up some 316 black oxide coated stainless and titanium bolts for the plates and a few jars of Copaslip Molyslip for plate bolts and to go over some bolts on the underside as well.
An ounce of prevention...
'Just have a few days before I can plop the plates in.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 08:00 PM #19
Robberbaron Robberbaron is offline
Robberbaron is on a distinguished road
I dip the screws in axle grease prior to installation. Never had a problem removing them.
Robberbaron is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 08:44 AM #20
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
These guys are OEM suppliers to exotic car manufacturers. I bought one of their stainless steel license plate frames and a set of hardware. It’s all stainless. The fastener kit I bought has bumpers to keep the plate off the paint. All of it is very nice stuff. I used antisieze on the plate screws from day 1.
Choosing the Best License Plate Frame for Your Car — Camisasca Automotive Manufacturing, Inc.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 10:18 AM #21
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
make sure to pull and apply antisieze to all your skid plate blolts too. In fact, anytime I remove a bolt or screw on the exterior of my 4R now, I have my jar of antisieze handy.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 11:39 AM #22
spartacus's Avatar
spartacus's Avatar
Make sure what ever screw you use its the correct length or it will scratch the rear glass.
Old 02-01-2021, 04:51 PM #23
weecho27 weecho27 is offline
weecho27 is on a distinguished road
Originally Posted by LandCruiser View Post
Both my screws were rusted in place and the heads snapped off when I finally removed my CO license plates.
My two cents, FWIW: When you replace your hardware use 316 SST (A4) and not 18-8 (A2) SST especially if you're in the rust belt. The 316 will hold up a little better. Might want to take the extra step and use safety torx head screws for anti-theft. Pro tip- dip the first few threads of the screw in grease before installing them. This will help with the rust and also any galling issues.
weecho27 is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 08:56 PM #24
Yes yes!
Been doing that since I bought my '02.
Maybe once a year, year-and-a-half though.
dealer , license , plate , rear , screw
License Plate Light Screw Size Hokie-Pokie VT 3rd gen T4Rs 0 03-19-2020 01:59 PM
License Plate Screw/Hardware Specs? Tcha1 5th gen T4Rs 2 02-11-2019 11:41 AM
New Funny Custom License Plate, where to buy front license plate mount spoiler900 3rd gen T4Rs 3 01-04-2013 12:57 AM
License Plate Bulb Lens Screw DISINTEGRATED! zerowkul98 4th Gen T4Rs 3 10-07-2012 11:35 AM
License plate screw broke in hole 1strun New Members 0 01-02-2012 03:13 PM
