Old 08-25-2020, 08:22 AM #16
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
I've never seen a spring break like that. And grime and surface rust are a normal part of living in the rust belt. Coil springs don't break from surface rust. MY guess, it was defective to begin with and finally snapped.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 12:33 PM #17
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Originally Posted by jp.vegas View Post
Unless he bought additional coverage, yep.
Originally Posted by honda250xtitan View Post
its 5 years...isnt warranty 3yr/36k mile?
Originally Posted by tls3601 View Post
Seems to me dealer should have replaced spring under warranty.......🙄
I think most of you missed the part where he swapped out the shocks. Accordingly, he kissed that part of his warranty goodbye.
Right. I've never seen a spring break like that either. It was either defective or wasn't seated correctly and ultimately failed.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 01:08 PM #18
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
As others have said, springs don't break like that if they're correctly installed and correctly made.
Luckily replacement spring are cheap, but replacement suspension isn't, and OPs looks like hell after years in the rust belt.
I will bet 20 bucks that the LCAs are rusted in place or no longer enjoy the freedom of movement they did when new.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 12:04 AM #19
Mach0hhh Mach0hhh is offline
Mach0hhh is on a distinguished road
@rustbeltboss may i ask how much did it run you to replace at the dealer. My 15 Pro has the same problem on the driver side. I bought the extended warranty (or so Toyota says) and I’m debating if i should bother trying to see if they will cover it.. would you also be able to provide a part number on the components?
Mach0hhh is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 11:40 PM #20
MoonGoon762 MoonGoon762 is offline
MoonGoon762 is on a distinguished road
Nice time to replace with some Wheelers!
MoonGoon762 is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 11:53 AM #21
eelski eelski is offline
eelski is on a distinguished road
Angry
Yup, Mine is broke too. Driver side spring at the same location.
eelski is offline   Reply With QuoteReply With Quote
broke , car , front , replace , shocks
Broke both front axles and need advice DallasStarsFan 5th gen T4Rs 22 01-16-2020 05:38 PM
Front skid bolts broke brown dog 5th gen T4Rs 12 08-20-2019 05:07 PM
Broke my front CV Axle AKA Half Shaft??? VH3SURF So Cal 7 01-10-2017 07:50 PM
Broke it - Last Day of 2015 Ron4RNevada 5th gen T4Rs 50 02-03-2016 01:37 PM
HELP!!!!! Front Swaybar Nut Weld Broke Inside Frame! SMEE 4th Gen T4Rs 3 12-11-2011 07:16 PM
