08-03-2020, 08:14 PM
2015 TRD Pro - Broke front spring? (broke while parked in garage)
Bought my 4Runner brand new in 2015. Did the recall shortly after purchasing to replace the faulty Bilstein shocks up front that would clunk in the winter, which did seem to fix it. Well today I washed by car, and dried it and parked it. Getting ready to come inside to eat, and heard a loud bang. The front left spring broke? On the lower end of the coil but not the very end. WTF? Anyone see this? The dealer did blow this apart when the car was basically new to replace the shocks and now I only have 30k miles. Oil changes only on this car have barely driven off road. Its babied. Plan on calling dealer tomorrow. Will post pics soon. These are Eibach springs right? Part #s? ugggg
08-03-2020, 08:27 PM
08-03-2020, 09:26 PM
I dont know if it is possible but I wonder if the spring wasn't sitting in the spring bucket correctly. There is usually a lower spot where the end of the spring nests.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
08-04-2020, 08:49 AM
Possible. Other than the fact its been like this for several years now. And broke out of the blue. Very odd and disappointing.
08-04-2020, 08:54 AM
you might want to replace those 5 year old, corroded coilovers. Babied or not
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
08-04-2020, 09:02 AM
I agree with @nb_rob on this one. Your name says it all! The rust belt has struck again. Those coilovers look 15-20 years old with all that corrosion. I agree that those both need replacing anyway. It was time for sure by the look of your pictures. You may not want to hear it, but I don't think it had anything to do with dealer fixing an issue, past problem, etc.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
08-04-2020, 09:38 AM
Fair enough. I did end up getting the underbody rustproofed from new and thankfully most of the metal underneath seems to be holding up OK where coated. Don' recall ever hearing a spring just self destruct.
08-04-2020, 10:34 AM
Those coils don't look that corroded. They look dirty with some surface corrosion, but to recommend a blanket "replace after 5 years" is absurd - although these, of course, need to be replaced.
I'd return these to the manufacturer and have them opine to the cause.
When in trouble - obfuscate
08-04-2020, 12:44 PM
Nobody said a blanket statement that all coilovers should be replaced after 5 years. When i stated "those both need replacing anyway" I was referring to his coils in the shape they are in, no matter if one broke or not. We were both referring to his dirty/rusty coilovers in his pictures. I can say if mine looked like that, and they will one day, I will definitely replace them. But like we said, HIS 5 year old coilovers definitely need replacing... and you said that yourself.
08-04-2020, 01:22 PM
Unusual for sure. IMO - I'd expect at least 10 years of use from the shocks and the springs should last the life of the vehicle. Springs should not ever really sag. Some do and some are not great metallurgy. But it's unusual. The problem with unusual events is that Toyota is going to be skeptical of how it happened.
Random guess after looking closer is a manufacturing defect in the spring. I'd guess it had cracks formed over a long time and finally the metal fatigue and cracks gave way and it broke.
I'd just replace with a new spring and go on. Shouldn't be very expensive.
08-04-2020, 01:36 PM
nobody said all shocks need replacement after 5 years. I mean in spite of this vehicle only having 30,000 miles, they are still 5 years old, and not brand new.
08-24-2020, 02:22 PM
Figured I'd provide an update. Had the front shocks and springs replaced at my local dealer. They were not covered under any warranty. I've been busy with other life things so I just went ahead with the fix using factory parts. Re-aligned as well. Thanks.
08-24-2020, 02:45 PM
Real Name: Tom
Real Name: Tom
Seems to me dealer should have replaced spring under warranty.......🙄
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
08-24-2020, 04:38 PM
its 5 years...isnt warranty 3yr/36k mile?
08-24-2020, 04:54 PM
Unless he bought additional coverage, yep.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
