Old 08-03-2020, 09:44 PM #1
skag1T skag1T is offline
skag1T is on a distinguished road
Aluminum Oil filter cap assy leaking
2018 4R SR5 at 30k miles.
Last oil change I replaced the original plastic oil filter cap with a TOYOTA aluminum oil filter cap bought from Amazon and advertised as Toyota genuine part 15620-31060.
Replaced the inner cylinder with the one from the original oil filter cap, bent the tabs back out, etc.
New gaskets, oiled before install, everything torqued to specs, I noticed the cap screwed in very easy all the way to the end. The plastic cap was getting really hard to screw in about half the way, and had to use the filter cap key to be able to screw it all the way in and torque it correctly. Didn’t think anything of it, torqued the aluminum cap to spec (even though it was kind of bottomed out), and away I go.
I kept on eye whether there is any oil leaks and after about 350 miles I noticed a light glinting below the oil cap. I dropped the engine skid plate and found that indeed this thing is seeping oil.
I ordered another identical part from Amazon to test, see if maybe I got a bad part …. Will get it tomorrow.
Anybody experienced this ?
Thoughts ? Advice ?
Aluminum Oil filter cap assy leaking-22-jpg  Aluminum Oil filter cap assy leaking-33-jpg
skag1T is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 10:09 PM #2
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
I installed the Aluminum cap on my oil change and while I do not have a leak, I was not comfortable with the loose bottoming out feeling and it doesnít have the special locking tab either. I think I will go back to plastic.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 10:37 PM #3
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
Thoughts ? Advice ?
This is the 3rd post, on the first page, on this and one of them is exactly your issue. Good luck.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 09:18 AM #4
Do I need a full oil change to replace the filter cap ? Somebody told me I could take the filter out and lose only a small amount of oil.
Old 08-04-2020, 10:03 AM #5
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Use a Shop Vac...
https://www.youtube.com/watch?v=Kp1SpNpXwlE
Mack1611 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:03 AM #6
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
No need to drain engine oil. You will lose only the amount of oil contained in the filter housing plus the small amount that runs down the side of the housing when you first loosen it.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:20 AM #7
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Just to check..you are using the second o-ring under the bottom cap, right? I have the aluminum Toyota housing and dont have leaks after three oil changes.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:37 AM #8
I have both o-rings in place, yes.
To me it looks l ike the leak is from the top and flows down the wall. Doesn't seem to originate from the bottom cap.
I'm getting a second aluminum housing today, will try to swap them and see how it goes, i really like the aluminum housing, but if it leaks will go back to the plastic one.
Old 08-05-2020, 10:49 AM #9
<<<<'s Avatar
<<<< <<<< is offline
<<<< is a jewel in the rough <<<< is a jewel in the rough <<<< is a jewel in the rough
<<<<'s Avatar
I have being using mine for years without issues. Since it is original part, you should have OEM fit. Make sure you place big O-ring in proper channel and rub some oil on it so it doesnt deform inside of receiver when you tighten the assembly. G.L.
TRD 17x8.5 Wheels / Nitto RG 285/70/17 / Shrockworks Sliders / ASFIR Al Trans Skid / B&I CF Dash / TRD Stealth Shift / LED Floor Ambient Light / Prado Al Pedals / Ellis Precision Al Battery Holddown / X2 AGM Battery/LED interior / ARB on-board Air / LC custom Engine Cover / CF GC Shelf / Fire Ext & MagLite
<<<< is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 12:00 PM #10
TheNicestGuy24 TheNicestGuy24 is offline
TheNicestGuy24 is on a distinguished road
Is it possible that you accidentally cross threaded it on when you put the aluminum one on? They don't seem that easy to cross thread to me. If not, maybe you have a faulty cap assembly (manufacture defect)?
I put an aluminum one on my 2011 Camry ( I know it isn't a 4R, but haven't gotten around to putting the aluminum one on my SR5 yet) because a plastic tab snapped off the original, and I haven't had any issues, driven it 3500 miles since change out.
Edit:: I also would assume your leak would be much worse if you did actually cross thread the cap on.
2011 SR5
2011 Camry
TheNicestGuy24 is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 01:06 PM #11
CollinJ's Avatar
CollinJ CollinJ is offline
CollinJ will become famous soon enough CollinJ will become famous soon enough
CollinJ's Avatar
I’ve had one on for 20k plus miles and haven’t had any issues? Mine also “bottoms out” it seems but I’m fine with that, I get it bottomed out and try to snug it just a little more and it’s good to go.
I got mine from Amazon but the seller was a Toyota dealership
CollinJ is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 01:09 PM #12
Today I removed the engine skid plate with the intention to replace the aluminum cap with the original one. I expected to see more oil leaks, but the thing was dry as a bone in the desert. No sign of oil leak anywhere !!
So I am going to leave it on for this oil change cycle see how it does. Maybe it's going the turn out to be a keeper.
Old 07-15-2021, 01:30 AM #13
BlackPhillip's Avatar
BlackPhillip BlackPhillip is offline
BlackPhillip is on a distinguished road
I had this same issue and discovered it was just the oil from the threads itself running down. Stopped leaking once that little bit drained out entirely.
BlackPhillip is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 11:17 AM #14
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD is on a distinguished road
MidniteTRD's Avatar
i had the same situation, with less leakage than you had but enough i wasn't comfortable with it. this was using all OEM components from toyota dealers, not amazon parts.
as others have mentioned, very little resistance threading it into place even with all 0-rings in the correct position. it continued weeping after starting the car so i shut it down and went back to plastic.
i figured if it was weeping this much at idle oil pressure, i definitely didn't want to find out what it would do at 60-70psi trying to merge onto the highway at high RPM.
maybe i got a bad o-ring? or maybe i didn't wipe down the housing threads enough. i don't know, so i might give it another shot someday but for now the metal one sits on the shelf as an emergency backup should the plastic unit ever crack.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 11:24 AM #15
Whippersnapper02's Avatar
Whippersnapper02 Whippersnapper02 is online now
Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold
Are you guys replacing the O ring with each filter change?
Whippersnapper02 is online now   Reply With QuoteReply With Quote
aluminum , cap , filter , oil , part
Aluminum Skid plate with access panels to oil filter AND oil plug? numbbrrr 5th gen T4Rs 9 07-28-2020 09:20 AM
5th Gen 72k Miles, Oil Filter Leaking, Need Help pinkstarjess Problems & Warranty Issues 6 11-18-2019 06:55 PM
Dorman Help makes aluminum filter housing $30 TRDfan2011 5th gen T4Rs 1 04-15-2018 05:40 PM
Leaking fuel filter question clt750 3rd gen T4Rs 4 06-22-2013 09:33 PM
What is this filter called? Air cleaner assy. eliask08 Maintenance/Detailing 1 09-25-2010 02:48 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
