Old 08-04-2020, 09:34 AM #1
chrissurfr chrissurfr is offline
Real Name: Chris
chrissurfr is on a distinguished road
Real Name: Chris
Possible driveshaft or ujoint vibration
Hey guys,
I have a vibration from the rear/middle of the truck between 30-40 mph.
I have replaced the needle bearing, also the rear carrier has been replaced, so its not those.
Has anyone with a 5th gen had a drive shaft or u-joint that needs to be replaced?
Thanks,
Chris
2017 Cement Grey TRD Pro
C4 Fab sliders
Prinsu 7/8 roof rack
King Shocks with adjusters
SCS 17x9 f5 with 285 Nitto Ridge Grapplers
chrissurfr is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:07 AM #2
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
have you greased the driveshaft?
tm965 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:26 AM #3
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Grease first. Then a rear drive shaft is cheap and easy to swap to try it. I think you can find a junk yard one for around $100. They are very durable, so it would be unusual unless you really hammered it. Mine has nice spiral rock rash on it. I've put most of the weight of the 4Runner on the rear shaft in the rocks and didn't bend it, so you'd have to hit it pretty hard. It's not like an F150 or GM truck shaft that's barely stronger than a soda can. It's robust.
Old 08-04-2020, 10:29 AM #4
Real Name: Chris
Real Name: Chris
If I swap out the drive shaft...does that include the ujoints too? or do I have to get the separately?
C4 Fab sliders
Old 08-04-2020, 12:24 PM #5
Jetboy's Avatar
Jetboy's Avatar
Typically a used shaft will include everything from flange to flange including the u-joints. Depending on condition you may need to replace them. My experience has been that Toyota OEM u-joints are excellent if they are lubed on time. My last 4Runner still had good joints at 220k miles and they were original. So I would not expect to need to change them if you buy a low mile takeoff shaft.
5th , drive , gen , replaced , vibration
Driveshaft vibration with lift? swapmeet 4th Gen T4Rs 24 05-29-2020 05:15 PM
Rearmost ujoint Writeup NHRunner 3rd gen T4Rs 31 09-01-2019 12:28 PM
Vibration ( I know-another vibration thread) jreask 4th Gen T4Rs 1 03-16-2018 02:14 PM
Lifted 4runner driveline vibration. CV axles or rear driveshaft? redrunn Classic T4Rs 23 10-09-2015 06:28 PM
Engine/Driveshaft - Vibration/Noise? elcidsurfer Classic T4Rs 6 12-19-2010 10:15 AM
