Originally Posted by IH784
No, you’re right. Not much room at all. I’d tried to find a similar picture online but not much luck with a closeup like that. Thank you!
You could check the tube is the center of the housing and make sure it is properly clipped into the bottom of the housing. Since you can remove it. I would suppose it could come lose and if it is not seated to the bottom of the filter housing correctly things would obviously not line up real well. Does not seem likely but you could check that
