Old 08-06-2020, 01:08 PM #1
Pathfinder! Pathfinder! is offline
Pathfinder! will become famous soon enough Pathfinder! will become famous soon enough
Brake Pads and Rotors
Need to replace my front and rear brakes. What site and which pads/rotors have you guys gone with and what was your experience?
Pathfinder! is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 01:47 PM #2
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
My rig is heavy with armor and larger tires but when it came time for it I went with OEM. I still think they do a great job and the durability and longevity are still the best. I'm sure some of the other aftermarket pads and rotors work better but I know I can ride these ones out for a long time. I'd say if your rig is stock or mildly built I'd just go OEM.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 01:59 PM #3
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
My other half’s’17 SR5 didn’t need front pads till just over 100K miles, turned rotors and new OEM pads. Her rear brakes are not quite worn out yet either so we just replaced the front pads.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 03:24 PM #4
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
I have not replaced rotors, but I'm running Akebono pads and I prefer their initial bite compared to OEM, though I am fine with OEM pads as well.
Akebono PNs:
ASP 976 front pads
ASP 606 rear pads
5thToy is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 04:00 PM #5
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I did new Toyota rear rotors
New Napa Altrom Front rotors (fremax from Brazil)
New Napa Adaptive One pads front and rear
For the rears learn how to back off the parking brake shoes inside the rotor so you can remove the rear rotor. A BFH is not the solution here. Turn the star wheel down to loosen and up to tighten, I think...
I was chasing a steering wheel wobble under braking. Long story short. Get quality parts and do the job once.
The dealership I bought my used 2015 from put cheap pads on the oringinal toyota rotors.
I have about 4500 miles on this set up and like it. No squeaks, no vibrations and it stops just fine.
Adding, I buy my OEM parts from BAMwholesale.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 04:04 PM #6
Jbuckets Jbuckets is offline
Jbuckets is on a distinguished road
Do you have any break screeching when you first start driving in the morning?
Jbuckets is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 05:40 PM #7
drewsro's Avatar
drewsro drewsro is offline
drewsro has a spectacular aura about drewsro has a spectacular aura about
drewsro's Avatar
I went with Centric pads and rotors from Rockauto. I have used them on other vehicles with no issues.
2012 Shoreline Blue TE
drewsro is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 08:19 PM #8
sn_85's Avatar
sn_85's Avatar
No I haven't noticed any of that.
Old 08-06-2020, 10:07 PM #9
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Akebono PNs:
ASP 976 front pads
ASP 606 rear pads
This. Except I used centric rotors. Braking totally changed. OEM was almost undealable with the lack of initial bite and then the way it would kick in 100% and test your seatbelts if you tried to brake hard at all. Doing 70 mph on the highway, I can't stand for that to happen even once or twice a trip by mistake. I only get that emergency braking assist now in a real emergency situation. Otherwise it's controllable and linear.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 11:47 PM #10
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Yep. Akebono pads and Centric premium rotors are my go to combo. Both are good quality that perform well and aren't very expensive. As a bonus the Akebono pads do not require a break in procedure.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 12:56 AM #11
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Another for centric rotors. I forget what pads I have but they're quality ones. Rotors are slotted and drilled, probably not necessary, but I have absolutely no complaints about the stopping power. It's amazing and I love it much more than OEM. When my semi built rig is loaded down with camping gear and people and dogs, I feel safe. OEM worked, but it wasn't the safest option IMO. Plus, since I would drive up and down steep mountain roads to over 9000 ft pretty often when loaded down, it warped the OEM rotors past the point of being able to turn and cut them to reuse. And before anyone says anything, yes that was in 1st and 2nd gear also using the engine to brake.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 08:51 PM #12
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
Akebono Pads and Wagner's coated rotors
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 01:32 AM #13
young young is offline
young is on a distinguished road
Just completed PowerStop z36 kit. It brakes well but it has been few miles since I upgraded them.
young is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 09:32 PM #14
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
How is the dust ?? I’ve seen people complaining about the dust with those specifically on 5th gens.
Arnezie is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 12:26 AM #15
No dust after I drove around 50 miles today. I just placed them last sat and they are good so far, not many miles though.
brake , guys , pads , pads/rotors , site
pads and rotors/brake job on '15 T4R jharpphoto Maintenance/Detailing 1 01-14-2019 11:40 PM
Brake pads and rotors Herculean T4R 3rd gen T4Rs 11 01-28-2016 11:23 AM
Brake Pads and Rotors pickerdd Maintenance/Detailing 10 11-13-2012 10:23 AM
brake rotors/pads TNTramair 4th Gen T4Rs 3 06-12-2012 04:26 PM
Need new brake pads and rotors david_ray320 3rd gen T4Rs 6 12-27-2008 11:43 PM
