Old 08-08-2020, 10:48 AM #1
rc10mike rc10mike is offline
rc10mike is on a distinguished road
Arrow Are 700lb springs overkill for me?
Long story short;Bought a used modified 2017 OPR with KDSS. Had to start from scratch to figure out what all the components were.
What I have is Bilstein 6112s with Eibach 700lb springs in the front. I also have a Warn Semi-Hidden bumper (no winch) and RCI Sliders.
On road driving is great, theres almost no body roll or nose dive, at least to me, since Ive never driven a stock 4r, I have nothing to compare it to.
The only "issue" I have is some road bumps feel rough sometimes. I dont plan on getting a winch or adding more weight to the truck any time soon.
Would going to 650lb or even 600lb give me a better balance or would it hurt handling too much?
rc10mike is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 02:15 PM #2
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
700lbs is way overkill and I’m surprised you still have teeth. I have almost 275lbs over stock hanging off my front end and I’m running 650s. For your current weight 600s would work
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 04:57 PM #3
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
This is something i am currently looking into.
I have 6112’s up front with the Bilstein springs (600lb), and stock weight (no add on weight).
I am looking to add Steel skid plates, and a Steel hybrid front bumper next. Winch will come in the future.
Currently i am looking at the King 700lb springs.
Is a 700lb spring whats required for a steel bumper, steel skids, and a winch?
King also offers a 650lb spring.
I may look into the Eibach springs.
GripT4R is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 05:11 PM #4
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
I’m running full aluminum RCI skids and the steel Victory 4x4 bumper hope front on stock 600lbs King springs that come with their kits. I see zero need to run a higher rate but many people disagree and think you need more. I’ve done it in the past based off those comments and hated it. Way easier to turn the coil over up if it sags.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 05:21 PM #5
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
I've got 700lb Eibach/Toytec(Elka) in the front and love it.
Warn Bumper - 90lbs
Warn Winch - 65lbs
LFD Skids - 75lbs
I don't even feel it rides great, also requires less preload to keep ride height up.
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 10:24 PM #6
Obviously I can see you're setup more toward off-road, but how is your body roll and nose dive during on-road use?
Old 08-08-2020, 10:31 PM #7
Warn Bumper - 90lbs
Warn Winch - 65lbs
LFD Skids - 75lbs
I just have the bumper and sliders. I will say it rides great most of the time but when I hit certain bumps on road you kind of feel it more than you should for a vehicle with this much suspension IMO. As far as my setup goes, Im already a max height setting on the 6112 and 700lb springs.
Old 08-09-2020, 11:52 AM #8
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
You've got the height maxed out with 700 lb coils? How much lift are you getting?
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 12:26 PM #9
Xtremluck's Avatar
Xtremluck's Avatar
700lb springs are overkill for almost any possible front end configuration out there on a 5th gen. Outside of an ARB bumper, 10k winch, dual batteries, dual air compressor and full steel protection. I specifically call out the ARB bumper because it’s center mass with a winch is cantilevered off the front end more than most bumpers. Which has a big impact on how any platform performs.
650 or 700lb springs weren’t really that much a difference in terms of pavement driving. They both suck You will get better on road handling by turning up your compression dampening than you would running 700s. I do a lot of racetrack driving with my BMW M3 so I’m pretty sensitive to on road manners. The truth is the 5th gen will never handle well on asphalt because it’s an absolute pig.
Oh and you should never be running an excess of 2.5” of lift for our IFS setup if you want the right up and down travel off-road. Going higher may get you mall crawler brownie points but it won’t help off-road.
Old 08-09-2020, 07:04 PM #10
About 23" from center cap to bottom of fender. Not sure what stock front height is. I also have these in the rear which gives about 2.25" lift.
Dobinsons Rear Offset Height KDSS Coil Springs for Toyota 4Runner and – Dobinsons Direct
Old 08-09-2020, 07:11 PM #11
Well this is my first SUV. Last car was a 13 SRT8 Charger and Im pretty impressed with how the 4r handles for a tall big SUV. Like I said my only "issue" is it does ride rough sometimes.
I dont think I can tune the 6112s but I could be wrong. Would you say going with a 600lb spring (from the same company, same series) would help the rough-er ride?
Pretty sure Im at around 2.5" lift in the front currently. It has KDSS but also has Total Chaos UCAs if that matters.
Old 08-09-2020, 07:36 PM #12
comtn4x4's Avatar
comtn4x4's Avatar
That's about 3" lift. So not crazy high all things considered. I'd agree with Xtremeluck that more than 2.5" isn't ideal from a optimal performance standpoint. Adjusting the perch to high can cause something of a harsh ride as well, maybe lower the perch and see how it is? Honestly, it's a giant pain to disassemble the coilovers to adjust the Bilsteins, if you have the money I'd get fully adjustable struts, that way you can adjust it with the coilovers on the truck. The 700# coils may indeed be to stiff for your setup. In addition to 600# and 650# I believe Dobinson's has some coils in the middle. I'd contact them and see what they suggest
Old 08-10-2020, 10:20 AM #13
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Not really overkill. Definitely would feel better at the 600-650 range. I have a full front bumper, winch, lightbar, roof rack, skids, and it works nicely. Before that I had the same, just a Lo-Pro bumper and 650 handled it well. Again, if you can handle it, it doesn't matter, but ideally yes, overkill.
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 01:58 PM #14
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
i recently upgraded from 650 to 700lb.
but for your purposes 700 is definitely too much for you
for me, 700lb is good, 650 i was nose diving all the time and had maxed recommended preload and still not leveled.
most recommendations on 650vs 700 lb are based on tacomas? which have a lighter front end then the 4runner i believe. My ridge is about the same between 650 and 700, i also changed tires amongst other things.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
700lb , issue , road , springs , winch
FS: Pair of Eibach 700lb 12" 2.5" ID Springs - $80 Troymclure For Sale: Suspension/Wheels/Tires 11 06-10-2021 09:50 PM
Front Springs for V8 650lb or 700lb? Az4runnin 4th Gen T4Rs 8 11-08-2019 07:48 PM
FS: Eibach 2.5" 700lb/in coilover springs 12" Length - SF Bay Area - $80 Troymclure For Sale: Suspension/Wheels/Tires 5 07-26-2014 01:15 PM
Maybe OverKill JP4RNR Maintenance/Detailing 1 09-20-2007 04:25 PM
