Old 08-09-2020, 12:24 PM #1
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
Oil filter - Rant - call for help
I do a majority of the work on my cars in the driveway. The 4runner was new to me so I thought for the first few oil changes I'll let the dealership deal with it. Great right? Well today I was doing fluids on the 4R I get to the oil filter and this thing is TIGHT. Its still not off yet and idk how the dealership got it on and if they even changed it last time since they might of ran into this problem.
I went to advance to grab one of those oil filter caps remover for Toyota, came home attached to my 3/8ths socket and it stripped. I bought another one where i attach a 17 mM socket directly to it and with a 3 ft breaker bar it doesn't even move.
I say forget it, i'll risk it all and attach an air tool to the dang thing and if it sheers it sheers...andddd it sheers. All 3 tabs snapped off and the oil filter cap is still stuck on there.
yes, lefty loose, yes I took off the 3/8ths metal cap before trying to pull this oil filter cap off.
idk what the dealership does with this to get it so dang tight. It needs to be hand-tightened and thats it.
Now I have to spend some time to slowly chisel this oil filter cap off and replace the whole thing.
Why can't toyota make a regular screw on oil filter in this spot
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 01:22 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I don't have a 5th gen so don't have to deal with it and IF I had a 5th gen don't think I'd deal with it long, I'd put on the spin-on kit that's available and be done with it!
Old 08-09-2020, 01:28 PM #3
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I Googled "how to remove a broken oil filter housing" to see if there was advice for your predicament. One frequent suggestion is to tap the housing with a dead blow hammer and a block of wood. There are instances where a plastic or metal housing was stuck and successfully removed as shown in this and other videos Tip To Remove A Stuck Toyota Oil Filter Housing - YouTube Is there any way you can still get a grip on the housing? I know the tabs are broken. Are the points rounded off so that the socket no longer grips? Does the oil housing wrench fit tightly on the points? If not, take up the slack with paper. Does the cap have holes in it where the tabs used to be? Inserting a tool through those holes is likely to damage metal strainer that supports the oil filter. If you have any mechanical means to remove the cap, such as a strap wrench or using an extension on the drain plug, then I suggest tapping the cap first to break loose mating threads that are ultra smooth and prone to sticking due to thermocycling. See also Oil change horror | Toyota Tundra Forum (add the words "toyota" and "forums" to the above Google search to bring up more hits that are relevant.)
DougR is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 02:53 PM #4
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
This is why there are so many complaints here about dealers doing oil changes. It seems the majority of the time they mess something up. Get the aluminum canister, replace the plastic one and NEVER let a dealer do an oil change! You could go the spin on filter route but I kinda like seeing what might be in the filter. I know it's a Toyota so I'm pretty darn sure there will never be any metal in there but that's just me.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 02:58 PM #5
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
The best oil filter wrench I could find
Assenmacher Tool of Boulder, Colorado Toyota Filter Wrench
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 04:44 PM #6
00Sebby's Avatar
00Sebby 00Sebby is offline
Real Name: Mark
00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice
00Sebby's Avatar
Real Name: Mark
The plastic housing is very snug. When I change the oil, I only hand-tighten mine until it stops. Yet, every time it is very tight when I remove it. It does respond to constant pressure. So if you try to force it to loosen quickly, I could see it stripping with the cheap stamped filter wrenches. An air wrench will likely shatter the housing because the plastic will not respond well to impact. I think if you have a good filter wrench or can get a band wrench around it and apply constant pressure, you will find it will give and loosen up.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 04:50 PM #7
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Nope
This one is better.
Chrome plated forged steel, so it is a bunch stronger than that 50 buck one.
Only problem, it's $59.00
61040 65mm 14 Flute End Cap Wrench for Toyota | Lisle Corporation
In reality the Motivx alum one is fine if you're worried about rust, but 6061 alum is about the cheapest to buy, nothing special there.
Autozone and OReilly both have one for $10 and Advance Auto has what looks to be the same for $14.
The stamped steel ones with the slots are more than enough.
If you need more for a really stuck one, go get a webbed strap wrench.
I use the $10 steel one and a Dorman alum canister.
Lots of choices, good luck.
seatia is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 05:11 PM #8
That is dog sausage.
It does not fit over the tabs completely and based on what I have seen that is a big issue.
That other brand doesn't do it either and it appears to be a sh'eet Chinese tool pimped by an American shill and it breaks the housing equally as easily.
Sunroof
Old 08-09-2020, 06:08 PM #9
CollinJ's Avatar
CollinJ CollinJ is offline
CollinJ will become famous soon enough CollinJ will become famous soon enough
CollinJ's Avatar
So I’ve looked into this option for mine. There is something major I’m not a fan of and it’s altering the oil system on a 40k truck. It’s the life blood of a vehicle and I would be too worried regardless of how high end the kit is of issues down the road. It’s VERY tempting though.
I went with an OEM metal cap and have had no issues since and feel much better when changing the oil.
CollinJ is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 06:14 PM #10
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
As long as you're comfortable with it and don't mind the additional hassle, works for you!
Old 08-09-2020, 06:51 PM #11
Tuco Ramirez's Avatar
Tuco Ramirez Tuco Ramirez is offline
Tuco Ramirez has a spectacular aura about Tuco Ramirez has a spectacular aura about
Replacing the plastic with metal is not a solution. The problem is dildos installing the plastic one incorrectly, they’d prob screw up the metal one somehow too.
I have done multiple oil changes on three 5th gen 4runners as well as a camry, all with the plastic, and never had an issue. Not sure why the brain trusts on this board think switching to metal is going to fix everything and make life all hunky dory.
When you have to shoot, shoot....don't talk.
#black4runnersmatter #myprodoesntclunk
Tuco Ramirez is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 06:55 PM #12
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
I had my first oil change last month on my 2019 TRD OR and they managed to break off a skid plate bolt. Took it back and they fixed it. After that, I ordered a Motivx kit off Amazon. A friend of my wife's suggested I try the Toyota dealership she uses. Said they've always had good luck with them and have been using them for many years. I might let them do the next one and see how it goes. But as soon as the free oil changes are done, I'll definitely be doing them myself.
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
yota1976 is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 07:05 PM #13
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
All these dealerships claim to be awarded for their service departments yet I have never found an actual online listing showing accredited service departments. I wish that was readily available. Maybe my searching skills aren't up to par. Sure would be great to be able to find a reliable service dept.
pointman is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 07:10 PM #14
gp55445's Avatar
gp55445 gp55445 is offline
gp55445 is on a distinguished road
gp55445's Avatar
I switched to the metal housing because I don't like the idea of plastic holding in engine oil.
I go hand tight, then 1/8" more and I'm done. No leaks and no hassle.
gp55445 is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 07:24 PM #15
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I passed on the free dealership oil changes because of the stories on here, and the dealer is over an hour away on paved roads. Two hours using the offroad shortcut.
So I've done my first oil change. Used the Motivx tool to gently remove the overtighten plastic housing. All went well, other than laying on gravel to do it. Really need to pour a slab.
So now I know it will go swimmingly the next time. Hopefully I'll have an aftermarket skid plate for the next oil change and make subsequent changes even easier.
Also will install the Fumoto valve at that time too.
patkelly4370 is offline   Reply With QuoteReply With Quote
cap , dealership , filter , oil , sheers
Sorry for the rant, but... SCRunner12 3rd gen T4Rs 24 02-06-2011 08:22 PM
Call me crazy, call me stupid... fadedsun Classic T4Rs 4 10-31-2010 09:07 PM
Bluetooth "In-Call" Call Transfer Shooter33 5th gen T4Rs 5 04-21-2010 05:52 PM
A Rant.... kregg Off Topic 13 10-30-2008 06:15 PM
rant - rattles - rant (feel free to join me) makakio 4th Gen T4Rs 9 03-06-2005 04:41 PM
