08-29-2020, 09:09 PM
#31
Originally Posted by Marine0369
Do you have pics of the completed product?
If you search “Baxter” you full see a write up by another member, but here’s a quick shot of my finished product. I just did my first oil change since moving the filter and I was very happy about it.
2016 TE Classic Silver, KDSS, TRD Intake, 255/75R17 BFG Mud Terrain KM3
08-30-2020, 09:30 AM
#32
Doesn't solve OP's problem but for the several of you who complained about the drain in the filter housing... just leave that plug in there. Take off the entire housing to drain the filter and don't worry about the plug and plug gasket. Saves a ton of time and really isn't significantly more messy.
If you then add a skid plate with a filter access hole you economize a good bit of time and it really makes the whole process substantially easier.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
08-30-2020, 03:35 PM
#33
Originally Posted by gp55445
I go hand tight, then 1/8" more
I'll assume you're able to get it almost to the top by hand and then the "1/8" finishes it off.
It amazes me that some people(especially the idiots at the dealerships) do not realize this plastic(or metal version) can only go up so far and it's done. Not like the spin-on types where it's possible to keep turning and turning depending on your strength and determination.
If you are paying attention, your eyes and the resistance you'll feel once at top will tell you when to stop turning.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
08-30-2020, 06:45 PM
#34
Free to a good home. This worked great for 65k miles but since I’ve relocated and changed to a spin on filter, have no use for it. Let me know if someone wants it and I’ll send it out.
08-30-2020, 07:02 PM
#35
Very kind of you
09-02-2020, 08:21 AM
#36
Thanks. The location of your mount turns it to an inverted filter. What happens when you unscrew that filter; where does the oil go?
Thanks,
2015 Trail Edition with KDSS. CoverKing Ballistic Seat covers, Husky Floor Liners. Dobinson's 2.5" lift. SPC UCA's. Pelfreybilt front bumper with Baja Designs 30" bar and BD Pro fogs. Toyo AT3 255-70LT17.
09-02-2020, 10:09 AM
#37
Thanks,
Good question. The mount has a trough that catches the oil from the filter when unscrewed. It’s a very intuitive design. My first oil change with this setup resulted in not one drip of oil. Imagine that!
11-13-2020, 07:07 AM
#38
Originally Posted by Charlievee
Played this game again today and only wish Toyota could have made it more complicated. I must have torqued the "filter drain cap, plug thingy, P.O.S" a bit to much and was turning the whole housing. Grabbed the trusty vise-grip oil filter wrench and made short work of separating the two pieces.I Really need to convert it to a normal filter.
I'm in the same boat. The oil filter housing will turn, but I can't get the metal plug out. How did you get it removed? Thx.
11-13-2020, 07:49 AM
#39
I was able to hit the wrench with my hand sharply and that action broke the filter housing drain plug free. When I just tried to unscrew it the filter housing unscrewed.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
11-13-2020, 08:53 AM
#40
I have a metal cap where the ratchet/extension male fits into the camp tool and that has never stripped on me.
BUT, I grew so frustrated at how this oil cap made me feel like a rookie mechanic that I spent this past weekend installing a full Baxter relocation setup:
This looks fantastic!
Is this the product you used? If so, does it come with the converter and hoses/fittings?
Inverted Remote Oil Filter Mount - Baxter Performance
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
11-13-2020, 10:58 AM
#41
Originally Posted by ElectroBoy
You’re in samurai warrior mode now. Get your new replacement Toyota metal housing and new oil filter and gaskets on deck and attack that busted up plastic filter.
Get a large channel lock pliers or a plumber’s pipe wrench. Engulf that plastic housing high up the best you can, and unscrew it by pulling on the wrench slowly with constant force. No sudden movements. You may need additional leverage with a length of pipe over the handle of the wrench. In addition to being cranked on too tight the rubber gasket was probably not lubed before installation and it binds.
This is what I had to do with my wife's Sienna, and I haven't had any dealer oil changes since the first one. I think I'm probably in the minority here in that I actually like the bottom mounted cartridge oil filters. It's easy to prefill and really not hard to work with (so long as it's not over tightened). I'm guessing the dealer techs use air tools on them for some reason. It only takes a few seconds to do it correctly though. Just oil the o-rings and make sure they are in the right place, and it goes together pretty much by hand. Snug with a 3/8 ratchet and you're set.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
11-13-2020, 03:58 PM
#42
Banned
Real Name: Mark
Banned
Real Name: Mark
The issue is getting beaten to death, but I used the MeefZah Method for my last oil change and it worked. After loosening the filter housing I wrapped it in a plastic bag to catch any oil spillage.
Another tip for using the metal housing is cleaning the threads on the engine and the housing itself of all oil. But oil the gasket (only) before screwing the filter on the engine. If you have left any oil on the threads it will work itself out and onto the housing and you’ll think you have a leaking housing or bad gasket. Some people have seen this seeping oil and figured they had a faulty housing, so they switched back to the plastic one.
I didn’t clean the threads well enough after my last oil change and saw this happening. I left the skids off and it took three days of wiping it down after driving for all the 0W-20 to work it’s way out of the threads. I think this does not happen with the plastic housing because the lip of that housing deforms a little and snugs right up to the engine, providing a secondary seal against oil leakage.
11-13-2020, 05:27 PM
#43
By any chance you have the part numbers for the components you used? Thank you in advance!!
11-13-2020, 06:07 PM
#44
Locking Grip Oil Filter Remover Wrench Tool Vise VICE Holding GRIPPING Pliers
Held it with the filter wrench in the link and a ratchet wrench. (To lazy to take pics at the moment).
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
