Old 08-10-2020, 01:51 PM #1
elusive01's Avatar
elusive01 elusive01 is offline
Real Name: Skeet
elusive01 is on a distinguished road
elusive01's Avatar
Real Name: Skeet
Excessive Toe-out Rear Alignment
After searching and reading ive been led to post this.. now groupthink!
My rear left wheel is consistently at -0.96 deg
I’ve chewed through 4 sets of ko2’s prematurely, approx 20k avg each set. Not sure why I am now getting to this, but better late than never?
History: 2016, truck was in an accident at 7.6k, I bought it and got it road worthy and now it’s at 100k mi.
Repairs in 2016: control arm mount replaced remounted, replaced control arm, rear axle shaft
Thinking out loud:
Possible problem?
Control arm mount not welded perfectly?
Possible solutions?
Bent axle housing
What should my next step be? I want my next set of tires to last longer..
Latest alignment
Rear control arm mount now
Tire wear (front passenger was in the rear left before rotation)
Damage in 2016
elusive01 is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 02:09 PM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
It's unlikely the rear arm has anything to do with it. If the axle was located improperly, you'd see the inverse on the other wheel since the axle is a solid member across.
Most likely cause is a bent axle.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 02:55 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
If it were me - I'd take it to a body shop and have them put your 4Runner on their frame rack. With it properly located on the rack, they can take accurate measurements to confirm if everything is in the correct location and measurements to other locations on the vehicle are correct. All vehicle frames have location marks as reference points for this purpose.
Old 08-10-2020, 03:15 PM #4
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
I had a bent rear axle housing when someone drown in to my rear tire at an intersection. It wasn't caught initially until they tried to align it.
I agree with the above-- it needs a good review on a rack. A bent axle housing is not unheard of--- I recall others on this forum had it happen too.
4 years later with the replaced housing, and I've had no issues. It was a ***** to get one with the KDSS tabs on it though. Looks like you won't have that issue.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 10:03 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
A body shop (competent one) should be able to measure the two axle flanges for being parallel with each other, within a tolerance spec.
Old 08-10-2020, 10:22 PM #6
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Your straight axle is bent. Negative toe on one side has to equal positive toe of equal amount on the other side if you have a straight axle. Repeatable alignment numbers confirm this. If you had just a bent frame or improperly welded control arm mount then adjustable control arms would be an easy fix to compensate.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
arm , axle , control , mount , rear
Excessive road/tire noise. Dealer says both rear axle bearings? QuarterNote 5th gen T4Rs 0 01-21-2020 10:03 PM
Rear Hatch Alignment collierunner 4th Gen T4Rs 0 01-23-2017 01:41 PM
Alignment After Rear Lift? pengwin 3rd gen T4Rs 4 06-05-2013 05:44 PM
Excessive wear on rear tires on 1997 Limited-Any ideas? 4RUNNERTMAN Maintenance/Detailing 5 12-05-2010 10:44 PM
98 4x4 4.11 rear end excessive failures hvguy 3rd gen T4Rs 10 11-02-2007 05:06 PM
