Old 08-11-2020, 03:02 PM #1
WhiteRubi WhiteRubi is offline
WhiteRubi is on a distinguished road
Baja Designs RTL-S
Hey guys, I just ordered a Baja Designs RTL-S. The plan is to mount it rear facing on the Prinsu. I was curious to know if anybody has mounted this light and can help with the simplest wiring to have all the features work correctly (running lights, turns, reverse, and brake). It seems like their would be a way to tap into the trailer harness but a search shows that is not a possibility. Any advice?
WhiteRubi is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 03:08 PM #2
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Are you sure it wouldn't work in the trailer plug? There's a write-up on Tundras and looks like they got it to work.
Review / DIY guide - Baja Designs RTL-M | Toyota Tundra Forum
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 03:34 PM #3
No, I'm not sure. I'll look on the Tundra forum. Seems I saw on the Taco forum it wouldn't work, but that was a couple weeks ago that I looked and perhaps i overlooked something.
Old 08-11-2020, 03:49 PM #4
Turns out that write up is the TRL-M. From what i can see, no turn signals.
Old 08-11-2020, 07:16 PM #5
Baja Designs Baja Designs is offline
Baja Designs will become famous soon enough Baja Designs will become famous soon enough
For an RTL-S install, I would say most people tap into their 7 pin trailer connector with a high quality T-tap connector or cut and add a connector where you can insert two leads to each circuit. We're tapping into the running light, brake light, left turn signal, right turn signal, reverse light, and ground. From the information you found, what's the reasoning on why it doesn't work there? In theory, it should work because it's just power being triggered.
Baja Designs is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 07:24 PM #6
sn_85's Avatar
sn_85's Avatar
But don't all trailer hookups have turn signals as well? I'm not an electrical expert but it would seem to me that you'd be able to find a way to make it work.
Old 08-11-2020, 07:52 PM #7
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
our 7 pin tow has turn signals. it'll do everything you need it to do. i have a tailgate turn/tail/reverse bar that is wired into my 7 pin tow
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 09:19 PM #8
I always assumed it would work. I'll have to go track down the info that said it wouldn't to see why.
Old 08-12-2020, 12:06 AM #9
grab a test light and start poking wires. otherwise the trailer harness will work, again, use a test light to identify which wire is which.
baja , brake , designs , reverse , rtl-s
Baja Designs DavidR1 5th gen T4Rs 30 01-20-2020 01:05 PM
FS:TX-Baja Designs fog light kit Tejas For Sale: T4R Items 2 09-17-2019 11:52 PM
New Baja Designs S8 LED Light Bar - Replaces Baja Designs Stealth - Now Shipping TotalAutomotiveLV Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-03-2016 08:24 PM
