Old 08-11-2020, 07:17 PM #1
-JD-'s Avatar
-JD- -JD- is offline
-JD- is on a distinguished road
-JD-'s Avatar
Uneven brake pad wear
Started to notice my 2016 making a squealing sound last week. The sound would come and go, but was pretty constant whether i was on the brakes or not, and sounded somewhat like a brake pad wear indicator.
This seemed odd as I knew my pads weren't that old but I pulled the front tires to have a look and noticed that the passengers side outer pad was nearly completely gone. The inner pad still had a lot of life left in it and the drivers side pads looked fine.
My first thought was a frozen piston/bad caliper, but when I went to replace the pads i had no problems pushing any of the pistons back. There's also no noticeable pull in either direction when braking. I thoroughly greased the slide pins just in case they were causing a hang up, but they were greased well before I took them apart. I do get a bit of high speed vibration in the brakes, but I assume this is most likely slightly warped rotors.
Now that there are fresh pads in there I'm going to continue to monitor the wear. Is this most likely a bad caliper? I'm not eager to just start replacing expensive parts like that in the hope I'm replacing the right part. I had the fluid replaced by the dealer a few months back, is it possible they introduced some sort of contaminant into the system that has blocked fluid somewhere? Not sure were to go from here.
-JD- is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 05:58 PM #2
BigTuna02 BigTuna02 is offline
BigTuna02 is on a distinguished road
I'm with you on the caliper. How do your rotors look?
BigTuna02 is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 07:21 PM #3
Shadytype Shadytype is offline
Shadytype is on a distinguished road
Its your calipers. Probably the pins. Very common, its not retracting enough so it is always wearing.
Also, this needs to be said, are you a 2 foot driver? This is common if you are and rest your left foot on the brake. A pad will take the hydraulic pressure and rub.
Shadytype is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 11:22 PM #4
MoonGoon762 MoonGoon762 is offline
MoonGoon762 is on a distinguished road
I agree with Shadytype, check the calipers. I was replaced my calipers on the cheap and easy. My caliper pistons had quite a bit of visible rust on the shafts.
MoonGoon762 is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 10:56 AM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Better check the disc runout, especially if you’re mentioning “warped” rotors. I wouldn’t simply replace pads if I found this type of uneven wear.
I don’t think 2 foot driving is possible in these trucks since the brakes override the throttle. I’ve only tried it a couple times and it kicked in brake assist.
1000MPH is offline   Reply With QuoteReply With Quote
back , fluid , pad , pads , wear
Uneven brake wear - Help please stonnie Maintenance/Detailing 6 04-20-2021 06:15 PM
Uneven Brake Pad Wear Veritas 4th Gen T4Rs 9 08-04-2020 09:18 PM
Uneven Brake Pad Wear Streams 4th Gen T4Rs 5 12-26-2019 08:41 PM
Uneven Brake Pad Wear Arcking Maintenance/Detailing 6 09-08-2012 10:52 PM
Uneven front brake pad wear! msanta Maintenance/Detailing 8 04-17-2006 06:54 PM
