Old 08-18-2020, 10:46 AM #1
chrissurfr chrissurfr is offline
Real Name: Chris
chrissurfr is on a distinguished road
Real Name: Chris
Humming noise - narrowing down culprit
Hi all,
I have some kind of hum from the truck. I believe its a wheel bearing, but Toyota says its not.
  • Its a hum that occurs at 30-40 mph.
  • It is not consistent but happens 80% of the time.
  • It is the same frequency and pitch and does not sound faster or slower if I speed up or down.
  • The rear carrier/diff has already been replaced, and that didn't fix it.
  • I have replaced the needle bearing so that isn't the issue.
  • The noise occurs in 2wd or 4wd.
  • The noise still occurs if put into neutral when driving.
Could it be the transfer case? In my head, all things point to a rear wheel bearing.
Thanks,
Chris
2017 Cement Grey TRD Pro
C4 Fab sliders
Prinsu 7/8 roof rack
King Shocks with adjusters
SCS 17x9 f5 with 285 Nitto Ridge Grapplers
chrissurfr is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:20 AM #2
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
exhaust parts or loose exhaust shield?
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:26 AM #3
Real Name: Chris
Real Name: Chris
I'll get under there and give that a look. Thanks
C4 Fab sliders
Old 08-18-2020, 11:45 AM #4
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Alternator bearing?
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:50 AM #5
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I can't imagine that it is the transfer case. Have you changed the TC oil yet?
Why did you have the rear diff swapped out? Do you wheel it hard?
And in response to the post above, I had an Escape one time where the belt tensioner wheel bearing went out but it was pretty noticeable at any speed. Check to see if the engine fan is loose? Usually that means you have a water pump going out and would have a fluid leak so I doubt that is the issue.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 08-18-2020, 11:51 AM #6
Real Name: Chris
Real Name: Chris
Well based on the sound coming from the rear/mid-rear the dealer thought that was the issue. Which it was not..
I also did bind the gears a bit in 4wd once. Which is why I was maybe thinking transfer case. But the noise is there when the car is put into neutral when rolling.
C4 Fab sliders
Old 08-18-2020, 02:06 PM #7
Endor-Runner Endor-Runner is offline
Endor-Runner is on a distinguished road
get a couple 50lb sacks of corn and lay them in different spots to see if sound goes away. may be something touching a panel might help you narrow it down. i used this trick to hunt down some trim that was vibrating. also try getting someone to drive and you crawl around and try and hear it better.
Endor-Runner is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 02:27 PM #8
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
tires cupping? Spiders lubed? Sometimes bad wheel bearings can be identified If you raise and spin a wheel with your hand on the spring. You would feel it as a vibration.
I have a similar hum and it is caused by some cupping on my KO2's from not rotating on time / enough.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 02:40 PM #9
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Wind noise? Wind causing something to vibrate maybe. Mine made a noise in certain crosswinds a year ago or so, but I don’t hear it anymore.
thennen is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 11:12 AM #10
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
I get a pretty good hum going at around that speed. I'm 99% sure it's from my roof basket. I've heard of people using bungees woven between the cross bars to help dampen it. I may look into that at some point. Might be worth checking out. Throw something up on your roof and see if it makes a difference.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 11:33 AM #11
Real Name: Chris
Real Name: Chris
Good thought. I actually got up there last night and started hitting it on different angles to see if anything was loose.
I'm 99% sure its coming from the passenger rear bottom of the car at this point.
C4 Fab sliders
Old 08-19-2020, 12:16 PM #12
GG5thGen's Avatar
GG5thGen GG5thGen is offline
GG5thGen will become famous soon enough
GG5thGen's Avatar
Originally Posted by Ogre75 View Post
Alternator bearing?
I had a similar noise one time in a 98 Chevy Lumina. (Yeah I actually had one)
Turned out to be the serpentine belt tensioner bearing. It finally went out on me on the way to work and had to be brought in on the hook.
GG5thGen is offline   Reply With QuoteReply With Quote
bearing , noise , occurs , rear , wheel
Humming noise help- have searched buckeye4runner08 4th Gen T4Rs 6 08-31-2016 05:54 PM
On off humming noise v8 4wd 4th Gen T4Rs 8 04-30-2015 03:25 PM
Anyone looking for the noise coming from the back? Here's the culprit radlynx 4th Gen T4Rs 8 04-12-2015 09:29 PM
humming noise while driving Eshua2 4th Gen T4Rs 7 12-13-2014 02:33 PM
