08-20-2020, 05:13 PM
#16
no hay u try it before??
Sent from my TECNO CA6 using Tapatalk
#17
Originally Posted by GripT4R
Better never drive with a window down....you might breath something besides oxygen.
Have u try it before??
Originally Posted by Javin028
If the temperature knob is all the way to "Max A/C," it will default and stay in recirculate. One click clock-wise (so it's on the blue mark), you should be able to toggle recirculate on and off. It should stay in the mode you last left it in, as long as you don't put it back to "Max A/C".
The attached picture (taken from AJT) shows the knob one-click clockwise.
08-20-2020, 05:16 PM
#18
Originally Posted by spartacus
Recirculation is better then breathing all the exhaust out there..
Yes is true better do that if not
08-20-2020, 07:10 PM
#19
Banned
Banned
Do you expect an answer to whatever you attempted to ask?
Also.... don't PM me random gibberish.
08-21-2020, 08:19 AM
#20
Originally Posted by Michael-Dallas
From page 286 of OM
This doesn't make sense to me. I see no reason why recirculate uses more power than when it's off. In fact, it seems the blower is working harder when it's recirculating.
This entire summer mine is usually set the way you posted on the max cold, but one click before Max A/C and it defaults to recirculate on every time I turn it on. Having said that, I usually turn off all electronics before I shut off the car and maybe the fact I turn them on after starting the car is causing it to default back to recirc on?
I didn't know about the temp thing and will keep my eye on it as the days cool off. That explains why I don't recall dealing with this before the last couple months.
08-21-2020, 12:52 PM
#21
When AC runs w/ recirc off, it brings outside air for the AC system to cool. Recirc closes the flap that brings in outside air. So it takes less effort to keep air that's already been cooled, cool, than to cool outside hot air.
08-21-2020, 01:37 PM
#22
Real Name: Mark
Real Name: Mark
As Michael-Dallas said, the A/C works less. The reason you think the blower is working harder is due to the louder sound it makes with the outside air door closed. It runs at the same speed based on the fan speed setting.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
08-21-2020, 03:37 PM
#23
I admit I'm not familiar with the intricacies of these systems and you could be entirely correct, but this does not pass the sniff test.
First, when the car is sitting in the summer sun, the air in the car is hotter than the air outside. So when you first start the car the recirc air going through the cooling system is warmer. By your logic it would be better to begin the system by pulling in the cooler air from outside. But even if the air outside is warmer I don’t see the energy to run the system being increased by starting with the recirc on. What part of the system is working differently?
I agree with you that over time the recirc air should be cooler than the outside air because the system has had time to cool it. But the comment I made was regarding Michael’s post which states “ In order to reduce the A/C power consumption…..Recirc air mode is on when the engine is started…" not after running for several minutes.
With regard to when the car is first started, whether the A/C is in recirc mode or not, the temperature is set to the coldest setting. So the question to me is whether there is any difference to the cooling system, other than the air source. It seems to me the cooling temperature within the coils is the same regardless of the recirc switch, so there shouldn’t be any difference to the power consumption of that portion of the system. And, if 00Sebby is right that the fan is just louder and not working any more, that just reinforces my point that the system isn’t working any harder or consuming anymore energy.
Beyond the issue of whether the system is working harder, I have found overall the cooling system of these cars is marginal and find that it works best when running at highway speeds with recirc off. That’s just my opinion, but it seems to be true in my car. Even at city speeds, the system seems to cool better though the difference is less obvious. Therefore, the first thing I do when I start the car in the summer is hit the recirc button. I would be much happier if the setting were to remain on or off from the last use rather than having to change it on startup every time.
08-21-2020, 05:17 PM
#24
Real Name: Mark
Real Name: Mark
This is an assumption. If you parked in the shade or a covered parking area or a garage, the interior of the vehicle may be cooler than the temp on the road and the recir just saved all of that cooler air from being forced out of the vehicle. As stated before, the only part of the system that is working differently is where the air passed through the evaporator is coming from.
The system defaults to this setting as a fuel saving tactic assuming 1) you will actually be driving for some time after starting the vehicle and 2) humans will not remember to turn it to recirc for fuel savings. It's easier/cheaper for the system to have a on/off logic mechanism (>75F=recirc on) than some algorithm that determines when it's the best time to turn it to recirc.
There is no difference other than the air management (inside air vs. from outside)
The compressor is either running (more work=more fuel) or not running (less work=less fuel). By setting itself to recirc it will save fuel during the drive once the cabin air has been cooled as the compressor will have less work to do. That is the whole goal of this feature and why this logic condition/setting is determined at startup.
I am. This point is valid for the initial startup time. At this moment, it doesn't matter which mode it is in. Again, it sets it for the expected drive to follow.
On mine, I find when I feel really cold, I look down and see that the recirc is on from when it was started. I like fresh air and not freezing so I turn it off for the rest of the drive. So at least on both of my 4Runners, the cooling is much more efficient with the recirc on.
08-21-2020, 06:24 PM
#25
If I am parked in a parking lot out in the sun, then I will crack the windows, and when I return, I will open the doors for a minute to let the interior air temp equalize to ambient air. Where I'm at, we get triple digit temperatures 2-3 mos during summer.
00Sebby answered your other questions, so I'll leave it at that. If you understand how AC (and automotive AC) works, then that may help. If this was a BMW, then it would have an auto recirc setting, but this is a Toyota - it's not that intelligent. Even my wife's Honda Passport w/ auto climate control starts in recirc mode in the summer.
08-21-2020, 07:13 PM
#26
Banned
Real Name: Mark
Banned
Real Name: Mark
Maybe it depends on your trim and model year. On my 18 ORP if you leave the temperature knob in the Max AC setting when you turn off the engine then yeah, when you start the car next time it will come up in recirculate mode. That’s by design. All that the Max AC setting does vs the lowest temp setting is shut the recirc door. I never use that Max mode since I want to control the recirc feature manually. Another feature is that the two diverter modes that blow air to the windshield to defrost will turn recirc off. And you cannot turn recirc on until you click off one of those the windshield modes.
Do you leave AC on and in Max AC all the time, and turn the car off that way?
08-21-2020, 10:01 PM
#27
Real Name: Mark
Real Name: Mark
20 ORP it will default to recirc at the lowest max setting all the time and at the cold setting one click up when it is hot outside. My '10 TE would only default to recirc in the max setting but never default to recirc on the cold or higher settings.
08-21-2020, 10:47 PM
#28
I have a 17 ORP and I usually leave it 3 clicks above MAX. It always starts in recirc mode. Weird.
09-01-2020, 10:24 PM
#29
Real Name: Dave
Real Name: Dave
My ‘18 SR5 is default recirc on. That said, I wish it wasn’t. Being an old fart, I tend to dislike the trend that vehicles think for me. I kind of like to think for myself. I’ve done just fine this way for five decades of driving.
My 4Runner doesn’t have the luxury of a garage. Though it isn’t particularly hot where I live (record high 109º), the car is hot inside. Recirculating hot air means slower cool down time. I also keep my windows up, as otherwise the interior gets all dusty. I’m not as picky as to how the outside looks, but I get picky about seeing a coating of dust on all the black surfaces every time I enter. So with the windows up and the truck sitting in the sun, it’s pretty toasty in there. And with the AC in normal mode, the fan noise is lessened as well.
Yes, it’s minor, but it is irritating that I have to hit the recirc button to off every time I start up. This is my first vehicle with a default recirc on system and I still prefer to have personal preference things set as they were the last time I drove it.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
09-02-2020, 08:10 AM
#30
I like recirculation for keeping out the smell of dead skunks. Also works decently for keeping out the smell of smoke as well.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
