Old 08-19-2020, 09:23 AM #1
chrissurfr chrissurfr is offline
Real Name: Chris
chrissurfr is on a distinguished road
Real Name: Chris
Replacement wheel bearing hub assembly - where to buy?
Hey guys,
I'm pretty sure one of my rear wheel bearings is shot. Most likely from high water in Houston streets.
Where can I buy the parts online? Are there any forum vendors that sell?
Does anyone know what the exact part number or list of parts to swap these out so I don't have to go to the dealer?
Thanks,
Chris
2017 Cement Grey TRD Pro
C4 Fab sliders
Prinsu 7/8 roof rack
King Shocks with adjusters
SCS 17x9 f5 with 285 Nitto Ridge Grapplers
chrissurfr is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:42 AM #2
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Originally Posted by chrissurfr View Post
Hey guys,
Thanks,
Chris
Be careful, rear wheel bearings are much different than fronts and pretty involved to change. Fronts are not too bad if you get a pre-pressed assembly. I bought 2 from a member on TW that you can find pretty easily, one of them worked great and the other would lose its press every time i installed it. I think it was pressed wrong to begin with. Finally had to go to dealer and have them press and install a new one for me. So, it's a roll of the dice, be prepared. Also, you have to make sure you know what bearing is being pressed into the assembly. Toyota was using Koyo bearings but then switched to NSK?, but I'm not sure.
The rears I was told rarely go bad. To change them you have to pull out the rear axle. There is instruction in the FSM, it doesnt look like a quick job like the fronts. Below enter your VIN# for exact part numbers:
Catalog Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 06:03 PM #3
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
If a rear wheel bearing fails due to water infiltration, then the entire differential was exposed to contaminated oil. The first thing I would do is remove the differential level plug and draw a sample of oil by dipping a pipe cleaner.
DougR is offline   Reply With QuoteReply With Quote
buy , dealer , forum , parts , wheel
Front Wheel Bearing Hub Assembly mlc2000 4th Gen T4Rs 95 03-11-2021 11:27 AM
Wheel bearing/hub assembly Deputy 4th Gen T4Rs 23 12-28-2018 12:27 AM
Best Replacement Wheel Bearing / Hub Assembly bzettler83 4th Gen T4Rs 2 08-02-2018 01:55 PM
Wheel bearing assembly replacement help nysimonsez 4th Gen T4Rs 27 09-24-2014 12:26 AM
Wheel Bearing/ Hub Assembly IOPturbo 4th Gen T4Rs 5 03-17-2012 07:08 AM
