Old 08-19-2020, 05:16 PM #1
vrydrtyd vrydrtyd is offline
vrydrtyd is on a distinguished road
Air Conditioner Issues
I’ve searched the forum for anyone having the same issue which is: the driver side a/c vent does not blow cold air, the passenger side blows noticeably colder. I took it to the dealer and of course they want an arm and a leg to evac. and recharge the system with dye to find a leak, but couldn’t explain why the passenger side blows cold. Has anyone heard of this with the 5th gen or 4Runner in general?
vrydrtyd is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 05:36 PM #2
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Yeah, it's a thing with Toyotas when they get low on refrigerant.
Just went through the same thing with my 4th gen, had Toyota evac/recharge with dye to trace the leak, but with my mileage/age, it's likely to be the evaporator core.
Once recharged, mine blows colder than ever, so it's definitely a thing.
eleven14 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:39 PM #3
JMZ400's Avatar
JMZ400 JMZ400 is offline
JMZ400 will become famous soon enough
JMZ400's Avatar
I'll second that. Had same on my 4th gen. Due to evaporator placement/design when refrigerant gets low one side gets warm first. Had mine replaced and no more problems. I'm hoping the 5th gen isn't going to suffer the same issue as it's a huge job on the 4th gen.
Could maybe be a stuck blend door with any luck. I know I still get outside smells even on recirculation setting so something's not sealing.
Sent from my SM-A205U using Tapatalk
2012 Trail Edition
2006 SR5 V6 Sold
1981 FJ40
1991 CRX Si - Sort Of
JMZ400 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 06:35 PM #4
Mcd3mcd3 Mcd3mcd3 is offline
Mcd3mcd3 is on a distinguished road
I have had both problems - blend door, and low leaky refrigerant. I'd pay to check for leaks first, then fill, then blend door - the blend door was a pia.
Mcd3mcd3 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 10:50 PM #5
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Some threads on this issue - usually low refrigerant causes the a/c system to only blow cold air through some of the vents (sort of an early warning of a problem), and if it is not this then troubleshoot the blend door.
5th Gen a/c issue:
AC dash vent temp imbalance
4th Gen a/c issue:
A/C Hot on drivers side!
Driver's side air conditioner not as cold
A/C hot on driver side, Cold on passenger
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
air , blows , cold , passenger , side
Air conditioner always on vtferret 3rd gen T4Rs 14 12-12-2015 07:41 PM
Air conditioner Deportistapr New Members 1 02-13-2014 10:23 PM
Air Conditioner MickeyMouse Classic T4Rs 16 12-17-2012 08:19 AM
Air Conditioner Issue Seth352 Problems & Warranty Issues 0 12-08-2011 03:34 PM
air conditioner noise issues augirl08 4th Gen T4Rs 1 03-28-2010 01:08 PM
