Old 08-19-2020, 06:34 PM #1
jayhat's Avatar
jayhat jayhat is offline
jayhat will become famous soon enough
jayhat's Avatar
Wiring to rear of vehicle for power distribution - does this look ok?
1) As far as circuit breakers go, should I have another one near the rear power distribution point? Is the 100a one off the battery enough?
2) 4GA wire good enough for this?
3) Anyone know of any factory ground points at the rear of the vehicle?
What might I run? Possibly a fridge, basic lighting, charging devices, charging goal zero/inergy apex type device while driving, etc.
jayhat is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 12:25 AM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Yep. That’s a good plan.
You don’t need another breaker in the rear (that’s what the fuse block does) but make sure to mount the one you’re planning under the hood as close to the battery as possible to minimize the length of unprotected high current wire.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 12:49 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
IMO - Looks like massive overkill. A 15 or 20 amp breaker and #10 wire will probably handle all you mentioned with capacity to spare. There is a good factory ground point at the built in inverter above the rear wheel.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 01:08 PM #4
Cajun_TRD's Avatar
Cajun_TRD Cajun_TRD is offline
Cajun_TRD is on a distinguished road
Cajun_TRD's Avatar
I'd put the fuse block under the dash so you can tie in stuff there later (CB, VHF, switches, etc. With your current drawing, if the breaker trips you have to find a short in the wire that goes ALL the way through the engine compartment and all through the interior. Putting the fuse near the firewall means that if the wire gets damaged on the interior the fuse will blow. If the breaker blows then you only have to check the wire to the fuse.
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
Cajun_TRD is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 01:35 PM #5
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
100 amp breaker is a little over what the #4 wire is rated for. ( its rated at 95 amps) and that depends on the wires insulation.
To save space under the hood you could use a Blue sea 5191 fuse holder that attaches to the battery terminal. This will eliminated the need for the breaker.
Blue sea also has a dual fuse Block the 2151. It holds two fuses so if you ad another circuit, say under the hood you can fuse that at a different amperage rating.
This might eliminate the bus bar in your circuit and still provide for future sub panel or relay panel under the hood.
Don't get me wrong Your on the right track
Calculate what your amperage draw will be with all you equipment you intend to have in the back.
#4 will be fine but might be overkill for your needs.
Lots of information in this forum, Most of it in the threads about refrigerators
I did something similar to this last year. Go to my Album page and take a look.
signature not available
Rack is offline   Reply With QuoteReply With Quote
charging , distribution , power , rear , vehicle
Limited power distribution 5Sport 5th gen T4Rs 5 03-17-2019 10:23 AM
Need 1999 4Runner SR5 Power distribution wiring diagrams Dozerman 3rd gen T4Rs 0 03-28-2017 10:47 PM
Power Distribution & Switch Option | New? reidbailey 5th gen T4Rs 0 07-10-2015 03:17 PM
