Old 08-19-2020, 08:12 PM #1
papapoopski papapoopski is offline
papapoopski is on a distinguished road
Oil on spark plug
yes I searched but only found results for 3rd and 4th gen
Changing my plugs out today, found wet oil on the threads of one plug. Truck drives as it should, no weeping from the valve covers.
2010 with 135k
Any suggestions, advice, sarcastic one liners?
2010 SR5, Dobinsons 300 & 505 springs, Bilstein 5100 front/rear, LED interior, Metaltech sliders, LFD crossbars, '10-'13 Trail Wheels, Toyo AT3 255/80/17
papapoopski is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:56 PM #2
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
There are grommets between the spark plug cans and cylinder head cover. It appears one of the grommets has an oil seep. It's always a good idea to shine a light into the spark plug cans before removing the plugs. Do you recall if all coil pack insulators that touch the spark plugs were dry? If so, I suggest waiting 10,000 miles and then inspecting the can with a wet plug. A trace amount of oil is nothing to worry about. Next time when you change plugs, hold a rag over the exposed spark plug can and blow out contamination with compressed air. I would also check the PVC valve for blockage.
DougR is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 01:01 AM #3
Whippersnapper02's Avatar
Little bit is fine. A flooded tube would throw a red flag.
Old 08-20-2020, 01:27 AM #4
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
If it ain't broke don't fix it!
nglayton is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 08:54 AM #5
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I found oil on the threads of the plug on the driver's side, closest to the firewall when I changed mine at 120K. The truck runs fine and uses no oil over the 5K interval, and it's been sitting a lot due to covid work arrangements.
Anyway, I later did a couple hundred miles in a weekend and pulled that plug and the middle one on the drivers side to check them. Both were clean and dry. So, it seems like sitting may contribute.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 10:23 AM #6
should be ok....one of my trucks has coolant on the plugs when i pull them lolol
Old 08-20-2020, 11:19 AM #7
Thanks for the replies. I will leave it alone for now and check the coils and plugs after driving for a while. I have a new pcv sitting around here somewhere. I'll get that done for good measure.
drives , found , oil , plug , truck
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
oil on spark plug #6 KMG 4th Gen T4Rs 6 03-10-2015 12:53 PM
Spark Plug Help kpnavarro Classic T4Rs 2 12-04-2012 09:40 PM
spark plug chg - anything I need to know about? jediwebdude 4th Gen T4Rs 10 04-30-2012 10:26 PM
spark plug help!!! Kris-with-a-k Classic T4Rs 17 05-10-2011 06:17 PM
