Old 10-14-2020, 03:56 PM #16
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Originally Posted by 4Runnin4Fun View Post
I'm considering adding a spacer in front but curious how preloading will effect the ride quality.
I don’t think a front spacer will introduce any preload. It will just add more lift, i.e., it won’t compress the spring(s).
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 07:20 PM #17
Treetopflyer Treetopflyer is offline
Treetopflyer is on a distinguished road
Originally Posted by Crikeymike View Post
Yeah, if the lift height front and rear was the same, it would keep the rake. Aka 2" lift front and rear won't reduce the rake. Most people would use a shorter height rear coil if they want to reduce the rake.
Oh, and KDSS vehicles don't lean to the driver's side hardly ever, they lean to the passenger side with the fixed sway bar mounts, so a lot that were chiming in probably don't have KDSS. A lot of people create a lean when putting a spacer on the driver's side with KDSS, making the passenger side really low.
That's why I usually recommend people wait and add a spacer after a lift is installed and settled and if they have a lean of 1/2" or more, then they can correct if it they feel they should.
It’s strange. I just installed my Dobinsons springs on my KDSS 2018 4runner and the left side sits 1.5” lower than the right. Is this normal and any idea how to best rectify it?
Treetopflyer is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 10:03 PM #18
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
That's a kdss lean then.
Look at this
https://exitoffroad.com/wp-content/u...it-Offroad.pdf
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 10:00 AM #19
Look at this
Thx. I always thought KDSS lean was lower on the right side than the left. It can be lower on the left?
Old 01-29-2023, 11:52 AM #20
Crikeymike's Avatar
Crikeymike's Avatar
The pistons are on the drivers side. It must be holding that side down, so follow those instructions to reset the balance
anticipation , driver , lean , side , spacer
Driver side lean octanejunkie 3rd gen T4Rs 25 11-15-2021 09:31 PM
Best Driver Side Lean Solution JBend 4th Gen T4Rs 2 05-14-2020 07:10 PM
Fixing the driver side lean.. BendRunner 4th Gen T4Rs 19 08-20-2019 11:18 PM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
