Old 08-20-2020, 12:29 PM #1
4Runnin4Fun 4Runnin4Fun is offline
4Runnin4Fun is on a distinguished road
Driver Side Lean
I'm getting ready to install an Eibach lift. I measured today and on stock suspension don't have a driver side lean. I had bought a ToyTec 1/4" spacer in anticipation of having driver side lean. So the question is, should I install the spacer in anticipation of ending up with driver side lean? Or since I'm good pre-lift should I be good post-lift?
2015 Trail Premium w/KDSS, Eibach Pro-Truck Lift System (Stage 1), RCI sliders, 285/70R-17 BFG T/A KO2s, SSO Slimline Hybrid w/High Clearance Cuts, 12K Smittybilt X20 w/synthetic line, Flush mount Diode Dynamics SSC2 reverse lights, NiLight LED ditch lights, LED high highbeams & fog lights, WeatherTech mats, Canvasback Cargo Liner
4Runnin4Fun is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 08:34 AM #2
I'm thinking I should go ahead with it
Old 08-21-2020, 08:38 AM #3
dirtydurley's Avatar
dirtydurley dirtydurley is offline
Real Name: Ryan
dirtydurley is on a distinguished road
Real Name: Ryan
I’d install it. I had my lift installed (Dobinsons) and afternoon it settled I had the lean so put the spacer on driver rear. Still need to measure again to see how much it helped.
dirtydurley is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 09:08 AM #4
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
I ended up with lean after the Eibach install, but can't say if it was there prior. If your installing the lift yourself, its like a 10 min job to place the spacer in the rear and i would wait to see if its required. You will also be able to measure for the correct size... Unless you get the adjustable spring perches. The information can also help future members.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 09:11 AM #5
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
I agree with waiting! Not every lifted 4Runner has issues with lean once the lift is installed. As mentioned before, it wont take long to throw that spacer in after the fact, so I would leave it out and see what measurements you end up with first.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 11:10 AM #6
M22's Avatar
M22 M22 is offline
M22 is on a distinguished road
M22 M22 is offline
M22's Avatar
What brand & height of spacer did you end up using for the rear? I installed the Eibach kit a little over a year ago and it has a little driver side lean that I would like to correct.
M22 is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 11:52 AM #7
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
OME makes a 10mm trim packer. That’s what I’ve used in every one I’ve had. Always did the job.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 12:18 PM #8
M22's Avatar
M22 M22 is offline
M22 M22 is offline
M22's Avatar
Are you using the OME 10mm that goes on top of the bump stop #150PR10 or it seems there is a older version that goes between the OE bump stop and the spring (yellow ring)?
Thanks
Old 08-21-2020, 03:35 PM #9
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I’m using the yellow ring. I actually use two to get the lean to be correct. Had zero issues on any rig with probably 50k miles like that
‘14 SR5 in white
Full RCI skids
Old 10-01-2020, 02:05 PM #10
I opted to forego adding the spacer while installing the Eibach Pro-Truck Lift System (Stage 1) for 2010+ 4Runner (E80-82-071-01-22) lift. Below are my measurements before and after the lift.
Before:
Front passenger 34.25"
Front driver 34 3/16"
Rear passenger 36.5"
Rear driver 36.5"
After:
Front passenger 36.5"
Front driver 36.5"
Rear passenger 38.25"
Rear driver 38.5"
I'm surprised that I maintained the factory rake. Has anyone else had this experience?
Old 10-01-2020, 03:46 PM #11
Real Name: Ryan
Real Name: Ryan
Wow. Sorry for late reply. I don’t like the Tapatalk App. I just ordered the spacer from Exit Offroad. It’s a Dobinsons spacer. PS59-4025
Old 10-14-2020, 07:28 AM #12
Is this normal? I'm surprised I kept my rake.
Old 10-14-2020, 09:02 AM #13
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I have a 4th gen, and my factory rake is back. I used to have front and rear Daystar spacers on my 4R, and they eliminated the rake.
After I installed Toytec/Bilstein shocks and springs recently, the rear is higher again, even with 1/4” spacers on top of both front struts. I think the new rear springs raised the rear 3” instead of the 2” advertised. That could also be because my factory springs were old and tired.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 12:43 PM #14
I'm considering adding a spacer in front but curious how preloading will effect the ride quality.
Old 10-14-2020, 01:24 PM #15
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Yeah, if the lift height front and rear was the same, it would keep the rake. Aka 2" lift front and rear won't reduce the rake. Most people would use a shorter height rear coil if they want to reduce the rake.
Oh, and KDSS vehicles don't lean to the driver's side hardly ever, they lean to the passenger side with the fixed sway bar mounts, so a lot that were chiming in probably don't have KDSS. A lot of people create a lean when putting a spacer on the driver's side with KDSS, making the passenger side really low.
That's why I usually recommend people wait and add a spacer after a lift is installed and settled and if they have a lean of 1/2" or more, then they can correct if it they feel they should.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
anticipation , driver , lean , side , spacer
Driver side lean octanejunkie 3rd gen T4Rs 25 11-15-2021 09:31 PM
Best Driver Side Lean Solution JBend 4th Gen T4Rs 2 05-14-2020 07:10 PM
Fixing the driver side lean.. BendRunner 4th Gen T4Rs 19 08-20-2019 11:18 PM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
