08-20-2020, 12:29 PM
Driver Side Lean
I'm getting ready to install an Eibach lift. I measured today and on stock suspension don't have a driver side lean. I had bought a ToyTec 1/4" spacer in anticipation of having driver side lean. So the question is, should I install the spacer in anticipation of ending up with driver side lean? Or since I'm good pre-lift should I be good post-lift?
2015 Trail Premium w/KDSS, Eibach Pro-Truck Lift System (Stage 1), RCI sliders, 285/70R-17 BFG T/A KO2s, SSO Slimline Hybrid w/High Clearance Cuts, 12K Smittybilt X20 w/synthetic line, Flush mount Diode Dynamics SSC2 reverse lights, NiLight LED ditch lights, LED high highbeams & fog lights, WeatherTech mats, Canvasback Cargo Liner
08-21-2020, 08:34 AM
I'm thinking I should go ahead with it
08-21-2020, 08:38 AM
Real Name: Ryan
Real Name: Ryan
I’d install it. I had my lift installed (Dobinsons) and afternoon it settled I had the lean so put the spacer on driver rear. Still need to measure again to see how much it helped.
08-21-2020, 09:08 AM
I ended up with lean after the Eibach install, but can't say if it was there prior. If your installing the lift yourself, its like a 10 min job to place the spacer in the rear and i would wait to see if its required. You will also be able to measure for the correct size... Unless you get the adjustable spring perches. The information can also help future members.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
08-21-2020, 09:11 AM
I agree with waiting! Not every lifted 4Runner has issues with lean once the lift is installed. As mentioned before, it wont take long to throw that spacer in after the fact, so I would leave it out and see what measurements you end up with first.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
08-21-2020, 11:10 AM
What brand & height of spacer did you end up using for the rear? I installed the Eibach kit a little over a year ago and it has a little driver side lean that I would like to correct.
08-21-2020, 11:52 AM
OME makes a 10mm trim packer. That’s what I’ve used in every one I’ve had. Always did the job.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
08-21-2020, 12:18 PM
Are you using the OME 10mm that goes on top of the bump stop #150PR10 or it seems there is a older version that goes between the OE bump stop and the spring (yellow ring)?
Thanks
08-21-2020, 03:35 PM
I’m using the yellow ring. I actually use two to get the lean to be correct. Had zero issues on any rig with probably 50k miles like that
‘14 SR5 in white
Full RCI skids
10-01-2020, 02:05 PM
I opted to forego adding the spacer while installing the Eibach Pro-Truck Lift System (Stage 1) for 2010+ 4Runner (E80-82-071-01-22) lift. Below are my measurements before and after the lift.
Before:
Front passenger 34.25"
Front driver 34 3/16"
Rear passenger 36.5"
Rear driver 36.5"
After:
Front passenger 36.5"
Front driver 36.5"
Rear passenger 38.25"
Rear driver 38.5"
I'm surprised that I maintained the factory rake. Has anyone else had this experience?
10-01-2020, 03:46 PM
Real Name: Ryan
Real Name: Ryan
Wow. Sorry for late reply. I don’t like the Tapatalk App. I just ordered the spacer from Exit Offroad. It’s a Dobinsons spacer. PS59-4025
10-14-2020, 07:28 AM
Is this normal? I'm surprised I kept my rake.
10-14-2020, 09:02 AM
Real Name: Howard J. Turkstra
I have a 4th gen, and my factory rake is back. I used to have front and rear Daystar spacers on my 4R, and they eliminated the rake.
After I installed Toytec/Bilstein shocks and springs recently, the rear is higher again, even with 1/4” spacers on top of both front struts. I think the new rear springs raised the rear 3” instead of the 2” advertised. That could also be because my factory springs were old and tired.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
10-14-2020, 12:43 PM
I'm considering adding a spacer in front but curious how preloading will effect the ride quality.
10-14-2020, 01:24 PM
Yeah, if the lift height front and rear was the same, it would keep the rake. Aka 2" lift front and rear won't reduce the rake. Most people would use a shorter height rear coil if they want to reduce the rake.
Oh, and KDSS vehicles don't lean to the driver's side hardly ever, they lean to the passenger side with the fixed sway bar mounts, so a lot that were chiming in probably don't have KDSS. A lot of people create a lean when putting a spacer on the driver's side with KDSS, making the passenger side really low.
That's why I usually recommend people wait and add a spacer after a lift is installed and settled and if they have a lean of 1/2" or more, then they can correct if it they feel they should.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
