TRD-Pro-FOX lift options
Trying to consolidate a bunch of threads here, this is the best I can do to gather information for lifting a Fox -shocked TRD-Pro and maintaining the factory Fox shocks
Cornfed
1.5"fr / 0.5"rr
2"fr / 1.0"rr
The bigger lifts seems to include both a spacer inside the coil pack on top of spring and a spacer between the shock and frame mount on the front to split the geometry changes between the coil itself and frame side.
TRD PRO 5th Gen
Burtman Industries..
Reseller of Cornfed?
They seem to be showing a 2.5" / 2" as well as a 3" / 2" Pro lift that isn"t on cornfed's list not sure if they are actually making their own? Could be UHMW plastics, not aluminum?
Burtman Industries
Toytec
1.5-2"fr / 1.5"rr
Front is split between coil pack (looks like lower spring perch) and above shock spacer. Aluminum spacers
4RPROFX - Toytec Lift Kit for TRD Pro 4Runners (with OEM Fox Suspension)
WestCott Designs
Fr 1.5" / 1.25" rr
Spring perch based lift kit..
Fox TRD PRO Lift Kit - Westcott Designs
Eibach
Replacement springs, slightly stiffer rates (designed for slim fit aftermarket bumpers..)
1.6"fr / 1.0"rr
PRO-LIFT-KIT Springs (Front & Rear Springs)
I"m not sure what can be combined, but I need to do some research to see what could work.... I like the idea of the Eibach springs, with a little spacer upfront, and then these in the back (just the adjustable perches..)
I'll update this with actual customer measurements if I get bored later.. maybe wheel center to fender arch kind of thing..
https://eibach.com/us/2261/AK31-82-0...truck-coilover
