Old 08-24-2020, 02:21 PM #16
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I suspect what happens is the car signal from the fob is interrupted or the vehicle otherwise identifies a problem with the signal and thinks that it is stolen. The security system probably allows you to operate for a while without the key, but eventually will shut off the engine if the key is not recognized again. So that would explain why it randomly turned off. And probably when the vehicle is "off" the charging circuit in the rear isn't working, but as soon as it moves to accessory it re-energizes the system and then the device you are charging interferes with the key fob and it tells the ECU not to start the engine.
Just a random guess. But it could fit all of the symptoms and why you couldn't get past the accessory on condition.
Old 08-24-2020, 10:05 PM #17
choochoo choochoo is offline
choochoo will become famous soon enough choochoo will become famous soon enough
Originally Posted by Kamalani Mahie View Post
@DannyLlama
This exact same thing happened to me too! I can't help with the cause. I'm not very knowledgeable when it comes to electronics. But I plugged in my radios to charge in the back and it caused this exact issue and so they haven't charged back there since. I see you have a 2017 SR5. Did you do the mod to put in an older accessory display? I have a 2015 Trail but I put in a 2014 Accessory display and it was right after that I noticed this issue. Maybe about a year ago. I have no idea if the two could be connected. Probably not but maybe I should ask @OldRed
I've not done a mod to put in an older accessory display. The only electrical mod I've done so far is add a Switch Pros SP9100 unit - but I don't think that's what is causing the issue.
choochoo is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 07:47 AM #18
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Good to know. I guess just stack it up to electrical interference?
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 03:42 PM #19
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Many (most?) battery chargers are cheaply designed and don't use enough suppression or filtering so they generate all sorts of interference across the radio spectrum. Short of opening them up and using shunting caps and inductive toroids to filter the junk, you're going to have to deal with that.
Plugging them into the 12v system of the truck is essentially like attaching a huge antenna to it so it's not all that surprising that will then interfere with the relatively weak signals of wireless fobs.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 05:37 PM #20
Oregon1 Oregon1 is offline
Oregon1 is on a distinguished road
Both of my fobs stopped working on Saturday and I had a semi glowing CEL. Wouldn't turn over - just cranked. Disconnected the battery and reset it. Turns out it was my Pedal Commander - had enough of an open draw to throw the code and kill the fobs. Fixed now though. But the fob thing kinda threw me.
Oregon1 is offline   Reply With QuoteReply With Quote
car , charger , lock , shut , unplugged
What would you do in this situation? jordan_tm 5th gen T4Rs 11 07-22-2014 04:22 PM
What is the best situation for AWD or 4hi spoiler900 3rd gen T4Rs 4 12-11-2012 07:47 PM
The explination!!! driffter33 Off Topic 3 07-04-2011 03:39 PM
What would you do in this situation?? KP Texan 4th Gen T4Rs 3 02-09-2009 04:15 PM
daystar cornfed... explination for newbie keylay31 4th Gen T4Rs 3 01-24-2007 09:19 PM
