Old 10-25-2020, 03:27 PM #1
slide531's Avatar
slide531 slide531 is offline
slide531 is on a distinguished road
slide531's Avatar
Would you replace this tire?
Just noticed this side wall slice on my rear passenger tire. I can't see the belts and it hasn't leaked air. I have a a couple hundred miles of dirt roads coming up in a couple weeks where I'll be aired down. I'm on the fence but leaning towards replacing it. These KO2s have 18k on them and looks like they've worn about 4mm, I'd only replace one tire.
Sent from my Pixel 2 using Tapatalk
slide531 is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 03:35 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Considering your up coming trip I'd replace it. However, I'm kinda fanatical about tire condition especially when going on a trip.
That being said what's you're spare tire situation? Are you carrying a same sized same type tire in excellent condition? What type of trails will you be on? Would you even be able to change the tire in the conditions your getting into or get to the spare? Do you have a method of jacking your vehicle in those conditions? Airing the tire? Do you have a tire repair kit and the familiarity with it to use it if needed? There's a lot of variables unfortunately.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 03:46 PM #3
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I’d replace it, maybe use it as a spare for low speed, off-road use. Sidewall damage can deteriorate quickly and catastrophically.
Good luck!
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 04:20 PM #4
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
Spare it better safe than sorry
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 05:49 PM #5
slide531's Avatar
slide531's Avatar
Good luck!
Thanks, think I was assuming it would stay the same but if sidewall damage deteriorates it has to go
Old 10-25-2020, 06:49 PM #6
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Would tire certificates take care of that?
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 06:49 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
It looks like that dark area around the slice could indicate some separation under the surface. I'd replace it.
Old 10-25-2020, 07:17 PM #8
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Yes, Yesterday
Unless you are staying within your own zip code.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 09:02 PM #9
Jeremy556's Avatar
Jeremy556's Avatar
I wouldn't. I got this nice little cut (8mm deep) when this tire had about 500 miles on it a year and a half ago. I'm going to be replacing it soon for tread wear.
Old 10-26-2020, 02:50 PM #10
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Looks like you cut the outer ply. You have two to go. I’ve sliced and diced my BFGs over the decades without failure.
But, I like the suggestion to use this one as a spare and buy a new replacement tire. Sounds like a win/win solution overall.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 04:08 PM #11
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
My general experience with sidwall cuts is that they'll give you a good amount of warning before going bad. Usually the tire will develop a pretty good bubble around the failure area before it actually blows out. To me it looks superficial. But it's hard to really see in a picture how deep it is. I'd probably run it. Maybe use it as a rear tire only if you're really worried about a blowout. Could make a good spare as well
Generally if you had cut any of the cords you'll see a bubble that looks like this: (and at that point it's time to replace the tire for sure)
Old 10-26-2020, 06:56 PM #12
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
If you're planning on airing it down and going on a remote adventure, I'd probably replace it unless you're in the mood for a tire change fire drill in unknown conditions.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 06:39 PM #13
slide531's Avatar
slide531's Avatar
Thanks guys, had an unused KO2 as a spare so swapped it out and kept it as the spare. Had to swap wheels - had the shop do that and they agreed with Jetboy Would you replace this tire?
Old 11-05-2020, 03:52 AM #14
Dollar Retriever Dollar Retriever is offline
Dollar Retriever is on a distinguished road
I would replace it.
Humps and cracks are not safe.
Dollar Retriever is offline   Reply With QuoteReply With Quote
couple , leaning , replace , replacing , tire
When to replace spare tire? Ray Dunakin 5th gen T4Rs 15 06-30-2019 12:40 AM
Hole in BFG KO2 Tire - should I replace?? JasonKoko General Discussions 17 06-09-2017 01:41 PM
When to replace a punctured Tire EinVB General Discussions 19 11-03-2015 06:01 PM
Replace One Tire or Two? splifrover 5th gen T4Rs 2 12-06-2010 11:34 PM
Replace Just One Tire? wiseguy 4th Gen T4Rs 6 11-16-2006 06:28 AM
