08-24-2020, 11:10 PM
Awning / Fridge Install Advice
Pulled the trigger on these two looooong overdue equipment upgrades  . Not top of the line but should meet my needs versus none at all. Under $525 in stock arriving next week in time for the HOT  AZ Dove hunting season. #shade_coldbeer
Any tips on mounting the awning to stock roof rails. Also, lessons learn with a AC fridge on a homemade wood riser (no drawers at this time)
2015 SR5 Premium (2019 / 42,335 mi): 1st time 4-Runner owner | 3rd row | N-Fab step / slide | Falken Wildpeaks AT3W 265/70/R17 | Alpicool C30 Fridge / Freezer | Danchel 6.5' x 8.5' awning | ... it's coming along, but still mostly stock still.
08-25-2020, 12:22 AM
I made some brackets a few yers ago.. works great with stock rails.. i dont have any more but any laser cutting shop can cut some,,, just a metal plate with 5 holes.. T slot bolts avaliable online.. search awning on stock rails
I went to a stereo shop to run 12v arb plug to the back for the fridge.. right off the battery... tie the fridge down, you dont want it loose in the back
08-25-2020, 10:23 AM
I build (two!) wood platforms w L-track to (1) strap down fridge, battery, other stuff and (2) sleep in back.
Sleeping Platform - V1.0 Complete - Now w Plan
Has worked flawlessly.
I'm about to create v3.0 to tweak a few things specific to my set up.
08-25-2020, 04:30 PM
The awning looks like it comes with some decent T-plates, good call on the T-slot bolts. The awning is 6.5 wide, the stock rack is about 5 ft, so there is about 16 inches hanging out front unsupported. I hope it doesn't sing in the wind or vibrate.
As for the fridge, there is a dedicated 12V adn 110V in the back cargo area, is that not sufficient? I do want to strap it down no doubt.
08-25-2020, 04:50 PM
Dang
@ rageandlove
- your shop is out of control sweet. You all need to click that link and see this guys shop! So, yah, not at that level, but you share a good lesson. You've shown, that it's okay, to evolve, and improve. I've been procrastinating to build one for years, waiting for the perfect everything and have done nothing. NO MORE.
I'm going for it. Something simple. I like the idea of just a shelf, so I can stow gear that gets used frequently underneath all the other gear for easy access, shotgun, chairs, ammo, table. then camp gear on top above that. It will most likely just be a riser platform. I 'm stealing your bolt down idea.
Thanks for sharing.
08-25-2020, 11:32 PM
Hey - it's not mine, it's my buddy's ... and it's great.
I've been doing the try/learn/adjust in a number of areas. For example, I head out dispersed camping a lot, and there I have been taking 2 boxes with camping/kitchen stuff, and at the end of every trip, I sort all the things I didn't use into the 2nd box. I've gotten to the point where I just take 1 now, since I proved half the crap I used to carry wasn't necessary.
Latest experimentation is how to carry a few bundles of firewood on top of the truck safely, so I have to do less scrounging at campsites.
Have fun with it!
Originally Posted by DabberAZ
Dang
@ rageandlove
Thanks for sharing.
08-26-2020, 01:17 PM
Look into something like LFD Off Road's awning brackets for stock roof rails. Depending on what your awning brand's specification is, 16" should be alright. ARB's specification allows for up to 700mm (~27.5") unsupported. Getting extra wind noise is probably likely.
The problem with the outlets in the back is two fold, firstly they are only powered when the truck is turned on; and secondly the 12v outlet is fed by wires that are much smaller than most (all?) fridge manufacturer's recommend.
'18 TRD Off Road
|LFD Off Road Full Length Rack/Dual Swing Rear Bumper/Gas Tank Skid|Warn Slimline|Mobtown Powertrain Skids/Sliders|C4 2nd Battery Tray/Diff Skid|
|Smittybilt X2O 12k|Dobinsons 314/574&329/701 & Snorkel|JBA UCAs|Durobumps|3rd Gen RSB End Links|SDHQ ABS Guards|ECGS Bushing|Level8 MK6 w/ 255/80|
|LED Everything|Lots of Lights|Full Stereo|Icom IC-2730A|weBoost 4G-X|LTE Wi-Fi|DIY Not-Drawers|ARB 50/DFG Slide|Orange Boxx PSDs|ARB 2000|
08-26-2020, 10:56 PM
Two very good tips. Nice brackets. And dawg gone it on that tease outlet wiring. It funny, now adays, you can't have live battery in AUX unless you rewire. Thanks for protecting me from me.
Fridge should be here in a couple days. Awning a day or 2 after that. I can't wait.
08-27-2020, 10:23 AM
I bought a Dometic battery. Ties down behind fridge. Battery into rear 12V fridge into battery. Battery charges while you are driving and runs fridge at camp. Just ordered a 120 W fold up solar blanket so I can charge battery when staying in 1 place for a few days. Battery can also be used for phones, etc.
Portable batteries have come a long way. It's super easy to create a versatile setup that provides continuous power without needing to do any wiring etc. these days.
08-27-2020, 03:50 PM
Hmmm, do you have a pic of that. I just went cross eyed? I think I get it. Interesting approach.
08-30-2020, 03:58 PM
I'm going on a flyfishing trip Thursday. I'll post a picture Tue/Wed when I have stuff set up in the truck - ok?
08-31-2020, 06:31 PM
Fly Fishing (envious) safe travels and tight lines
I’m preparing for dove season tomorrow.
PS fridge arrived today
09-01-2020, 03:43 PM
Those outlets should work when the vehicle is on. But they are not hot when the car is off. Hopefully you are not like me and forget to push the button to turn the outlets “on” every time.
The external battery is a nice idea as well as wiring the fridge to your battery.
Issue I discovered in very hot climates is the fridge will not stay as cold when the vehicle is off. Keep the surrounding as cool as possible and find insulation, that will help a lot with the internal temp.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP
09-01-2020, 09:31 PM
What temps and what fridge are you using? I have a ARB 50 that lives in the truck 24/7, set to 32ºF, and even after the truck sitting in the sun for a few days of 95ºF+ temps it still solidly maintains 28-36ºF (depending on where it is in it's cooling cycle)
'18 TRD Off Road
09-02-2020, 02:58 PM
That is awesome, I need to switch. I have a Dometic
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
