Old 08-25-2020, 07:41 PM #1
lawn_gnome lawn_gnome is offline
lawn_gnome is on a distinguished road
RTT and Rack Noise - Creaking and Clunking
Hi All, looking for some help with my roof top tent (iKamper mini) and roof rack (prinsu full no drill) on my 2010 Trail. I have the tent mounted using the prinsu feet. There is a lot of noise coming from the rack or tent when driving. It isn't wind noise or whistling, but a sort of creaking or clunking. Any small bump or dip in the road will cause it, sometimes just turning and you can hear it creaking away. You can hear it with the sun roof closed, and when its open its quite loud.
I'm pretty new to the rack and tent so I'm wondering if it's common? If it is common, is there anything that can be done to minimize it? And if it isn't, what could be the cause.
Thanks for the help! Love the forum, been lurking around for years. Was really valuable when I had my '98 4runner.
lawn_gnome is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:36 PM #2
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
Not normal. My RTT makes zero noise, up to 85mph. I would start with any clunking, as that seems like a lose connection. Check all nuts and bolts are secure. This may include the RTT itself, check the tent/rail connectors.
Try lifting and shifting the RTT by hand and see if there is any movement or if you can reproduce the clunk.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Jpilot is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 09:10 PM #3
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I'm going to ask the obvious questions - you've confirmed everything is properly tightened down? There are lots of bolts between the roof / rack / cross bars / tent mounting - if a few were loose possibly that's the culprit?
Otherwise I'm of no help - no aftermarket rack or RTT here
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 09:19 PM #4
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
I have noise as well from an iKamper X-Cover (yes everything is tight). Narrowed it down to two things.
Hinges and the rails of the RTT on the aluminum rack rails flexing (Victory rack)
Hinges..not sure how to address that
Rails. I am going to mark where they touch front to back. Then when I remove it for winter I will cut up some bicycle inner tubes and slide them on on each rail (or heat shrink) to create a barrier between the aluminum RTT rails and aluminum rack rails
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 12:51 AM #5
SEOULBROTHA805 SEOULBROTHA805 is offline
SEOULBROTHA805 is on a distinguished road
Just curious if you were able to pinpoint the creeking, clucking noise from the roof rack? I’m having the same issue with my roof top tent on my prinsu rack.
SEOULBROTHA805 is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 01:01 AM #6
Mine was caused by the ladder moving around bouncing up and down inside the tent. Secured the ladder better and no noise.
Old 07-17-2021, 01:22 AM #7
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
My noise was caused by a couple loose roof rack bolts. Make sure every single bolt is tight. Bolts that mount roof rack to roof, every bolt on roof rack, mounting bolts between rack and tent, and the bolts that hold the tent rails to the tent. I check those every few thousand miles and a few have loosened up a little here and there over time and dirt roads.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 11:56 AM #8
Ventureast_t4r Ventureast_t4r is offline
Ventureast_t4r is on a distinguished road
I’m currently having the same issue with my ikamper 2.0 and prinsu full non drill rack. I am going to be going over everything today and re-tighten everything down. Does anyone use blue loctite to secure the rack to the truck? Or what about for every bolt on the rack (there’s definitely a lot) oh and make sure not to over tighten the bolts because I already snapped one and that’s no fun!
Ventureast_t4r is offline   Reply With QuoteReply With Quote
creaking , noise , rack , roof , tent
LCA creaking noise jonb2 4th Gen T4Rs 4 12-31-2018 08:30 PM
Creaking Noise Gesekee19 5th gen T4Rs 15 09-17-2017 03:31 AM
Clunking noise from rear end, trac bar makes noise when tapped with mallet thegipper 3rd gen T4Rs 2 04-18-2016 09:54 PM
03 Sport Front Popping Clunking Creaking Noise? dalandshark 4th Gen T4Rs 8 03-24-2015 07:47 AM
4th gen Creaking Noise hufflite Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-06-2014 11:21 AM
